Old April 6th, 2011, 03:05 AM   #1
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
petcock fuel filter won't stay in?
Cleaning out the tank. removed petcock. Removed both filters to clean them. The filter for the main pickup slips over the end to stay in place. The filter for the reserve pickup fits into a recess. When I pulled the filter out of the reserve pickup all kinds of gunk and corrosion came out from the recess it sits in. Now that it's all clean, the filter fits very loose and I'm afraid it will just fall out... Is there supposed to be some kind of putty I use to get it to stay in place?
Last futzed with by CynicalC; April 6th, 2011 at 06:55 AM.
Old April 6th, 2011, 06:56 AM   #2
CynicalC
CynicalC's Avatar
Old April 6th, 2011, 03:10 PM   #3
I was just cleaning out the fuel petcock on a Kawasaki dirt bike that has pretty much that same arrangement for the filter screens. As far as I could tell, the filter screens are a press fit. I'm guessing you had so much corrosion that when you you cleaned out the petcock, you must have taken out enough of the corroded aluminum that there is not enough for a good press fit anymore. My solution was to purchase a used petcock in better condition. I had been thinking of just running an inline filter in the fuel line going to the carbs. That would work.
Old April 6th, 2011, 07:56 PM   #4
CynicalC
CynicalC's Avatar
Yeah I scraped a lot of crud out of there. I figured it was some kind of adhesive or something I'd have to reapply. I guess I'll just ditch those two filters and use one in-line.
Also, after cleaning the tank (letting 5 gallons of vinegar eat away at the rust), is it really necessary to seal the inside with por-15 or kreem? There were huge clumps of rust from sitting for so long but I think I got it all. Is the tank likely to rust again or should it be fine after it dries out?
Old April 6th, 2011, 08:00 PM   #5
to be sure, I'd recommend you try using something like this to insure all rust is removed.
http://www.ninjette.org/forums/showthread.php?t=65609
Old April 7th, 2011, 02:01 AM   #6
CynicalC
CynicalC's Avatar
Thanks. I just check and it looks like I got it all, or at least what I can see. Now the question is whether it'll rust again if I don't put fuel in it right away. I guess I'll give it a good douching and dry it with the heat gun stuck inside then seal it up good and hope for the best.
Petcock Filter Anyone? woodyshin 1986 - 2007 Ninja 250R Tech Talk 9 November 8th, 2021 05:52 AM
fuel petcock Sebastian f7 1986 - 2007 Ninja 250R Tech Talk 2 July 13th, 2013 02:54 AM
Fuel Petcock Issue ans008 2008 - 2012 Ninja 250R Tech Talk 6 June 7th, 2013 07:14 PM
LF: Petcock filter screens ('93 EX250) kg4kpg Items Wanted 0 October 11th, 2012 09:14 AM
Fuel Petcock Leaking FrankW 1986 - 2007 Ninja 250R Tech Talk 9 July 8th, 2012 04:19 PM
