Old September 6th, 2020, 09:57 PM   #1
Kingmo25
Motorcycle(s): Ninja 250 r 2011
Exclamation NINJA 250r DEAD HELP ASAP A
Hey so I changed my spark plugs and my ninja 250 ran real good. So I decided to elavate that performance with some love and care by cleaning it’s guts with sea foam. Then it started BOGGING so I was like okay there’s something stuck in the carbs and followed pwn Jones https://youtu.be/ENc8Ssmjyt4 —- and it now doesn’t even start. Can some send me the hose wiring in the carbs and gas tank because I cleaned the hoses but now I don’t know which ones go where. As in from gas tank in particular. I live in PICKERING Canada so the California ones aren’t helpful.
File Type: jpg A7B471F0-AAED-4F0B-9A06-448DFF1C40A6.jpg (92.9 KB, 2 views)
File Type: jpg 186E189D-7671-4636-B771-668C18EEFB6A.jpg (127.7 KB, 2 views)
File Type: jpg EB529C94-C382-47CF-8F4E-A124659E25F5.jpg (171.0 KB, 1 views)
File Type: jpg 1F4B9BD3-5612-45AA-B69D-3F8B1CD3FA67.jpg (194.9 KB, 1 views)
File Type: jpg F149A601-533A-4FE5-AD14-9157E061F1DD.jpg (206.8 KB, 1 views)
File Type: jpg 4FA20C45-1DB2-4DF3-8C42-C40438379547.jpg (183.6 KB, 1 views)
File Type: jpg 9A6F2FB7-43E0-4F95-8634-B6F0E38A1D7B.jpg (162.2 KB, 1 views)
File Type: jpg 54F926B0-C70D-47AF-A5E4-336B8B313DA8.jpg (70.8 KB, 1 views)
File Type: jpg 291042DD-F44C-4A64-AA6A-E3091C1B2E30.jpg (195.4 KB, 1 views)
File Type: jpg 7776D272-77A3-448D-A210-CF472E720C95.jpg (145.6 KB, 1 views)
File Type: jpg A3B4F8AD-6F59-481E-BCC3-C1F76DB46921.jpg (79.9 KB, 1 views)
File Type: jpg 6BDA5684-C364-4855-A602-A3A0CE03FDBA.jpg (72.4 KB, 2 views)
File Type: jpg 4F0BFCE9-3785-4596-B651-E69EA8FAF541.jpg (70.8 KB, 1 views)
File Type: jpg AB9AB937-8F3F-4262-9ACF-EC553842D9B6.jpg (124.2 KB, 1 views)
File Type: jpg 3762AD6A-4706-43C5-AD5A-428741725F07.jpg (85.0 KB, 1 views)
File Type: mov trim.B209E390-67E6-48DB-8055-7454D38E6750.MOV (6.66 MB, 1 views)
File Type: mov trim.BF0E8E52-6049-4266-B569-B0856504E50F.MOV (50.24 MB, 0 views)
Last futzed with by Kingmo25; September 6th, 2020 at 10:12 PM. Reason: More pics for good input I need this to work man
Kingmo25 is offline   Reply With Quote
Old September 7th, 2020, 12:53 PM   #2
Hi Mohammed and welcome to Ninjette!
Hmmm, I think this is a case of leaving good-enough alone. Bike is very well optimised from factory and is super reliable when maintained. Just need to fill it with petrol, chain oiled occasionally, engine-oil changed once a year, valves checked every couple years and it should run forever.
  • Was there any problems with it beforehand?
  • Did you have difficulty starting?
  • Does it die when you open throttle from idle?
  • How far did you disassemble carbs?
  • Did you split them into 2 separate carbs?
There's some diagrams of hose-routing somewhere, lemme see if I can dig them up...
Old September 7th, 2020, 02:00 PM   #3
Kingmo25
Yea the main problem was it was misfiring a bit.
I just followed the video above.
No splitting
Last futzed with by Kingmo25; September 7th, 2020 at 02:02 PM. Reason: Full answer
Old September 7th, 2020, 06:44 PM   #4
Try this guide: https://www.ninjette.org/forums/showthread.php?t=307413
1. Note that you don't have California model, there is no T in vacuum-line going to coast-enricher. It should be just one continuous hose.
2. Second vacuum line goes directly to petcock vacuum-inlet
3. vent hose from tank goes down next to shock aimed at ground
4. vent hose from centre of carbs goes back between air-box runners down next to shock aimed at ground
For misfire, you may want to try fuel-system cleaner with strong dose of PEA. More than just jets needs to be cleaned. All internal hidden/secret passages between jets and carb-venturi needs to be cleaned. Basically need to mechanically scrub entire flow-path of petrol from tank to intake-valves.
- Red Line SI-1
- Techron Concentrate Plus
- Gumout All-in-One
- 3M Max Strength Fuel System Cleaner #08814
- Royal Purple Max Atomizer 18000
For real carb-cleaning, you need lots more equipment and lots more elbow-grease:
https://www.ninjette.org/forums/show...7&postcount=11
Last futzed with by DannoXYZ; September 7th, 2020 at 10:13 PM.
Old September 8th, 2020, 08:51 AM   #5
Kingmo25
- Red Line SI-1
- Gumout All-in-One
I followed your instructions still nothing.
Old September 8th, 2020, 10:17 AM   #6
If hoses are correct, then something else is wrong.
First, test for air-flow/compression:
- put plugs back in
- place tissue-paper over end of muffler
- crank engine
Does tissue-paper get blown off muffler?
Does air coming out of muffler smell like petrol?
Second, manually test petcock flow:
- disconnect fuel-hose from carbs and aim into measuring cupo
- apply vacuum to petcock vacuum line.
- time flow for 30-seconds (use stopwatch)
how many CCs of petrol did you collect in 30 seconds?
Third, test for spark:
- remove plugs from engine
- insert into plug-wires
- lay plugs on top of engine so case of plugs are grounded
- crank engine.
What colour spark do you get?
Old September 8th, 2020, 05:32 PM   #7
VaFish
VaFish's Avatar
MOTM - Jan '16
All I have to say is that video is a terrible way to clean a carb.
Pull them out and clean them right.
WTB ASAP : 08+ Ninja 250 Clutch Cover Rod abhijitz Items Wanted 0 June 11th, 2013 11:48 AM
WTB ASAP : 2010+ Ninja 250 Motor or Bottom End abhijitz Motorcycle-related 0 June 7th, 2013 10:03 AM
WTB : *ASAP* 08+ Ninja 250 Front Wheel abhijitz Items Wanted 0 March 9th, 2012 09:12 AM
08 Ninja 250r clutch cable? Needed Asap... razorgamez Items Wanted 4 December 1st, 2011 08:02 AM
2009 Ninja 250: Going to Iraq, Must Sell ASAP! (Michigan) Brently7785 Motorcycle-related 19 August 10th, 2010 04:26 PM
