March 29th, 2013, 01:50 PM | #1 |
Join Date: Mar 2013 Motorcycle(s): 05 Kawasaki Ninja 250R Posts: 37
Can I adjust the Speedo?
My Speedo seems to be showing me going slower than i actually am. Its there any way i can adjust it or should i take it to my local bike shop?
March 29th, 2013, 02:15 PM | #2 |
It is a mechanical gear driven instrument attached to the front wheel. No adjustments can be made to calibrate it. The speedo can be around 5-7 mph off. This is normal for many gear driven speedos. Electronic ones tend to be more accurate.
March 29th, 2013, 02:18 PM | #3 |
It is attached to the front wheel, and that range is exactly what its Off by dependin on the mph so no adjustments can be made? That sucks looks like I'll have to compensate then. Thanks for the speedy reply :-)
March 30th, 2013, 09:10 AM | #4 |
Join Date: Oct 2010 Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900 Posts: 80
You say it "seems" to be off. If you're not using a GPS then a good way to check your speedo is to get on I-75 and ride next to a late model Honda Civic.
You can see the digital MPH display on the dash quite clearly. It's big and bright. |
March 30th, 2013, 09:47 AM | #5 |
I just gps'd the bike on my phone and it's about 1mph off at 30mph.
Last futzed with by 05Ninjette89; March 30th, 2013 at 09:47 AM. Reason: spelling error |
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd | Klondike1020 | General Motorcycling Discussion | 8 | August 17th, 2014 12:23 AM |
My speedo is way out! | Damo990 | 2013 - 2017 Ninja 300 Tech Talk | 14 | March 5th, 2014 06:54 AM |
Speedo not working | LR1914 | 2008 - 2012 Ninja 250R Tech Talk | 5 | June 24th, 2013 01:01 PM |
Speedo Came Off! | komohana | 1986 - 2007 Ninja 250R Tech Talk | 8 | May 29th, 2011 01:55 PM |
My speedo is off??? | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 28th, 2010 03:24 PM |
