Old March 2nd, 2016, 02:45 PM   #1
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
Clutch switch delete.
So i removed the clutch switch when i cut down my harness... I can not start my bike in gear... Should i connect the wires or leave it open? Had an issue with the bike dying in gear this past weekend because the wires came apart (i didn't permanently connect them in case i read the schematic wrong), put them back together and the bike ran fine other than having to be in neutral to start it.
Dsheumaker is offline   Reply With Quote
Old March 2nd, 2016, 02:54 PM   #2
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Connect them together permanently.
Goin' fast on slow bikes!
Old March 2nd, 2016, 02:57 PM   #3
Dsheumaker
Dsheumaker's Avatar
But I have them connected now and have to start in neutral ??
Old March 2nd, 2016, 02:58 PM   #4
chugs
Schönen Tag noch
chugs's Avatar
Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica
I just heatshrinked them together.
chugs is offline   Reply With Quote
Old March 2nd, 2016, 03:02 PM   #5
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Sidestand switch wires connected together? Do those too.
Does your neutral light work?
Old March 2nd, 2016, 03:04 PM   #6
There are 3 safety switches; clutch, neutral and sidestand. All 3 can be disabled at your own risk.
http://faq.ninja250.org/wiki/Underst...afety_switches
Old March 2nd, 2016, 03:08 PM   #7
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
After reviewing a wiring diagram, my bad, sidestand doesn't control the starter, only ignition.
Old March 2nd, 2016, 03:16 PM   #8
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
If it still won't start in gear, they aren't connected together properly OR are disconnected somewhere else in the loom.
Those are the only wires preventing you from starting in gear.
Old March 3rd, 2016, 03:36 AM   #9
Dsheumaker
Dsheumaker's Avatar
So i think i know what my issue is, just dont have time to fix it till after this track weekend. I had my sidestand siwtch and clutch switch mixed up. Sidestand is was i fixed the other day, need to fix the clutch switch at some point. should be able to look at it next week, ill give update then.
Old March 26th, 2016, 11:03 AM   #10
All fixed?
Old March 26th, 2016, 01:21 PM   #11
HoneyBadgerRy
HoneyBadgerRy's Avatar
I completely disabled the clutch and the stand safety switches, but aperently I forgot the neutral safety switch.
Old March 28th, 2016, 11:16 AM   #12
Dsheumaker
Dsheumaker's Avatar
I just didnt have it grounded. As soon as i grounded the clutch safety wire it started working correctly, just did it a week or so ago, sorry for forgetting to post up.
Old March 28th, 2016, 11:37 AM   #13
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Thanks for the update!
Old March 30th, 2016, 11:22 AM   #14
Dsheumaker
Dsheumaker's Avatar
Yea i love being able to start it in gear now! So much easier haha. It would have sucked before if i would have stalled off the line of a race and had to find neutral and then start it and put it back in first haha. MY switch never worked before i cut down the harness either.
Old March 30th, 2016, 11:27 AM   #15
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Have you done the ignition delete yet? It gets rid of the key and makes everything power on and off through the kill switch. It's a neat mod that only takes an hour or so if you're competent with electrical and a soldering iron.
Old March 30th, 2016, 11:30 AM   #16
HoneyBadgerRy
But unlike the other mods, this makes your bike track dedicated.
Old March 30th, 2016, 11:42 AM   #17
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Why?
Old March 30th, 2016, 11:46 AM   #18
HoneyBadgerRy
Why?
I leave my key in the ignition all the time, but I live in a weird area. Normal people would get their bike stolen if they didn't need a key to start it.
Old March 30th, 2016, 11:54 AM   #19
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Would they?
If a thief wants your bike, they're going to kick the bars to break the bar lock and either break your ignition switch, punch it out or bypass it.
If they want your bike, they will take it period.
Besides, without an ignition switch will they figure out how it works?
Old March 30th, 2016, 11:57 AM   #20
HoneyBadgerRy
Would they?
I'll admit, I don't know much about theives, because around here, nobody steels anything.
