Old April 22nd, 2009, 08:14 PM   #1
SpyderGirl
3 for street, 2 for dirt
SpyderGirl's Avatar
Motorcycle(s): 2008 Can Am Spyder PE #1344 / 2009 Kawi KLX140L Monster Energy / 2009 Kawi Ninja 250R (RIP 8.23.09)
Blazer LED White Foglights
So I installed these on my baby and I was shocked to see that they throw out a lot of light. I am hoping they will be a good attention getter for the cagers to see me better.
Feel free to look me up on facebook.
SpyderGirl is offline   Reply With Quote
Old April 22nd, 2009, 08:21 PM   #2
curious... how did you run the wiring?
Old April 22nd, 2009, 08:28 PM   #3
SpyderGirl
SpyderGirl's Avatar
I ran the wire through the hole where the fender mounts on the bottom, mounted the base over the hole in the fender, then wire tied it to the fender bracket behind the fender, ran the wire along behind the fork and along the brake line and wires on each side. It was quite easy and lots of clearance and slack without interference to the steering, wheel, or brake. I'd take a photo but it wouldn't come out.
Old April 22nd, 2009, 08:34 PM   #4
keep an eye on the wiring for wear. I assume they are fused? As the front forks work up and down, they will rub, though you may not encounter any problems. If you do, armor it with some electrical plastic loom.
Looks great. I've thought of dong something similar, but didn't like the idea of having to run electrical down the forks to the wheel.
Making yourself more conspicuous...
Old April 22nd, 2009, 08:37 PM   #5
Rynownd
Rynownd's Avatar
http://www.southparkstudios.com/clips/224099
Rynownd is offline   Reply With Quote
Old April 22nd, 2009, 08:38 PM   #6
SpyderGirl
SpyderGirl's Avatar
The wires are wrapped an insulated in PVC waterproof wire sheathing and are not rubbing against the forks. There is plenty of slack. I turned the wheel full both directions.
I thought it would be hard, but it wasn't. I'll keep you updated on how they are holding up.
Old April 23rd, 2009, 09:10 AM   #7
camaroz1985
camaroz1985's Avatar
Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold)
Very nice. Very clean looking as well. Before I did the HIDs I was looking into doing something similar.
camaroz1985 is offline   Reply With Quote
Old April 23rd, 2009, 09:13 AM   #8
Snake
Snake's Avatar
Very nice instalation.
Old April 23rd, 2009, 09:19 AM   #9
SpyderGirl
SpyderGirl's Avatar
Thanks. I am happy at the way it turned out and the size and fit is perfect.
I'm still going to do the HIDs as well, never can be TOO visible.
Old April 23rd, 2009, 11:14 AM   #10
camaroz1985
Where did you buy the lights?
Old April 23rd, 2009, 11:21 AM   #11
SpyderGirl
SpyderGirl's Avatar
Kragen Auto Parts. I'm not sure what it's called out there... maybe O'Reilly's I think ??
Old April 23rd, 2009, 12:03 PM   #12
camaroz1985
Thanks!
Old April 23rd, 2009, 04:46 PM   #13
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
They look very nice! Makes the bike look more mennacing at night!
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old April 23rd, 2009, 07:58 PM   #14
SpyderGirl
SpyderGirl's Avatar
I am so surprised how bright they are!
Ninja White Face cluster LED colors? relic 2008 - 2012 Ninja 250R Farkles 4 January 27th, 2013 01:11 PM
I want.. to see.. the white light.... (White Bike with LED? Can I see?) Mr.E Pictures 28 January 28th, 2012 09:07 PM
LED Question (Blue or White + Installation) AeroXtasy 2008 - 2012 Ninja 250R Tech Talk 18 August 26th, 2011 10:10 PM
new horn-Blazer Claxon Low Tone Otter 2008 - 2012 Ninja 250R Farkles 16 August 13th, 2011 08:56 PM
[hell for leather] - Belstaff District Blazer, finally better than Grandpa's Ninjette Newsbot Motorcycling News 0 May 19th, 2009 05:00 PM
