Old September 11th, 2018, 06:35 AM   #1
Hewes
Motorcycle(s): 2007 Ninja 250R
2007 250R Starting Trouble
Hi! First post, please no roast.
Bike is a 2007 Ninja 250R with 4000 miles on the odometer.
This is also my first bike. I got the bike home yesterday and it was struggling to start, I had the choke full on and had to give it gas to get it to roughly idle below 1k RPM. I think the idle adjustment screw was out of adjustment so I turned it all the way tight and then backed it off 2.5 turns because I read online that this is where the factory idle setting roughly is. I did get it to start at some point and it revved up to around 10k and with some adjustment I got it to idle at 3k but I couldn't get it to drop below that without dying. It was low on gas so I added a gallon (couldn't find a bigger gas tank because, unfortunate timing, I'm in NC where the hurricane is supposed to hit).
Any thoughts? Should I take out the carb? I've never serviced a carb but I have some tools and have experience working on cars.
Thanks
File Type: jpg 41554406_476794086134080_7853886843685699584_o.jpg (131.1 KB, 7 views)
Hewes is offline   Reply With Quote
Old September 11th, 2018, 07:08 AM   #2
rottyfan
Motorcycle(s): 2006 Ninja 250, 1999 Aprilia RS50
Sounds like your carbs just need a good cleaning. The best advice I can give you is to do the airbox mod to make removing and installing the carbs a breeze.
https://www.youtube.com/watch?v=s86bimD4ft0" TARGET="_blank">Link to original page on YouTube.
Cleaning the carbs is not that difficult, all you need are basic tools and take your time. The carbs on these bikes do not act that well when they sit for a period of time, but a good cleaning brings them right back. Hope this helps and good luck with the storm.
rottyfan is offline   Reply With Quote
Old September 11th, 2018, 09:12 AM   #3
Hewes
Thanks!
I'll give it a shot. I'm hesitant to do the air box mod because I don't like sawing into stuff but I'll clean the carbs for sure. Hopefully it survives the Armageddon.
Old September 11th, 2018, 09:50 AM   #4
First thing I would do is completely drain the gas from the tank and floatbowls. Use fresh 87 octane, ethanol-free if it's available.
I'd also check all of the clamps around the carb, because you could have a vacuum leak. Spraying carb cleaner on the boots (when it's running) will tell you if there is a leak.
Have the caps been removed from the idle mixture screws on the bottom of the carbs? Those are the screws that should be set to 2.5 turns out as a starting point.
If all that checks out, it may be time to pull the carbs. I wouldn't say doing it properly is easy, as it takes more than a can of carb cleaner and compressed air to really get them clean. If you get to that point, and don't want to do it yourself we will put you in-touch with ducatiman.
How does the air filter look?
There's a bunch of good info here - https://faq.ninja250.org/wiki/Ninja250_Howto
Old September 12th, 2018, 03:08 AM   #5
No need to chop airbox, here's how to extract carbs easily in less than 5-min:
1. Remove seat, side-covers, tank, battery
2. Remove screws at bottom of battery box
3. Remove choke & throttle cables
4. Spray WD-40 on carb-boots and warm them with hair-dryer for 1-min
5. Loosen ONLY clamps between boots and carbs, slide clamps towards middle of boots
6. Grab carbs and slide them backwards out of boots
7. Loosen LEFT carb boot clamp to head, slide clamp toward middle of boots
8. Carefully pry LEFT carb boot off head with rear sliding back onto carb
9. Pull front of LEFT boot sideways to remove
10. Loosen clamps/spring-rolls between carbs & airbox
11. Push carbs forward off airbox
12. Remove carbs sideways from left side.
The trick is to leave them attached to airbox to make as much clearance in front as possible to remove left boot completely. And leave right boot firmly attached to head to give enough clearance to remove carbs sideways
Trouble starting matt021126 2008 - 2012 Ninja 250R Tech Talk 6 May 12th, 2017 05:26 AM
Trouble starting Wrestler174 1986 - 2007 Ninja 250R Tech Talk 1 June 14th, 2015 06:02 PM
Bike has trouble starting capriccio 2008 - 2012 Ninja 250R Tech Talk 7 July 19th, 2012 10:37 AM
Trouble Starting dlebe250 1986 - 2007 Ninja 250R Tech Talk 7 January 12th, 2011 07:47 AM
trouble starting... n4v1n 2008 - 2012 Ninja 250R Tech Talk 4 August 9th, 2009 03:18 PM
