Old July 18th, 2011, 10:17 PM   #1
Oaklandish
Oaklandish's Avatar
Motorcycle(s): 2002 ninja 250
how much does tire size affect the final drive?
would increasing the front tire size equal less rpm at higher speeds? (like gearing)
Oaklandish is offline   Reply With Quote
Old July 18th, 2011, 10:21 PM   #2
The size of the front tire has nothing to do with rpms of the engine, or gearing, is that what you meant?
Old July 18th, 2011, 10:41 PM   #3
Snake
Snake's Avatar
The front tire hub has a gear and cable that runns the speedometer and trip meter.
Old July 18th, 2011, 10:50 PM   #4
Oaklandish
Oaklandish's Avatar
I know gearing is what mainly determines rpm but i thought tire size influences it as well. isnt that why drag race cars have off set tires, for faster acceleration?
Old July 18th, 2011, 10:55 PM   #5
I'm still not sure I follow. Drag cars have tiny front wheels because they don't need anything larger. The thinner and lighter they are, the less drag they have, so at very high speeds, the car can go that slight bit faster than it would with wider or heavier wheels. They still have nothing to do with the drive of the car (or the bike), and have nothing to do with the gearing, or the drivetrain at all, right?
Old July 18th, 2011, 10:58 PM   #6
Oaklandish
Oaklandish's Avatar
i think you're following... my idea was this, wouldn't it take more rpm to push a bigger wheel? i might be wrong and its the same not matter what
Old July 18th, 2011, 11:07 PM   #7
No, the rpm's of the engine have nothing to do with the front wheel. If the rear wheel was taller, the rpm's of the wheel (and therefore the engine) would be slightly lower in proportion to the larger size of the wheel. It would be the same as going with slightly taller sprockets.
Old July 18th, 2011, 11:49 PM   #8
Snake
Snake's Avatar
Old July 19th, 2011, 01:02 AM   #9
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
The only thing that affects gearing other than gears/sprockets is the rear wheel diameter. The front will only affect the speedo reading.
Felipe the Ant is offline   Reply With Quote
Old July 19th, 2011, 07:59 AM   #10
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Yes, smaller diameter wheels will accelerate faster, but will not affect the Final Drive. Final Drive is speed vs. RPM. Acceleration is Time vs. speed.
So to answer your first post, a smaller tire circumference may allow you to accelerate slightly faster (probably not even noticeable), but won't do much for top speed. It does affect your speedometer reading in cars and bikes with electronic speedos, but not on our bikes since the speedo reads off the hub and is mechanical.
The www.ModMy250.com guy
Old July 19th, 2011, 02:51 PM   #11
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
Originally Posted by drsketch View Post
bigger front tire = less miles on speedometer, and keep in mind changing your bike may produce an effect that you do not want.
Your still travelling the same distance?
blink-182
blink is offline   Reply With Quote
Old July 19th, 2011, 05:52 PM   #12
Suave
Suave's Avatar
tire size will not significantly effect your rpms at all on the subject of gearing, but it will require an increase of power to turn them because the added weight and drag. I know what you are asking because I asked the same thing in my first Auto-class in high school lol There was a lot of pain and pictures and yelling before it was explained to me in a way I understood ; but I assure you, alex is right, tire size will not 1. effect your rpms 2. effect your speed 3. change your acceleration/top speed on a gearing level (it is only top speed) will if you get a larger size. The reason drag cars have smaller fronts is like Alex said, less drag = faster accel; and like Thunder said, it will only change your acceleration very slightly, probably only hundreths and maybe tenths of a second (because sometimes that makes the difference on the strip)
"Hey man, I'm not tryin' to start nothin'. But... i wouldn't take that"
Suave is offline   Reply With Quote
Old July 20th, 2011, 08:42 AM   #13
ducducgooseit
Motorcycle(s): ...
Silly readers. ANY change in the circumference of a tire will change the wheels RPM given a steady velocity. The question that should be asked is, "At what size will the change in rpms be noticeable?" THAT question should be answered thusly, "At no size that will make the vehicle behave the same will a tire change noticeably affect the wheels RPM."
ducducgooseit is offline   Reply With Quote
Old July 20th, 2011, 08:51 AM   #14
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Only the diameter of the DRIVE tire will affect the final drive. The front tire is just an idler. It can be a roller blade wheel and the bike will still go the same speed, regardless of the rpm of the front tire. The only thing that may change with a different size front tire is the REPORTED speed, as the speedometer reading is taken off the front wheel.
Some of you need to sit through 6th grade science again. Simple machine #1 - the wheel.
The original question is vague, but alex is correct. Changing the size of the front tire will have no effect on the speed or gearing of the bike mechanically. Only the reported speed as the front wheel will be spinning at a different rpm.
Old July 20th, 2011, 09:01 AM   #15
CynicalC
CynicalC's Avatar
Originally Posted by CThunder-blue View Post
A smaller tire circumference may allow you to accelerate slightly faster
This is incorrect, as we're talking about the front tire.
It does affect your speedometer reading, but not on our bikes since the speedo reads off the hub and is mechanical.
This is also incorrect, for the reason you stated. A smaller front tire would cause the front wheel (hub and all) to be turning at a higher rpm. It will effect the speedometer reading.
Old July 20th, 2011, 09:09 AM   #16
CThunder-blue
ModMy250.com
In regards to the our 250, we already experience up to a 10% discrepancy in speed. A slight change in tire size will not make a noticeable difference in the way the mechanical speedo reads.
Old July 20th, 2011, 09:10 AM   #17
blink
Always.
blink's Avatar
We are talking about actually RPM which is engine speed. Not tires, so in this case your argument is true in a non relative way
blink-182
Tire size question sidekick10121 1986 - 2007 Ninja 250R Tech Talk 5 March 11th, 2014 06:39 PM
Tire Size Dilemma rdrgoB 1986 - 2007 Ninja 250R Tech Talk 6 July 3rd, 2012 04:58 PM
Tire size advice koenigcitizen 2008 - 2012 Ninja 250R Tech Talk 37 June 11th, 2012 03:40 PM
What size drive head do I need? jenndiggity 2008 - 2012 Ninja 250R Tech Talk 15 May 10th, 2011 11:03 AM
tire size unowned Ninjettes At Speed 13 June 13th, 2009 03:34 PM
