Old March 10th, 2014, 03:43 PM   #1
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Problem after front suspension change
So I just got done buttoning up the front of the bike. Did Springs and Emulators. Put everything back together and then set the forks 12mm above the triple. Problem is the front end is WAY too high off the ground now. Like the forks are too long. I mean it's so high that I can't even attach the speedo cable and my front stand that I have won't even lift it from the triple tree now.
WTF did I do?
Old March 10th, 2014, 04:02 PM   #2
Boosted139
Motorcycle(s): 2009 Ninja 250R SE, 2009 Triumph Daytona 675
When you did your springs did you cut your spacers to the proper height? Also, is your front suspension super stiff? Can you bounce the forks?
Boosted139 is offline   Reply With Quote
Old March 10th, 2014, 04:08 PM   #3
ForceofWill
I cut the spacers to make the new springs + spacers the same length as the stock springs + spacers.
I can compress the forks after I put them together on the ground, but it's pretty stiff on the bike.
Old March 10th, 2014, 04:10 PM   #4
ForceofWill
I also put the caps back on the forks while they were in my vice and were fully extended.
Old March 10th, 2014, 04:11 PM   #5
You may have a hydraulic lock if your level of oil is too high.
http://faq.ninja250.org/wiki/How_do_...he_fork_oil%3F
http://faq.ninja250.org/wiki/Removin...stalling_forks
Otherwise, reduce the length of the spacers.
That is what Keith Code is doing when adjusting the pre-load of the springs in this video; only that your bike has not an easy regulation: test and cut, test and cut, test and cut.
Your springs should compress certain sag under the weight of the bike+rider.
Old March 10th, 2014, 04:14 PM   #6
Boosted139
What he said ^^^
Sounds like spacers are too big
Old March 10th, 2014, 04:15 PM   #7
ForceofWill
Alrighty, back to more trial and error hah.
Old March 10th, 2014, 04:15 PM   #8
misfitsailor
Ninjette Jockey
misfitsailor's Avatar
Motorcycle(s): Ninja 250R, Harley Davidson Heritage Softail, 2 Honda Monkeys, Polini & GRC mini GP
I had forks that would not compress once. Turned out that the shop had overfilled them during "service".
For what shall it profit a man, if he shall gain the whole world, and lose his own soul?.
misfitsailor is offline   Reply With Quote
Old March 10th, 2014, 04:16 PM   #9
Boosted139
Shouldn't be trial and error. It's math. Kind of.
Old March 10th, 2014, 04:17 PM   #10
Boosted139
Also did you drill the dampening rods?
Old March 10th, 2014, 04:18 PM   #11
ForceofWill
Ya, they have 6 holes in them each like it said to. I'm at 130mm of oil. Should I go less oil?
Old March 10th, 2014, 04:18 PM   #12
Please, re-read my above post; I just edited it and added two links.
Old March 10th, 2014, 04:22 PM   #13
ForceofWill
Ya, I was using all the DIYs from ninja250.org. Gonna try the suggestions out and see where it lands me.
Old March 10th, 2014, 04:42 PM   #14
ForceofWill
What he said ^^^
I just realized that I didn't take into account the Emulators when I did the spacer. So they're most likely way too long.
Gonna do some math and cut them now.
Old March 10th, 2014, 06:04 PM   #15
simook
I was just going to ask if you took into account the emulators and washers.
- OMRRA Racer #83 -
-- OMRRA Media Group Editor/Producer --
simook is offline   Reply With Quote
Old March 10th, 2014, 06:17 PM   #16
ForceofWill
So I cut the spacers down and there's no preload now. They're barely touching the bottom of cap after installed. Still the same crap. Its like the forks are too long or something. I can compress them both fully and they feel smooth.
Does anyone know how high the front should be stock? The forks stock were extremely soft, like I could just hold the front end to the ground before. And when I took them out and drained them there was hardly any oil in them both. So maybe what I think is stock height is actually really low?
I'm calling it for a night, pissing me off.
Old March 10th, 2014, 06:18 PM   #17
dino74
dino74's Avatar
If you can't connect the speedo cable then its not the spacers or oil height. If the forks are fully extended, the speedo cable should still reach.
The only way I could imagine this happening would be if you didn't put the damper rod through the upper fork. That is the upper fork is hitting the top of the damper rod.
CVMA #55
Old March 10th, 2014, 06:21 PM   #18
ForceofWill
Omfg you have to be kidding me lol. I bolted the damper rod in and then put the upper fork over it. Hahaha Jesus I'm a retard.
This is why you need to do one mod at a time. I took the front apart then moved on and did the whole rear. By the time i started the front again the next day I totally gapped it.
Old March 11th, 2014, 01:46 PM   #19
ForceofWill
Just so everyone can see how much an idiot I am and so no one else does it. This is what the difference between putting the damper rod under or over the top fork does.
Thanks again Dino, lol.
Old March 11th, 2014, 04:53 PM   #20
.........This is what the difference between putting the damper rod under or over the top fork does.......
Old March 19th, 2014, 10:04 AM   #21
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
@ForceofWill how much fork oil did you end up putting in?
Old March 19th, 2014, 02:06 PM   #22
ForceofWill
I ended up going with 130mm 15wt. That's what racetech recommended with the GVE.
Just did oil change - problem caineroad 2008 - 2012 Ninja 250R Tech Talk 14 September 24th, 2013 02:41 PM
[motorcyclistonline] - Oil-Change Intervals For Your Suspension? | Street Savvy Ninjette Newsbot Motorcycling News 0 September 12th, 2012 11:10 PM
Will raising my suspension with shorter dogbones change my chain length requirement? CZroe 2008 - 2012 Ninja 250R Tech Talk 7 June 16th, 2012 02:53 PM
Rough ride....possible suspension problem? JCCJMM_ 1986 - 2007 Ninja 250R Tech Talk 7 November 16th, 2011 01:30 PM
Brake or suspension Problem?? BobsPT 1986 - 2007 Ninja 250R Tech Talk 33 September 6th, 2011 11:49 AM
