Old April 2nd, 2009, 02:21 PM   #1
00v_Lucky
00v_Lucky's Avatar
Motorcycle(s): '09 Candy Thunder Blue Ninja 250R
Wind Shield Problem
After seeing the thread on the smoked turn signals, I decided that instead of dropping 70+ on a wind screen, might as well just do a free job and use the leftover smoke-out spray for car tail lights.
Did not come out the way I wanted, but still looks better than stock. Anyways, the problem I have right now is that one of the screws (facing the bike's headlights, bottom left screw will not go in) I tried both of the long screws on it and also by kind of pushing the dash up a bit but for some reason it will not go in, the screw kind of bounces or springs up.
My current solution: washable white glue the washer and screw. (I am pretty sure that this will not screw up the paint, or prove me wrong please)
damn screw, there is no possible way that I stripped the screw or anything right? the screw itself isnt damaged but I do not know, I can barely see inside of the hole to see if there is damage in there. I will be honest, I was a bit frustrated so I tried putting pressure trying all angles and what not.
help?
00v_Lucky is offline   Reply With Quote
Old April 2nd, 2009, 02:25 PM   #2
those screws are held in by wellnuts. look at my DIY on installing the ZG DB. You can actually reach up under the front nose piece and grab onto the wellnut to keep it from spinning... if it's still there. Look up under there and check it out.
Old April 2nd, 2009, 02:36 PM   #3
00v_Lucky
00v_Lucky's Avatar
roger that.
Old April 2nd, 2009, 03:48 PM   #4
Jiu Jitsu Player
Live 2 Ride Forced 2 Work
Jiu Jitsu Player's Avatar
Motorcycle(s): 2008 RED 250r
I concur. I read Kkim's DIY on this and I screwed everything in in the order he specified. If you try to do it any other way you may wind up having to unscrew everything to properly position it. Kkim is the 250 Yoda. Not following his DIY unwise it is.
SAVAGE MODE: [ON] OFF
www.7milesdown.com
Jiu Jitsu Player is offline   Reply With Quote
Old April 2nd, 2009, 05:53 PM   #5
Moo-wasaki
Moo-wasaki's Avatar
Motorcycle(s): 2008 Ninja 250
You seek KKim, you do...The force is strong in that one!
Moo-wasaki is offline   Reply With Quote
Old April 2nd, 2009, 06:45 PM   #6
Sailariel
Sailariel's Avatar
Used KKim`s DIY and installed a ZG Sport Touring windscreen in less than five minutes. The DIY`s on this forum are priceless.
Old April 2nd, 2009, 10:08 PM   #7
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Ooo, I want to join the club too!
Kkim, you're so cool!
Also, you reckon you can post up pics of the windscreen? thanks.
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
miks is offline   Reply With Quote
[motorcyclenews.com - news] - Staff Blog: Trying to solve my wind problem Ninjette Newsbot Motorcycling News 0 August 21st, 2013 02:20 AM
