Old October 11th, 2017, 02:33 PM   #1
LR44
LR44's Avatar
Motorcycle(s): 2003 Ninja 250R
Weird Oil Leak
A couple weeks ago, I finished a rebuild of my swing arm and installed a new rear tire. During the rebuild, the bike was resting on the oil screen cover bolts with the rear end supported by jacks (one for each kickstand).
I come outside a couple days after I finished all of the above and there's an oil spot underneath my bike. Not pleased. I first look underneath the bike to see if resting it on the oil screen cover loosened the screws. I check with a torque wrench and they're all gravy. No leakage around the seam of the cover. I also checked the drain screw and the oil filter screw just in case. Both are fine with no leakage.
I was due to install a new sprocket anyway so I pulled the sprocket cover and cleaned the area with a work towel. I see oil on the towel, so I wipe the area down thoroughly and within about a half hour after installing the sprocket, I notice a trail of oil appear. The oil appears to be pooling under the starter motor (see the attached photo - the red arrow is where the trail of oil appeared). Again, not pleased.
A look at Ron Ayers suggests to me that this is due to a bad starter motor gasket, but I haven't started the bike in a couple months. Am I correct or could this be something else?
LR44 is offline   Reply With Quote
Old October 11th, 2017, 02:43 PM   #2
LR44
LR44's Avatar
Weird Oil Leak
Old October 11th, 2017, 06:31 PM   #3
LR44
LR44's Avatar
Weird Oil Leak
So I walked outside yesterday and found a oil spot underneath my bike. I checked the usual suspects: the drain bolt, the oil filter bolt and the oil screen cover bolts. All of them were properly torqued to spec and no leakage was found around these areas.
After taking a closer look, the oil looked like it was dripping from somewhere behind the sprocket cover. Seeing as I had to install a new sprocket anyway, I took off the cover and cleaned up the gunk with work towels. Some of the gunk was laced with oil, so I knew the leak was in that area. After installing the new sprocket, I waited about a half hour to see if I could trace where the oil was coming from. Sure enough, I saw a streak of oil develop from beneath my starter motor (indicated by the red arrow in the attached picture).
I took a towel and forced it into the gap between the engine and the starter motor and found a substantial amount of oil had pooled there. Diagrams on Ron Ayers would suggest the issue is a bad starter motor gasket, but could this be something else? I haven't run the bike in a couple months so I suspect the onset of cold temperatures at night is why this issue is rearing its head, but what do I know.
Old October 11th, 2017, 06:43 PM   #4
LR44
LR44's Avatar
Oil Leak - Help
Old October 13th, 2017, 08:34 AM   #5
LR44
LR44's Avatar
Oil Leak - Help
I walked outside a week ago and found an sizable oil spot under my bike. I haven't started it in a couple months as its still a work in progress. I checked the usual suspects: the drain bolt, the oil filter bolt and the oil screen cover bolts. All of them were properly torqued and there was no leakage around the seams.
After a lot of frustration and searching, I determined that somehow oil was pooling underneath my starter motor and was dripping down behind my sprocket cover (see red arrow in attached image). Before I go the whole nine yards and pull the starter motor, has anyone experienced this issue before? I thought it may be a worn starter motor gasket but what do I know.
Old October 13th, 2017, 01:17 PM   #6
Ram Jet
Ram Jet's Avatar
Any oil directly under your counter shaft sprocket? Maybe a counter shaft seal?
Bill
Old October 13th, 2017, 01:31 PM   #7
Pull the starter and check the O-ring. If it's flattened, replace it with new one so it's rounded. I've reinforced with some RTV as well.
Old October 16th, 2017, 12:36 AM   #8
All threads merged. Brian - it looks like some of these got caught in the spam prevention process. They go into a queue to be approved, but are not deleted. Apologies for taking this long to get to them.
Old October 18th, 2017, 08:37 PM   #9
LR44
LR44's Avatar
Thanks Alex - my apologies for submitting so many posts. I'm a newbie and didn't realize that was something that might happen.
Lesson learned!
Still got this oil leak!! xXecuterXx2 1986 - 2007 Ninja 250R Tech Talk 11 August 11th, 2015 11:56 PM
Oil leak.... skilletmo 2008 - 2012 Ninja 250R Tech Talk 13 October 24th, 2014 09:31 PM
Oil leak Xaero 1986 - 2007 Ninja 250R Tech Talk 11 November 16th, 2013 06:58 PM
possible oil leak? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 17 August 21st, 2012 01:35 PM
Oil Leak Help sjc88 1986 - 2007 Ninja 250R Tech Talk 7 December 29th, 2011 04:13 PM
