May 28th, 2014, 10:22 PM | #1 |
Hit the crater today...
Had to help a friend hook up a radio antenna way up on the mountain today for a non-profit radio station. Buzzed up the mountain, did the heavy lifting, buzzed down the mountain, then turned around and went up/down again.
Chicken strips to 1/4" on the left and 1/2" on the right side rear.. about an inch in the fronts. I focused on body positioning and trying to be smooth on the bars but I didn't feel my knee touch down. Felt like I was really hanging off the bike, coming into most sweeping hairpins at about 40mph, very hard on the brakes, super high RPM, early apexing then a hard uphill drive out of each turn. I gotta say... the bike is just not there... the power is non existent. Feels like I'm careening into these turns at 13.5k, screaming out of the turns giving it all I've got on the throttle and the bike just doesn't pull out of the turns hard enough to give me the confidence to tuck harder off to the inside of the bike. Statistically speaking, you lose 3% of your power for every 1k feet above sea level. My riding was from about 6k feet to 10k feet. So that means I'm losing ~30% of my available horsepower and torque. A few turns I came out of at a steep lean angle and I got on the gas and just didn't have the power to maintain the angle and found myself standing the bike up rapidly because I felt it begin to 'fall away' under me into too tight of a lean. (The same feeling you get when you're buzzing along in a straight line and get hit with a strong gust and the bike just disappears from under you and all of a sudden you're leaning at a crazy angle just to maintain a straight line.) At the top of the hill my bike would barely idle. I turned up the idle to maintain 1500rpm, and by the time I rode down to 5k feet elevation and stopped, I was idling at 5000rpm. I hate to say it but I feel like I need more bike. I've modded the 250r to the absolute limits of it's potential, no more power will come from this machine. I REALLY felt like I was absolutely beating on it just to get to the top of the mountain. I came out of town and it was WFO for about 6 minutes in 6th gear. Literally WFO at 13krpm pushing a headwind barely maintaining 86mph for 6 minutes at a time. Am I going to blow this bike up or are they designed to handle this level of abuse? (I'm anal about maintenance, oil @ 2500, chain lube every 400, chain tension every 1000, but I'm literally asking all that this bike can give, 24/7.) Feels like she's gonna go "pop" and just seize all of a sudden. What should I do? /dear diary
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
May 28th, 2014, 10:35 PM | #2 |
Found a youtube vid of the road, it starts a few switchbacks above where I did, but climbs between about 6.5k feet elevation to 9.8k feet elevation by the time it reaches the 6:30 minute mark. Notice he's riding below the clouds, then up through them, then above them back into the sun. I never take the bike above where he did at 6:30... because the power is literally nonexistent and I'm backfiring massive amounts of unburned fuel on every shift due to the lack of oxygen in the air.
If anyone cares to sit through 6:30 minutes of the video, they'll see the road I'm talking about. https://www.youtube.com/watch?v=QyvMBCNgIow Oh and the guy was in a slow as$ miata, but still shows the road.
May 29th, 2014, 12:39 AM | #3 |
Join Date: Nov 2012 Motorcycle(s): '07 ex250-F/J Posts: A lot.
You might just need a different bike for higher elevations. That's a legit excuse to get a new bike right? lol
May 29th, 2014, 05:52 AM | #4 |
Old and slow
Join Date: May 2014 Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250 Posts: 889
My son spent the summer in Creede, CO 8800ft
Now I'm going to throw some numbers at you, hope it doesn't put you to sleep. 30% of of say 60 horse power is 18 horse power 30% of 140 (a nice used GSX-750R) is 42 horse. So while the % is the same, the numbers are not. you are down to just over 40 horse, while the gixxer is still tickling 100. Note I'm not hate'n on the 250, just saying it's light on the ponies to start out with and the Gix has a few extra in reserve. Be ready, things that you just assumed were the case for all bikes, not so much. The 250 is about as agile and responsive to your inputs as you are ever going to get. you tell the bike to lean, it does, you tell it to stop... it does. That narrow rear tire and even more narrow front tire that just lay over at the slightest bar inputs... not so much when you go 190/70ZR17 and 120/65ZR17. Double the weight of the bike. suddenly the little whisper, "over here sweetie, lets go over here"... turns into a forceful, "THIS WAY... OH NO YOU Di'nt" things don't just double when you double the horse power...they square, and sometimes cube... and the "get you butt into trouble" rate, that is 2.2 x 10E4 |
May 29th, 2014, 10:57 PM | #5 |
Good points, I agree.
I'm not totally comfortable hanging off the ninja yet, but when I nail a few sweepers smoothly and have a perfect weight transfer without feeling shaky, it feels like I'm ready for a bigger bike. Alas, I will wait until I put another 30k on the clock before upgrading. The main thing I'm concerned with is braking... can you really haul a literbike down from 100mph with the same ease? Using the motogp style of riding of course.. 'hold it WFO until you see god, then brake like a mofo and mutter prayers mixed with expletives as you hope your front wheel stays tight to the road." I hear you that more power = more problems. My main concern is getting myself into a new bracket of "trouble" with the law. If the bike only pulls 90mph, that's not doubling the speed limit. But if you're got the power to get her up to 100... 110.. That's loss of license for 6 months, mandatory 30 days in prison, massive fines... a whole new "bracket" of consequences. I have realized in my years that a key to living a happy life is spending enough time doing what you enjoy that you make palatable the un-enjoyable with an equally balanced "fun/not-fun" ratio. I love motorcycling.. it's just good old fashioned raw unadulterated fun. Kinda wish I didn't have HP-killing elevation to contend with, but that's life.