Old March 30th, 2016, 12:51 PM   #21
Dsheumaker
Dsheumaker's Avatar
Yea i already ditched mine. Have the switch in plain sight on my home made fairing stay, have had people look right at it and not see it haha. I had fun figuring out how to get the switch to work while still having some lights hooked up haha
Old March 30th, 2016, 01:40 PM   #22
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
hehe. I have a switch for my heated grips. People ask me what it's for and I'll tell them that's my wheelie power switch.
Old March 6th, 2017, 06:46 PM   #23
howlinhoss
Motorcycle(s): Ninja 300
So I am planning on doing this soon. I removed the whole turn signal/headlight switch housing/clutch switch from the main wire harness. Can I just use a wire to jump the hot and ground female terminals on the main wire harness?
howlinhoss is offline   Reply With Quote
Old March 7th, 2017, 07:21 AM   #24
Dsheumaker
Dsheumaker's Avatar
Jose,
Here is a snip from the manual for the left bar harness. Just need to connect the two wires. I had an issue on my 250 with something not being grounded, but that was a long time ago and i dont completely remember what it was. See you at NCbike.
Old March 13th, 2017, 04:44 PM   #25
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
On the PreGen/500, the clutch switch bridges to the common black/yellow ground wire. On the NewGen (and I assume the 300), it bridges to the sidestand switch instead.
On the older bikes, pulling the clutch will let the bike start and run, regardless of any other switch's status. On the new bikes, pulling the clutch will only work if the sidestand is up/bypassed also.
Old November 18th, 2017, 05:09 PM   #26
mindgam35_civic
mindgam35_civic's Avatar
Motorcycle(s): gy6 ruckus, ninja 250r
Hate to bring up an old thread, but I'm looking for some insight. Converting my 300 into a dedicated track bike and want to remove the clutch side controls. Including the clutch switch...
I will also be removing the kickstand... so I'll have to bypass that as well. I get the idea of connecting the 2 wires feom the clutch switch together... and the 2 wires from the kickstand switch together... but someone above said something about a neutral switch. I can't find any info on this.
I want to be able to start in neutral or in gear with clutch in
Any help is appreciated!
mindgam35_civic is offline   Reply With Quote
Old November 18th, 2017, 05:37 PM   #27
If you disconnect the clutch switch wires and connect them together, you can do what you said you want to do, since the electrical system will think you're always pulling the clutch lever. Obviously you will also be able to start the engine with the lever released (clutch engaged), making you lurch forward, but I assume that's not going to be a problem for a track bike.
Old November 18th, 2017, 06:53 PM   #28
howlinhoss
Disconnect the clutch switch at the clutch perch and the harness. Then remove the turn signal housing. You can then separate the clutch switch wires.
Old November 18th, 2017, 10:29 PM   #29
mindgam35_civic
Thank you both. I'll dig into it tomorrow...
Any idea what honeybadgerry was talking about with the "neutral switch"?
I should be able to just cut the kickstand sensor and jump the 2 wires... and do the same for the 2 clutch wires... soldering then of course.
Anyway, thanks again.
Howlinhoss - I dig your 300 build. I've come across it several times in my research for building my bike.
Old November 19th, 2017, 04:26 AM   #30
The neutral switch is 3rd safety-interloc. If you bypass clutch and kickstand switches, it'll be possible to start bike in gear with clutch engaged. The neutral switch is only safety left and prevents the bike from starting unless transmission is in neutral.
Old November 19th, 2017, 06:43 AM   #31
Do you mean that normally it does that? As you said above, once you bypass the clutch lever switch, the neutral switch won't keep you from starting in gear, at least if I'm remembering right. I admit I'm used to old bikes with no interlocks at all.
2 more q's. Carb removal and clutch switch peperino 2008 - 2012 Ninja 250R Tech Talk 14 January 31st, 2016 06:49 PM
WTB 08+ clutch switch Gandalf Items Wanted 2 October 12th, 2014 12:59 PM
clutch switch l agent of orange General Motorcycling Discussion 2 July 1st, 2014 05:15 PM
Area P full race exhaust/jetting/airbox-delete/kleen-air delete.. corksil 2008 - 2012 Ninja 250R Tech Talk 24 January 21st, 2014 07:57 PM
How do I delete a thread and delete profile ojameyo Help 18 July 17th, 2012 10:48 AM
