Old September 24th, 2018, 12:57 PM   #1
tanghonglai
Motorcycle(s): 2006 Ninja 250
Torque link nut
Hi,
The manual says we need to loosen the torque link nut before adjusting the chain slack. Is it absolutely necessary? If so, what kind of tool do you use to reach it? It's very tight but the pipe's getting in the way so my socket wrench can't reach it. Do you remove the pipe every time you adjust your chain?
Thanks,
Tang
tanghonglai is offline   Reply With Quote
Old September 24th, 2018, 03:26 PM   #2
taz
taz's Avatar
MOTM - May '17
Well i never do if that helps.
Old September 24th, 2018, 03:59 PM   #3
greg737
Motorcycle(s): -
Originally Posted by tanghonglai View Post
Hi,
Thanks,
Tang
The human willingness to imagine that they are somehow smarter than the vehicle engineers who actually built the motorcycle always amazes me.
Here's a test for your question:
After you've loosened up the rear wheel axle nuts and after you've backed off the long bolts in the chain adjustment adjustment mechanism (on the rear of each side of the axle) can you move the rear wheel forward and backward?
(Hint: If the rear brake torque link is still properly tightened you should find that only the left-hand side of the rear axle will move, and it will only a little bit.)
If you find that you can move both sides without loosening the rear brake torque link then it wasn't properly tightened last time it was installed.
Old September 24th, 2018, 08:03 PM   #4
There are no shortcuts!
There never seems to be enough time to do it right,
but there's always time to do it again!
How to Use a Torque Wrench Motofool General Motorcycling Discussion 31 October 23rd, 2016 06:42 PM
More torque RadenRider26 2008 - 2012 Ninja 250R Farkles 17 October 5th, 2015 04:33 PM
torque skip 2008 - 2012 Ninja 250R Tech Talk 7 May 22nd, 2014 02:55 PM
clutch lever pivot bolt/nut torque specs Confuzshuz 2008 - 2012 Ninja 250R Tech Talk 3 September 25th, 2012 05:11 AM
axle nut torque? nate-bama 1986 - 2007 Ninja 250R Tech Talk 10 July 3rd, 2009 08:22 AM