May 30th, 2014, 05:03 AM | #6 | |
If you regularly ride at high elevations it might not be a bad idea to have a little more displacement, but if you can't control the speed... |
May 30th, 2014, 06:36 AM | #7 |
Certified Slacker
Join Date: Apr 2014 Motorcycle(s): 2010 Kawasaki Ninja 250R SE Posts: 232
I keep thinking this is a pothole thread.
Ninja Bob |
May 30th, 2014, 07:41 AM | #8 |
Track Clown
MOTM - Sep '15
the only way to combat elevation changes is and electric bike.
May 30th, 2014, 08:00 AM | #9 |
Join Date: May 2014 Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F Posts: 588
A fuel injected motor doesn't have some of the issues of carbs at altitude, so if you want to stick with some thing safer in terms of your willpower, maybe just upgrade to the 300.
Or something a bit more practical, but without the crazy HP of a full out SS, like an SV-650, Ninja 650, CBR500...... My street bike is a CBR 600, and she can get ya in trouble real quick if you don't use the throttle and brakes judiciously (I can do almost 65 mph in first gear....). There's a reason I race, legally, on the track. It keeps me from getting too crazy on the streets, and gives both a good outlet, and more importantly, a place to practice the skills and get the feel of what real speed feels like. Looks like a fun road, though. |
May 30th, 2014, 08:10 AM | #10 |
Old and slow
well, #1, the rubber tube off the right handle bar... the more you twist that, the faster you go... the less you twist it, the slower... you... you are in control of the bike. there are times to go fast and times to back off. You need to use that thing between your ears before you twist it up.
Oh yes, the brakes on the 1000cc machines will haul them down from WOT. The ones on My TLR are 6 pot dual on 320 cm rotors. That's a lot of grab, it will squash the berries and twig pretty good on a panic stop. I commute to work every day, heavy Chicago area traffic... I keep it at or near the speed limit, don't get stupid... but (yeah everyone has a big stinky but) I know where I can blow off some steam, give her the spur and let it run... Coupla industrial parks, no kids, no traffic, good sight lines... I can neither confirm nor deny that the front tier comes off the ground *wink* Guess the point there is choose your moments, enjoy them, then ride in such a way as Jonny Law isn't going to get too up in your grill. so, that being said... time in the saddle (though very important) does not a good or accomplished rider make... As my dad would say, if you practice a mistake, you just get really good at making a mistake. SO, can i recommend a book, really REALLY good for anyone who likes the feel of the bike, the lean, the thrill but may need some insight into what is going on. Twist of the Wrist, by Keith Code Yes the same Kieth Code that started and runs California super bike school. it explains things that you do, but may not know why or how you do them, when you ride. It explains "the perception of speed" as opposed to just speed. Sometime, when you have a long stretch of open empty road... look all the way to the horizon, far out as you can see... how fast are you going? now look down at the road directly in front of your tire (as near the bike as you can)... now how fast are you going? Weird thing is that you are going the same speed both times, it just feels different. Now pick a point way out in front of you, a rock by the side of the road... look at that spot and let your eyes watch it all the way in... it will feel like you are going slow... then speeding up. Perception. there are many things in that book that will help you understand and then improve your riding skills. A bigger bike isn't necessarily a bad thing, bigger heavier bikes are very stable, planted, and predictable when set up properly. You shift your body position around on a big bike it doesn't upset the bike as much, little inputs to the bars make minor adjustments. It takes some work to push a tank around, trust me, i drive a tank. So if you feel the 250 is rung out and you are still looking for more... the 600 will bring that tingle back. The new ones are insanely light, they are in the range where performance tires are being made by most manufactures. You will easily double or even triple your horse power. just keep your wits about you, or they will be hauling your carcass out of a ravine, an the fun level on that is zero. |
May 30th, 2014, 11:47 AM | #11 | ||
Dude I am hungry as hell right now and if I had a pot to cook anything in, and something to cook in that pot, I would dig a hole and build a fire to cook said item in said pot but until then the only thing on my mind is eating something. Think that's a little too far out of my budget. An electric motorcycle seems like.... uh... such a let down. No roaring engine, no unburned deliciously smelling hydrocarbons, no exhaust, no fuel smell, no oil odor... just seems like blasphemy on some level. Quote:
Some new-ish tech would be nice, maybe a 2010 or newer... dang this is almost impossible to find.
May 30th, 2014, 11:58 AM | #12 | |
Hubby hit by a minivan today (he's OK, thanks to gear!) | bluepoof | !%@*#$%!)@#&!%@ I crashed! | 39 | May 30th, 2014 07:37 PM |
Hit the 1000 mile mark today then nearly went down | mapolley07 | General Motorcycling Discussion | 6 | December 10th, 2011 01:08 PM |
Hit a squirrel today... | THE BIG SITT | General Motorcycling Discussion | 19 | October 19th, 2011 10:39 AM |
Hit a coyote today... | aloh | Ride Reports | 14 | August 9th, 2010 03:44 PM |
Hit at 100 MPH today. | headshrink | General Motorcycling Discussion | 14 | November 3rd, 2009 08:38 PM |
