Old August 14th, 2020, 02:32 PM   #1
aquavisiondc
Motorcycle(s): none
Rear Brake Won't Bleed
Im in the process of installing new break pads for my 2012 ninja 250r. Im dojng the rear brake and im at the point where ive already replace the pads and got it mounted back on. Im trying to bleed the brake again but it just wont go. the brake stays soft and i dont feel any tension. The reservoir isnt moving at all. Some one help ASAP please.
aquavisiondc is offline   Reply With Quote
Old August 14th, 2020, 05:48 PM   #2
Hi Bobby and welcome to Ninjette!
Hmmm, how far do you have bleeder unscrewed? Do you get any fluid out of it with bleeder-screw completely removed?
Old August 14th, 2020, 07:27 PM   #3
Sounds like its possibly airbound? Try bleeding the brake hose attaching bolt (at the master) until fluid runs. Then go back to the caliper, may take some repeated efforts till the system displaces air with fluid and responds.
Alternately, if airbound, injecting fluid *into* the bleeder offers an alternative method.
Old August 14th, 2020, 11:43 PM   #4
Also vacuum sucking from bleeder is another way. Much easier than open-pump-close-release-repeat method!
Old August 15th, 2020, 05:19 AM   #5
provided he's equipped to do so
Old August 16th, 2020, 06:32 AM   #6
well? resolved OP?
Old August 17th, 2020, 11:16 PM   #7
I suspect there may be an embarrassing “oops” component here...
Old August 18th, 2020, 04:47 AM   #8
"Some one help ASAP please." And so we did.
@DannoXYZ....oops very possible, or simply a "grab and run"?
OP.....Posting/offering feedback is important to Ninjette forum reference resources in benefiting future members.
So, one mo' time....wha' happened?
At wits end trying to bleed front brake after new line install daverdfw 2008 - 2012 Ninja 250R Tech Talk 25 March 3rd, 2016 09:55 PM
Rear Brake Lever Travel is Excessive and Rear Brake won't Lock Tire. N-m 1986 - 2007 Ninja 250R Tech Talk 14 July 17th, 2014 04:13 AM
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 08:13 PM
tube for brake bleed headshrink 2008 - 2012 Ninja 250R Tech Talk 10 June 26th, 2009 08:17 AM
