Old June 1st, 2013, 07:24 AM   #1
boomer187um
Motorcycle(s): 2012 250R CLG
Question air box drain cap
how is the drain cap removed? do i just pull it? is it threaded? i have no idea, and dont want to go just yanking on it, and breaking something
boomer187um is offline   Reply With Quote
Old June 1st, 2013, 07:35 AM   #2
mgentz
Board Member
It should just pull. Is yours just a vacuum cap? Is there a clamp?
Old June 1st, 2013, 07:53 AM   #3
boomer187um
no that i can dee, im not sure though, is a 2012 if that helps at all?
i'll try to get a good pic
Old June 1st, 2013, 09:18 AM   #4
boomer187um
here we go...
and if i do just pull it, wont all the oil in it spill all over my engine?
Old June 1st, 2013, 10:49 AM   #5
mgentz
Board Member
Pull it and yes it will so put a towel under it.
Old June 3rd, 2013, 04:58 AM   #6
boomer187um
ok thank you, i just wanted to be sure
Old June 3rd, 2013, 10:21 AM   #7
turbo101
Motorcycle(s): ninja 250r
its held on by a small clamp that you can get to with some small needle nose and yes put a paper towel under it before you pull it out or oil will get everywhere if theirs any in it.
turbo101 is offline   Reply With Quote
Old June 5th, 2013, 08:14 AM   #8
boomer187um
ok, so i emptied it lastnight, rode about 20 miles and ITS FULL AGAIN!! where is this oil coming from? it seems to be clean... is it excess from my air filter?
Old June 5th, 2013, 09:08 AM   #9
nick5446
Motorcycle(s): Too many
It's engine oil; you've probably got too much in there. That's where it overflows to.
nick5446 is offline   Reply With Quote
air box John D 1986 - 2007 Ninja 250R Tech Talk 10 September 4th, 2012 08:07 PM
Air Box removal cbinker Ninjettes At Speed 23 August 20th, 2012 11:46 PM
K&N air filter to stock air box Graugaard 2008 - 2012 Ninja 250R Tech Talk 29 July 28th, 2012 06:33 AM
Air Box Modification exploring/carolina 1986 - 2007 Ninja 250R Tech Talk 19 May 21st, 2012 06:30 PM
Air box removed, now.... cbowman78 2008 - 2012 Ninja 250R Tech Talk 6 December 15th, 2010 08:11 AM
