Old August 16th, 2014, 02:50 AM   #1
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
shock bolt cover
so the plastic cover that blocks you seeing the bolt for the shock has all ready fallen of any ideas on a place to get one? I want metal this time since factory is plastic. 2014 ninja 650r.
Last futzed with by fishdip; August 16th, 2014 at 07:05 AM.
Old August 16th, 2014, 05:21 AM   #2
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
I believe they are same as the 250's part..
http://www.slingshotracing.net/catal...set-p-510.html
Old August 16th, 2014, 05:46 AM   #3
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
My socks are okay. What I really need is a cover for my neck bolts.
nnnnggggggg.........
Old August 16th, 2014, 08:38 AM   #4
fishdip
fishdip's Avatar
Old August 16th, 2014, 09:50 AM   #5
fishdip
fishdip's Avatar
dose some one have calipers that can tell me the size of the hole on a 250?
Old August 16th, 2014, 11:33 AM   #6
EsrTek
EsrTek's Avatar
OEM Parts listings:
Ninja 300
11065: CAP,SWING ARM BRACKET
11065A: CAP,SWINGARM BRACKET
65- is the bottom one w 4 indents
65a - is the top one, w/o the indents.
650:
11065: CAP,PIVOT COVER,RH,P.
Same OEM part number as the 300's bottom one.
300 is same as 250's, so should be fine
site used: http://www.bikebandit.com/oem-parts/...5385#sch798888
Old August 16th, 2014, 12:08 PM   #7
there are two sizes. but they always fall off. i would recommend you forget they ever existed.
Old August 16th, 2014, 12:12 PM   #8
fishdip
fishdip's Avatar
Originally Posted by EsrTek View Post
OEM Parts listings:
Ninja 300
650:
the shock is not in the same spot as the 300?
Old August 16th, 2014, 12:13 PM   #9
fishdip
fishdip's Avatar
it looks kind of
ugly with out one.
Old August 16th, 2014, 12:28 PM   #10
which would you prefer, ugly, or extra useless pieces that don't do anything except look pretty and fall out?
Old August 16th, 2014, 02:17 PM   #11
EsrTek
EsrTek's Avatar
Ahh I was thinking about wrong part...Sorry for that useless info.
Old August 16th, 2014, 02:31 PM   #12
fishdip
fishdip's Avatar
if its one with rubber it won't fall out. its just the plastic one gets way to hot and AZ and falls out
Old August 16th, 2014, 02:32 PM   #13
fishdip
fishdip's Avatar
Thanks for trying tho.
[motorcycledaily.com] - Star Motorcycles announces the 2015 Bolt*and Bolt R-Spec “Per Ninjette Newsbot Motorcycling News 0 June 5th, 2014 02:00 PM
1 Head cover bolt, washer and o ring WageSlaveEscapist Items Wanted 0 September 27th, 2013 02:46 AM
crank case bolt size(generator cover) focus101 1986 - 2007 Ninja 250R Tech Talk 1 September 11th, 2013 06:10 PM
Broke Off Valve Cover Bolt off any advice cuz 2008 - 2012 Ninja 250R Tech Talk 19 September 22nd, 2012 08:48 AM
[superbikeplanet.com] - Dean Live In Portugal. Brought 14 Pair Of Underware & No Sock Ninjette Newsbot Motorcycling News 0 November 1st, 2008 02:49 PM
