Old August 10th, 2013, 05:44 PM   #1
brenthedtke83
brenthedtke83's Avatar
Motorcycle(s): 07 ninja 250r
Repaint to white with blue accents
Has anyone had a lot of success with painting their bike white with any accents? I am going to strip and sand mine down, and paint it all white with the pegs, handles, levers, windscreen, and a few other pieces in blue, then paint the mufflers black (to cover a few scrapes) to look like newer model stock mufflers. Any thoughts?
brenthedtke83 is offline   Reply With Quote
Old August 10th, 2013, 05:54 PM   #2
Joshorilla
Bass Master General
Joshorilla's Avatar
It will look terribly gay
Old August 11th, 2013, 08:38 PM   #3
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
wow... i guess ignore him.
i have painted my ninja a few times, white will work fine just make sure you let each coat dry so you can see how white it is. you will need at least 2-3 coats, my ninja is gunmetal with kawi green accents. i have some pics in my profile and if you want i can take some new ones with my equipment painted kawi green.
if you start to paint things blue as an accent color i would recommend some blue vinyls, they really set things off. if you want to do what i did start with the vinyls then paint things piece by piece so you can make sure they look right.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old August 12th, 2013, 12:31 AM   #4
brenthedtke83
yeah, that would be great, I'd love to see some more pictures. Thanks, man!
Old August 12th, 2013, 12:52 AM   #5
Dark
Simple kind of man
Dark's Avatar
Motorcycle(s): 2013 Ninja 300
What are you using to paint the parts? If you're planning to use spray paint then just stop where you are, the quality in the paint along is not worth the time/effort it will take.
Any heavily used parts should be powdercoated if you want then to last longer than a single ride. Painting the pegs is a non-starter. If you have to powder coat one blue part then you might as well do all other parts (that can be PC'd) to keep the color uniform.
I'm with Joshorilla IF you use any lighter shade of blue, if you stick with a nice deep blue and keep it subtle (no need to coat every metal knick-knack on the bike) then you should end up with a clean look.
Dark is offline   Reply With Quote
Old August 12th, 2013, 03:46 PM   #6
darrell85
darrell85
darrell85's Avatar
Motorcycle(s): 2001 250 ninja
dont worry about what anyone else thinks of your bike, its yours not theres! Hes right about painting levers, rearset etc. I think zero gravity makes a blue tinted double bubble windscreen, and I seen someone on here found some cheap blue rearsets on ebay. If done right It should look good. Post up pics when you start.
darrell85 is offline   Reply With Quote
Old August 12th, 2013, 10:05 PM   #7
Dark
Simple kind of man
Dark's Avatar
Until you want to sell it. Lol
Old August 13th, 2013, 05:15 PM   #8
brenthedtke83
Well, I've repainted the mufflers with black heat resistant paint, and taped off the heat shield and the very end trim by the muffler end. It looks SO much better than it did before, especially with an updated look like the newer ninjas. Anyone else tried this? It's made a world of difference when covering up those rust spots.
Old August 13th, 2013, 09:30 PM   #9
7oxSin
MSF Coach!
7oxSin's Avatar
pic plz!
Old August 14th, 2013, 05:31 PM   #10
darrell85
darrell85
darrell85's Avatar
Old August 14th, 2013, 05:51 PM   #11
brenthedtke83
agreed, but when it stops raining, i should be able to get more on here...they're on the way, guys.
Old August 20th, 2013, 05:27 PM   #12
brenthedtke83
Here are a few pictures of the mods I've made so far. Included are:
new bar ends
removal of stock decals
addition of LED light strips on a rocker switch
installation of the stock chain guard, not installed when the bike was purchased
painted caliper
painted mufflers, to mimic the look of the newer 250 mufflers
to name a few...
it's rained for the last few days, so it needs to get cleaned up. but the mufflers turned out really neat and clean. The mirrors were added there because they did not fit in the sockets for the stock mirrors, and they have LED blinkers integrated as well.
