Old May 9th, 2017, 02:59 PM   #1
Unicyclone
Motorcycle(s): '03 Ninja 250, '02 KLR 650
Clutch plate gap
Hello all,
I'm a new '02 ninja 250 owner, but have had a KLR for a couple years now.
Question is, what should the space be between the tabs on the edge of the friction plates, when it's all assembled? I measure 2.4 something mm.
The manual has spec for the friction plate thickness, but I can't measure that without disassembling it.
I have adjusted the cable, and it still slips a bit.
Assuming the clutch sounds like it's bad, what's my cheapest still decent bet for plates and springs?
Thanks!
Unicyclone is offline   Reply With Quote
Old June 7th, 2017, 09:46 PM   #2
/moved to pre-gen tech area
Old June 8th, 2017, 12:37 AM   #3
Ghostt
Ghostt's Avatar
Originally Posted by Unicyclone View Post
Hello all,
Thanks!
Okay first off I'm assuming your using the proper oil for a wet clutch?
Second the clutch on these bikes is pretty much bulletproof, the weak link is the springs, which are crap at best friend on Kawasaki, reason is they made them soft due to the Ninjette is an entry level bike.
Here my write-up on the subject
Upgrading to performance clutch springs by Ghostt
IMHO, The OEM clutch springs are soft/weak, and there's only 4 of them unlike bigger bikes like the Zx600, due to this is a beginner's bike according to Kawasaki, to make it easier for beginners male and female. This leads to slippage in certain cases, especially at high RPMs
This is an easy fix, replace with aftermarket performance springs.
Choosing Clutch Springs
Barnett aftermarket clutch springs for a 1985-1989 ZX-600, Part # 501-50-05055. You can view them online at the Barnett catalog, here: http://www.barnettclutches.com/produ...&clutch_cc=600 They can be ordered through your local dealership, or at a number of online sources. Here is one such online catalog: http://www.exoticsportbike.com/6001.htm
Another option is the EBC CSK10 (see http://www.ebcbrakes.com/motorcycle_..._springs.shtml). This kit isn't quite as stiff as the Barnett, but is better than stock and usually a little cheaper. The kit does include six springs, while the ninja 250 only uses four.
I have done this to both my Ninja 250 & EX 500
Final verdict:
The clutch pull is a little bit more stiff, but nothing to worry about. The shifts have more of a crisp and positive feel, and eliminating slippage is always a good thing when it comes to the clutch.
It's my personal opinion that this is a must do item, as it saves the clutch itself, and eliminates a possible problem especially when the springs get older.
violente et ignorantia
ZX-2R BLOG
Last futzed with by Ghostt; June 8th, 2017 at 01:54 AM.
Old June 8th, 2017, 03:53 AM   #4
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
What I've done on a couple of mine is to put a washer under each of the factory spring retainers (4) to preload the springs. I never did find a washer the right inside and outside dimensions, so I found one that was right on the outside and made the hole right with a die grinder. The ones I used are 1.5 mm thick, 20 mm outside, and about (?) 12 mm inside. I know....doesn't sound like much preload, but it's worked on the 3 Ninjettes I've put them in.
Old June 8th, 2017, 11:39 AM   #5
Ghostt
Ghostt's Avatar
Pre-load doesn't increase the spring weight itself, your still dealing with a spring which does a minimal job.
I highly recommend doing the spring upgrade, you won't be sorry you did, and you'll have happy with the results I'm sure.
ZX-2R BLOG
Old June 15th, 2017, 04:37 PM   #6
Unicyclone
Sorry I posted in the wrong spot.
Thanks for the replies!
When I posted, I had lubed the clutch cable, but not replaced it.
I put a fresh cable in, and rode it 4000 miles with no issues. I did carry backup gasket/springs/friction plates for peace of mind though​.
Old June 16th, 2017, 09:37 AM   #7
Ram Jet
Ram Jet's Avatar
Barnett
Final verdict:
I put Barnett clutch springs on my 82' Honda FT500. They were too stiff. I removed them after a two mile ride and gave them away.
Bill
Old June 16th, 2017, 09:53 AM   #8
Ram Jet
Ram Jet's Avatar
pre-load
I've been reading about fork spring pre-load spacers here and on other forums. One guy says 1 1/2" spacers work for him. The only thing I've done to my forks is replaced the fork oil with 15w and installed real snap rings in the fork caps. I weigh 180lbs and wouldn't touch the springs or adjust the preload. Maybe it's beacuse I'm an old fart and don't ride too aggressively, or, maybe that's why I have lived for 69 years. Just sayin'.
Bill
Old June 16th, 2017, 05:14 PM   #9
Ghostt
Ghostt's Avatar
Setting up suspension is to one's personal taste, and how they ride, setting the sag is important, like spring weight, oil, etc....
I set mine up for what I like, I cut and spaced out my OEM springs, 15 wt oil, and a Zx6 rear shock.
Adding pre-load to a spring doesn't increase its weight, it effect sag, ride, etc....
ZX-2R BLOG
Old June 16th, 2017, 10:26 PM   #10
Ram Jet
Ram Jet's Avatar
I get about 1 1/2" sag on my EX500 rear shock and nearly no sag on my stock front forks. Right, it's a mater of taste/preference. I'm of the Colon Chapman/Lotus school of suspensions - "light springing and heavy damping". Works for me.
Bill
2007 ZX6R Clutch Spring Plate/Clutch Spring Direction? KnuckleBuster General Motorcycling Discussion 2 August 24th, 2015 03:21 AM
Clutch :: Friction Plate & Metal Plate Install and Wear Questions abhijitz 2008 - 2012 Ninja 250R Tech Talk 12 June 21st, 2013 10:45 AM
clutch pressure plate torque kristie93 2008 - 2012 Ninja 250R Tech Talk 1 June 20th, 2013 07:39 PM
Helping a friend with a clutch plate problem! skilletmo 2008 - 2012 Ninja 250R Tech Talk 109 April 28th, 2013 06:09 PM
WTB: Old/Used clutch plate! leed Items Wanted 0 September 2nd, 2012 11:24 AM
