#1 |
slight choke cable issue
ok so i had another thread where you guys have been helping me try to diagnose a dying issue that i'm having with the wifes ninja. well i'm starting to rip it apart today to get the carbs out and go through them.
i did notice yesterday though that if the bike is on the side stand, bars FULLY turned left, and the choke applied to a set RPM (lets say 3,000), and then i grab the bars and turn them center/right, then the RPM goes down. if i turn it fully left again, the RPM goes up again. obviously the cable is location is being quite heavily moved for it to change like that, but i don't think it should do that. I was wondering if some of you guys can tell me how/where you have your choke cables routed that you know you don't have issues with. when i pulled the tank off the bike, i noticed that the cable was actually routed over the left gas tank mount between the tank and the frame. thanks.
Been there, Wrecked that. |
#2 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
![]() Remember when sex was safe and motorcycles were dangerous? |
#3 |
yes, that's a sign of a misrouted/binding cable. also, check your throttle cables to make sure they are properly routed.
#4 | |
![]() ![]() ![]() any other way somebody can show me the routing, or am i gonna have to go find my old office disks in the attic??? ![]() ![]() ![]()
#5 |
do you have a service manual? it's in there.
#6 |
i thought i seen it somewhere, but i couldn't for the life of me remember where i had seen it. LOL thanks. don't you hate when you read and study so much that you can't remember where you found the info???
#7 |
that's the whole key to knowledge... you don't have to remember everything, you just need now where to find it when you need it. Now, that's a trick.
Now a Choke Issue | rasta | 2008 - 2012 Ninja 250R Tech Talk | 7 | March 12th, 2014 04:32 PM |
Just noticed a slight issue with my tail light, need some advice. | beta7 | 2008 - 2012 Ninja 250R Tech Talk | 7 | July 9th, 2013 06:43 PM |
Choke cable relocate | pjed | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 21st, 2012 04:39 PM |
Choke issue | novafallen | 1986 - 2007 Ninja 250R Tech Talk | 9 | September 21st, 2010 02:22 PM |
