Old July 31st, 2017, 09:00 AM   #1
[motorcycle.com] - 2018 BMW HP4 Race Priced at $78,000 US
BMW has announced U.S. pricing for its exotic carbon fiber sportbike. Arriving in American dealerships this fall, the 2018 BMW HP4 Race is priced at $78,000.
Only 750 units will be produced, worldwide, but it’s not clear how many will be available in the U.S. Visit the link above for our original announcement post, but for the cliff notes version, here’s what $78,000 gets you below.
2018 HP4 Race (arriving Fall 2017)
MSRP — $ 78,000
Standard Features and Specifications**
  • Volume is limited to 750 consecutively-numbered units worldwide
  • Milled fork bridge with carbon badge (numbered 001/750 to 750/750)
  • DIN wet weight 377 lbs (171 kg)
  • Dry weight 322 lbs (146 kg)
  • 999 cc, 4 cylinder, water/oil cooled HP4 RACE factory engine
  • 215 hp, 88 lb-ft of torque (120 Nm)
  • Reinforced WSBK transmission, longer first and second gear
  • Titanium bolts used throughout to minimize weight
  • Brembo GP 4 PR brake calipers
  • 6.75 mm brake disc thickness
  • Highly precise and steady brake pressure points
  • Brembo radial brake master cylinder
  • Carbon front wheel: 1.7 lbs (770 g) lighter than forged wheel
  • Carbon rear wheel: 1.7 lbs (770 g) lighter than forged wheel
  • Öhlins FGR forks from the WSBK (fully adjustable)
  • Variable fork bridge offset: 28 – 30 mm and 26 – 32 mm
  • Steering head angle adjustment from -0.5° to +1°
  • HP brake and clutch levers
  • Milled aluminum switches
  • Racing wiring harness prepared for 2D linear position sensor
  • Unitary HP carbon front
  • RTM carbon frame (Carbondrive) 17 lbs (-9 lbs vs. RR)
  • Lohmann HP Shift Assist Pro
  • Brushed and polished aluminum tank
  • Unitary HP carbon rear
  • 32.7” HP race seat, adjustable from 32.1” – 33.3”
  • One-piece carbon intake muffler and side trim panel
  • Carbon race engine spoiler
  • Complete carbon trim panel
  • Milled HP footrest system: 8-way adjustable
  • Öhlins TTX 36 GP rear shock
  • Two plates to adjust spring strut position
  • WSBK swingarm
  • Eight inserts for swingarm position -3 mm to +4 mm
  • 520 racing chain
  • 15, 17 pinion sprocket (series 16/43)
  • Four aluminum rear sprockets – 41, 42, 44, 45
  • 2D racing data logger including analysis software
  • HP Race Calibration Kit
  • 2D dashboard from the WSBK / MotoGP
  • WSBK complete titanium exhaust system (AGA) (Akrapovic)
  • Titanium precision casting flange on the AGA (1.1 lb lighter than WSBK flange)
2018 BMW HP4 Race Priced at $78,000 US appeared first on Motorcycle.com News.
Click here for full story...
[motorcycledaily.com] - BMW HP4 RACE: Does an $87,000 Limited Edition Sportbike Still Ninjette Newsbot Motorcycling News 0 April 20th, 2017 06:00 PM
[motorcycle.com] - BMW HP4 RACE Revealed in All its Carbon Fiber Glory Ninjette Newsbot Motorcycling News 0 April 19th, 2017 01:20 PM
[motorcycle.com] - 2018 BMW HP4 RACE Preview Ninjette Newsbot Motorcycling News 0 November 10th, 2016 01:40 PM
[motorcyclenews.com - news] - Video: BMW HP4 'Road' & BMW HP4 'Superstock' ridden at Ninjette Newsbot Motorcycling News 0 July 17th, 2013 09:30 AM
[motorcyclenews.com - news] - Video: BMW HP4 'Road' & BMW HP4 'Superstock' ridden at Ninjette Newsbot Motorcycling News 0 July 17th, 2013 02:51 AM
