Old November 9th, 2017, 02:20 PM   #1
JEFFJ
Sammycycle
JEFFJ's Avatar
Motorcycle(s): Ninja 250r, 440ltd, suzuki gr650
Radiator MOD
Hello,
Has anyone seen this radiator MOD before? isn't the radiator supposed to be in the front?
JEFFJ is offline   Reply With Quote
Old November 9th, 2017, 02:46 PM   #2
Hmmm, that's not allowed in my racing orgs due to not being able to catch all leaking coolant into belly-pan.
I suspect it won't work as well since airflow won't be as much as in front. And air that does make it through will be hotter. Will most likely result in roasted-nuts syndrome...
Old November 9th, 2017, 03:35 PM   #3
taz
taz's Avatar
MOTM - May '17
yea vary bad idea, move it back to the front
Old November 9th, 2017, 03:46 PM   #4
Before you panic, watch your coolant temperature gauge for a while and see what you learn. Stock 250s have way more cooling than they need, at least in NC in the hottest part of summer. Liquid cooled engines don't have a lot of fins for heat transfer, so they don't heat the air going past them as much as air cooled engines do. The only concern I'd have would be the speed of the air flowing through the radiator.
An advantage of having it in the rear location is protection from rocks and other debris.
Old November 9th, 2017, 05:05 PM   #5
Snake
Snake's Avatar
That location should be fine as long as the electric fan is still on the radiator.
Old November 9th, 2017, 05:51 PM   #6
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Motorcycle(s): 06 Ninja 636, 2016 Yamaha R3 (Street/Track), 2019 Ninja 400 Project Racebike
Looks interesting, but again as is prominently pointed out, may adversely affect cooling. What's filtering the air for the carbs?
Racer, Mechanic, Enthusiast. Vendor for Norton Motorsports
Subscribe to my Instagram and YouTube: Instagram
YouTube
NinjaBraap is offline   Reply With Quote
Old November 9th, 2017, 06:41 PM   #7
Good question, Tom. You sure don't want to run very long without at least some Uni filters.
Old November 9th, 2017, 06:52 PM   #8
Ram Jet
Ram Jet's Avatar
Originally Posted by JEFFJ View Post
Hello,
Attachment 44020
Now I can say I've seen everything. What's next, front wheel drive?
Bill
Old November 9th, 2017, 11:29 PM   #9
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
There are front wheel drive motorcycles, and also all wheel drive, albeit either expensive, concepts, prototypes, or all of the above.
YouTube
Old November 9th, 2017, 11:30 PM   #10
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
There's even a motorcycle that turns into a jetski.
YouTube
Old November 10th, 2017, 12:27 AM   #11
Ram Jet
Ram Jet's Avatar
The best thing about those motorcycles is that they aren't mine.
Bill
Old November 12th, 2017, 12:22 PM   #12
JEFFJ
Sammycycle
JEFFJ's Avatar
Carbs have pods, just not installed when I took pic. I think I will leave it and see how it goes. Thanks for the input!
To mod or not to mod, that is the question... RiderOnTheStorm General Motorcycling Discussion 19 October 29th, 2012 08:21 PM
I'm going to mod....! RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 6 October 6th, 2012 03:34 PM
Red Hot Glowing Radiator Supports/Radiator Top bluebr65 2008 - 2012 Ninja 250R Tech Talk 10 March 10th, 2012 10:05 AM
First mod. HMB-ninja 2008 - 2012 Ninja 250R Farkles 10 September 28th, 2009 09:54 AM
First to do this new mod. headshrink General Motorcycling Discussion 14 August 17th, 2009 06:12 PM
