Old October 25th, 2017, 02:42 PM   #1
corksil
Motorcycle(s): A lot.
Rear shock conundrum!
I bought a used rear shock as a budget 25 dollar upgrade for a bike.
The shock showed up, and after a few hours of custom fabrication to make it fit the bike -- I removed the spring so I could install the shock and run the swing arm fully up and down to check chain tension, brake caliper clearance, exhaust clearance, etc.
Once I removed the spring, and the plastic cover (protecting the shock shaft) beneath it, I discovered that the bump stop was virtually non-existent. The rubber had crumbled and dry-rot had decayed what was left of the bump stop.
Being resourceful, I ordered a replacement bump stop. Once it arrived, I set the shock in the vise and began to remove the lower eyelet so I could install the replacement bump stop.
Upon cracking the nut loose, I heard a hiss and approximately 1cc of oil came out around the threads. Realizing what was happening, I immediately re-tightened the nut and sat down to re-think things.
I thought nothing of depressurization or oil loss before taking it apart because I had just done a spring swap on a similar minibike shock the day before. Obviously the minibike shock was not as sophisticated, and therefore not losing any pressure when I removed the lower eyelet. In hindsight, I should have known that I would lose pressure if I loosened that nut. Not my finest moment.
Now I have a shock with no bump stop, compromised internal pressure and oil volume, and a 'rebuild' estimate of 200 bucks from racetech to install the bump stop that I bought.
This was supposed to be a "budget" upgrade. As of now I've got..
-useless 25 dollar shock
-useless 35 dollar bump stop
-useless 20 dollar dog-bones
-30 bucks in wasted hardware/fasteners
-5 hours of fabrication and time
...and my pride won't let me write all this off as a mistake and put the OEM shock back on.
I can either..
-send shock to racetech for 200 and they will install bump stop and re-charge oil/pressure
-buy new/old "budget" shock of same make/model and hope it has a decent bump stop
-throw it all in the trash and feel sorry for myself
Old October 25th, 2017, 03:03 PM   #2
Remove the upper eyelet.
Which shock did you get?
Last futzed with by DannoXYZ; October 25th, 2017 at 04:12 PM.
Old October 25th, 2017, 06:28 PM   #3
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
better yet, remove the pride and the whole God damn shock. Replace it with an OEM. Browse online. Get a new one. It was just one of those ways nature tells you that sh*t ain't working.
We all have been through this. Well, not replacing shocks, but something similar. I chose to save my time since I can do other things which will be way more productive.
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Need New Rear Shock akima 2008 - 2012 Ninja 250R Tech Talk 30 September 24th, 2015 11:58 AM
Gixxer rear shock question - rear stiffness too high cookiebug79 2008 - 2012 Ninja 250R Tech Talk 20 January 17th, 2015 08:19 AM
Rear shock set to high (rear wheel slipping)? passive101 2008 - 2012 Ninja 250R Tech Talk 6 August 10th, 2014 08:45 PM
For sale: 2003 ninja 250 rear brake pedal and rear shock ReDnEcK Motorcycle-related 0 October 6th, 2010 12:02 PM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
