Old July 24th, 2018, 05:44 PM   #41
MrMushroom86
MrMushroom86's Avatar
Motorcycle(s): 1994 Kawasaki Ninja 250R, 2009 Kawasaki Ninja 250R Limited Edition
My 250R still in progress
Okay so I posted before about some of the mods done, but didnt have pictures to show at the time. I still have to put the front light with the turn signals on and the plate bracket with turn signals / running / brake lights on.
Tires and suspension are off a 2nd gen so they are a bit bigger than stock. Front tire is 110/70R17 and rear tire is 140/70R17. Led tail lights and turn signals, rear spring I was told is off a Yamaha R1. Various other mods but these are the biggest ones.
MrMushroom86 is offline   Reply With Quote
Old September 8th, 2018, 10:45 AM   #42
thumper64
-new gen front and rear suspension
-new gen headlight mounted on driving light brackets and L brackets.
-ex500 gauge cluster, the tach reads a bit off but it works for my purposes
-ex500 rear shock and springs in front
-bike lowered about 2" front and rear
-dirtbike handlebars on homemade adapter plate on upper triple tree.
-UNI pod filters and Area P exhaust 112.5 main jet, 42 pilot and 2 washers under each needle, IIRC. Pilots could be dropped a size, but this starts in 30* weather.
-2x 6 LED driving lights
-Rear of frame chopped off and seat shortened, tail light and grab bar welded on closer.
-Removed fairings and service stand.
Next up is porting the head. I have a ticking sound coming from the left cylinder, and I found a used head and timing chain guides cheap, and I'll get a new timing chain tensioner to put on at the same time. Looking at the head, there's some pretty obvious things to clean up like casting lines and sharp edges without making any major changes, I'm just not sure how far to go, like deshrouding valves, where it will flow better but not drop compression too far and shift the power band too much. It'll probably benefit from a bit more compression and timing advance though, so I'm already planning to just omit the base gasket under the jugs and do the timing pickup mod. I believe it's the intake cam that was suggested to advance 1 tooth to improve top end.
Motorcycle noob, feel free to ignore me.
thumper64 is offline   Reply With Quote
Old September 12th, 2018, 01:24 PM   #43
Jpc647
Motorcycle(s): 07 Ninja EX250 , 2005 SV650, 2003SV1000
Originally Posted by greg737 View Post
Fuel Injection.
How?
Jpc647 is offline   Reply With Quote
Old September 12th, 2018, 02:16 PM   #44
taz
taz's Avatar
MOTM - May '17
im just guessing he put a micro squirt system in it and could be this one https://www.ecotrons.com/small_engin...injection_kit/
Old September 12th, 2018, 06:22 PM   #45
greg737
Motorcycle(s): -
Originally Posted by Jpc647 View Post
How?
I did a MicroSquirt conversion on my '05 Kawasaki EX250 and '93 Suzuki GSF400.
Both run great. I did the conversion on the EX250 in 2009 and the GSF400 in 2013.
This past spring/summer I dug back into the EX250 to upgraded/improve the fuel injection (and ignition control) because this bike is becoming my younger daughter's ride now. This was both a desire to make sure the bike was up to spec because it's my daughter (right?) and because I enjoy tinkering in the garage.
So I improved its fuel delivery system and I implemented full ignition control, the most important item in this was adding the alternator rotor from a 2015 EX250 (this new-generation rotor has a "24 minus 2" trigger pattern on it, which works perfectly with the MicroSquirt firmware and it fits perfectly on the pre-gen EX250).
Other parts in the FI system:
ECU = MicroSquirt V3
Throttle Body = from a parted-out European 2008 EX250 (the first FI EX250)
fuel manifold in place of original fuel petcock = Pingle FI manifold
fuel pump = Honda TRX500 Rancher (four wheeler) fuel pump
Manifold Absolute Pressure Sensor = Motorola MPX4115
Intake Air Temp and Water Temp sensors = General Motors (AC Delco)
Wide Band O2 sensor + sensor controller = Bosch sensor + Innovate LC-1
Upgraded Fuse Box = Eastern Beaver PC-8 Fuse Panel
Old September 13th, 2018, 08:25 AM   #46
Had non-functional petcock on my street pre-gen. Someone had removed spring and it doesn't turn off properly, leading to leaking-carb filling up my engine and hydrolocking it. I installed new-gen petcock on it. Don't have gas-gauge, don't have reserve. But at least I know it functions properly. Just have to odometer and refill every 250-miles or so.
Some more mods Somchai 2008 - 2012 Ninja 250R Farkles 20 March 7th, 2016 03:47 AM
pregen risers now available & safety mods isuoboe 1986 - 2007 Ninja 250R Farkles 1 September 25th, 2015 10:36 PM
My mods so far... ninjamunky85 2013 - 2017 Ninja 300 Farkles 35 August 11th, 2013 10:54 PM
First Mods FoxRacerX78X 2008 - 2012 Ninja 250R Farkles 5 April 4th, 2012 03:24 AM
What are some MUST have mods? aznboi250r 2008 - 2012 Ninja 250R Farkles 11 June 26th, 2011 09:52 PM
