August 16th, 2014, 02:50 AM | #1 |
Join Date: Apr 2013 Motorcycle(s): 250/300 Posts: A lot.
shock bolt cover
so the plastic cover that blocks you seeing the bolt for the shock has all ready fallen of any ideas on a place to get one? I want metal this time since factory is plastic. 2014 ninja 650r.
Hey Unregistered never go faster than your brakes can be applied... Last futzed with by fishdip; August 16th, 2014 at 07:05 AM. |
August 16th, 2014, 05:21 AM | #2 |
I believe they are same as the 250's part..
http://www.slingshotracing.net/catal...set-p-510.html |
August 16th, 2014, 05:46 AM | #3 |
My socks are okay. What I really need is a cover for my neck bolts.
nnnnggggggg.........
August 16th, 2014, 08:38 AM | #4 |
Hey Unregistered never go faster than your brakes can be applied... |
August 16th, 2014, 09:50 AM | #5 |
dose some one have calipers that can tell me the size of the hole on a 250?
August 16th, 2014, 11:33 AM | #6 |
OEM Parts listings:
Ninja 300 11065: CAP,SWING ARM BRACKET 11065A: CAP,SWINGARM BRACKET 65- is the bottom one w 4 indents 65a - is the top one, w/o the indents. 650: 11065: CAP,PIVOT COVER,RH,P. Same OEM part number as the 300's bottom one. 300 is same as 250's, so should be fine site used: http://www.bikebandit.com/oem-parts/...5385#sch798888 |
August 16th, 2014, 12:08 PM | #7 |
there are two sizes. but they always fall off. i would recommend you forget they ever existed.
August 16th, 2014, 12:12 PM | #8 | |
August 16th, 2014, 12:13 PM | #9 | |
ugly with out one.
August 16th, 2014, 12:28 PM | #10 |
which would you prefer, ugly, or extra useless pieces that don't do anything except look pretty and fall out?
August 16th, 2014, 02:17 PM | #11 |
Ahh I was thinking about wrong part...Sorry for that useless info.
August 16th, 2014, 02:31 PM | #12 |
if its one with rubber it won't fall out. its just the plastic one gets way to hot and AZ and falls out
August 16th, 2014, 02:32 PM | #13 |
Thanks for trying tho.
[motorcycledaily.com] - Star Motorcycles announces the 2015 Bolt*and Bolt R-Spec “Per | Ninjette Newsbot | Motorcycling News | 0 | June 5th, 2014 02:00 PM |
1 Head cover bolt, washer and o ring | WageSlaveEscapist | Items Wanted | 0 | September 27th, 2013 02:46 AM |
crank case bolt size(generator cover) | focus101 | 1986 - 2007 Ninja 250R Tech Talk | 1 | September 11th, 2013 06:10 PM |
Broke Off Valve Cover Bolt off any advice | cuz | 2008 - 2012 Ninja 250R Tech Talk | 19 | September 22nd, 2012 08:48 AM |
[superbikeplanet.com] - Dean Live In Portugal. Brought 14 Pair Of Underware & No Sock | Ninjette Newsbot | Motorcycling News | 0 | November 1st, 2008 02:49 PM |
