November 5th, 2010, 04:39 PM | #1 |
Problems with manometer
I have one of those Motion Pro manometers for syncing my carbs. It is a very nice tool to have.... but today I am very frustrated with it. For some reason a bunch of air got into the tubes, and I can't get solid columns of fluid to calibrate the manometer, or sync my carbs. Grrrrr!
Does anyone know how to fix this?
November 6th, 2010, 07:14 AM | #2 |
I would try replacing the fluid.
November 6th, 2010, 02:35 PM | #3 |
I was hoping I wouldn't have to do that.... but it is on order.
November 6th, 2010, 02:57 PM | #4 |
At first I thought you were having trouble proving your manliness .
In the DIY on carb-syncing, he describes the fluid as bubbly, so perhaps that is normal? It seems like under some vacuum, most liquids would be bound to cavitate at least a little. If it is still doing what you want, I wouldn't worry about it. http://www.ninjette.org/forums/showthread.php?t=9754
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
November 6th, 2010, 05:04 PM | #5 |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R Candy Plasma Blue Posts: 129
You should not need to replace the fluid. Just pour it out into a container and slowly refill the tubes.
November 6th, 2010, 06:11 PM | #6 |
My fluid levels were always uneven, thus the adjustment screws were at opposite extremes. It will be nice getting it "reset."
I think I got a wee bit of condensation in the tubes too... that certainly didn't help the bubbles.
Carb problems? | radioflyer | 1986 - 2007 Ninja 250R Tech Talk | 22 | July 9th, 2013 04:57 PM |
Electrical problems | chef | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 22nd, 2013 12:10 PM |
Possible Clutch Problems? | Daks | 1986 - 2007 Ninja 250R Tech Talk | 8 | June 14th, 2013 06:34 AM |
gear problems | sah27513 | New Members | 45 | January 11th, 2013 07:24 PM |
Problems...maybe ya'll can help | bobguy | 2008 - 2012 Ninja 250R Tech Talk | 34 | October 3rd, 2011 02:37 PM |