DSC00149.jpg DSC00150.jpg DSC00151.jpg DSC00152.jpg DSC00153.jpg DSC00154.jpg DSC00155.jpg DSC00156.jpg DSC00157.jpg DSC00158.jpg
Old August 21st, 2013, 07:29 PM   #13
7oxSin
MSF Coach!
7oxSin's Avatar
nice, what are the mirrors mounted to? just drilled into the fairing?
Old August 21st, 2013, 07:45 PM   #14
fr1dayn1ght
fr1dayn1ght's Avatar
Motorcycle(s): '07 Ninja 250 (sold), 2013 CB500F
where did you get those LED strip? how did you install it me want
fr1dayn1ght is offline   Reply With Quote
Old August 22nd, 2013, 12:43 AM   #15
brenthedtke83
Yes, the fairings are mounted and drilled right to the body. The angle was a little difficult at first to get right, and the mirrors feel like I'm always adjusting. Also, with the knock off mirrors, you have to tighten the bolt every few trips, depending on how rough the road is and how fast you go. They do droop down from their position (not from being mounted, just the forward/back position on the angling bolt). But once they are tightened a few times they stick well. Just make sure you have them at an angle where the led flashers blink out, not down.
Old August 22nd, 2013, 12:46 AM   #16
brenthedtke83
The LED strips were from Newegg.com. I think they cost around $15 for a set of four strips, and they wire in to the accessory port with a rocker switch from O'Reilly Auto Parts. Pretty easy setup, just don't leave the switch on accidentally, as they do not shut off with the key. They are adhesive, altough I have them zip-stripped to the frame beneath the fairings, and the front ones are superglued to the fairing underneath the front end.
Old August 22nd, 2013, 06:41 AM   #17
7oxSin
MSF Coach!
7oxSin's Avatar
why not use some loctite on the bolts that way they wont work themselves loose again.
Old August 22nd, 2013, 09:14 AM   #18
fr1dayn1ght
would that drain the battery? how long can you leave the led on? Im thinking my bike might shut off in the middle of nowhere from the led strip
Old August 22nd, 2013, 02:02 PM   #19
brenthedtke83
Well, I've rode with them on for over an hour before, and never had a problem. The wires do need to be a bit more secure, though, because sometimes, especially on bumpy roads, the lights do blink a little bit, but come right back. Otherwise, it's good. Just make sure that you don't put these on a naked bike, because moisture can DEFINITELY affect the strips.
Old August 22nd, 2013, 06:59 PM   #20
fr1dayn1ght
how legal is that underglow? i thought blue and red were reserved for cops and we can only use white/amber
Old August 23rd, 2013, 12:46 AM   #21
brenthedtke83
Underglow is illegal period regardless of color, depending on your state it might differ. But most cops that I've talked to said they wouldn't even bother with it. If it's not blinking or on the tail directly, most won't even think twice. They might even admire it.
Old August 23rd, 2013, 05:25 AM   #22
7oxSin
MSF Coach!
7oxSin's Avatar
i have 255 LED's on my bike, and as long as you have the bike running while they are on there is no problem. ive also left em on for about 30 min with the bike off before w/o problems.
Old August 24th, 2013, 02:39 AM   #23
kslane
kslane's Avatar
Motorcycle(s): 2003 Ninja
where did you get those led strip? How did you install it :d me want
walmart sells the led strips and very easy to install
kslane is offline   Reply With Quote
Black and Blue or White and Gold? Ninjinsky General Motorcycling Discussion 9 March 2nd, 2015 05:26 AM
Does anyone have White LEDS in his/her blue 250? watsyurface 2008 - 2012 Ninja 250R Farkles 3 February 14th, 2013 01:04 PM
Pearl White Repaint Honko General Motorcycling Discussion 1 August 11th, 2011 03:39 PM
gold accents snowsoldier 2008 - 2012 Ninja 250R Farkles 2 April 13th, 2011 02:33 PM
Thinking of a repaint JeffM General Motorcycling Discussion 38 March 26th, 2010 08:21 AM
