July 18th, 2012, 07:55 AM | #1 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
badly stripped brake caliper screw
hey guys I stripped the screw bad on the front brake caliper. Its one of the ones that holds the brake pads in place. How the hell can I get it out?? I tried to fit a larger allen key in it once it got rounded out but it just made it worse...
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound |
July 18th, 2012, 08:40 AM | #2 |
July 18th, 2012, 09:50 AM | #3 |
grind the head off, take the caliper off, use grips to remove the remaining bolt shaft, replace.
July 18th, 2012, 09:58 AM | #4 |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
EZ out will work or could also try tapping a Torx bit into the head and try removing the bolt.
July 18th, 2012, 09:58 AM | #5 | |
Looks like a used one can be had for around $30
July 18th, 2012, 10:20 AM | #7 |
dremel a flathead pattern into it, and buy a new one.
a small easy out might do the trick. or maybe go buy a reverse thread tap and bolt that will fit into the allen area. "tighten" the reverse threaded bolt in and eventually it will start removing your stripped piece. |
July 18th, 2012, 03:49 PM | #8 |
Join Date: Jun 2012 Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F Posts: 534
Bring it to a good machinist. Seriously. For a small fee they'll save you a LOT of head aches and get you all set. I wouldn't recommend trying to fix this yourself unless if you know what you're doing. However, since you're asking this here, you do not know what you're doing. This is your brakes you're talking about.
I once stripped the caliper body of my last bike (CB450T). A replacement was $200. I wasn't about to pony up that coin. Luckily, my mom's boyfriend was a machinist in his day and knew exactly what we needed to do. The stars aligned and the caliper was able to be saved. However, the first move I was going to make to fix it was going to cost me $200, that's for sure. Some time spent, and knowledge gained, vs. $200, time and even less knowledge gained. What do you think sounds better? Also, for future reference, this is why you ALWAYS use flare nut wrenches on bleed screws. This eliminates the possibility of them stripping. Also, when bleeding, DO NOT tighten. Think of the bleed screw as an on/off valve. When it lightly seats, it's turned off. Only give it a VERY slight tighten when you're all done bleeding. Calipers are made of VERY soft metal. I learned this the hard way with my CB450. I was barely putting any force on the screw and it ate through the threads in the body of the caliper like it were wet toilet paper. |
July 19th, 2012, 01:50 PM | #9 |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
Those pad alignment pins are VERY VERY VERY prone to seizing. A lesson learned the hard way from me due to MULTIPLE times rounding off the heads.
I used this from Harbor Freight...has saved me multiple times. EDIT: I will post a picture of it when I have the chance or PM me...the website doesnt show them You need to actually hammer it down a bit so the teeth bites into rounded head, and then use a ratchet or a T-handle...DO NOT use a drill...it will break the extractor and then you're REALLY in for a world of hurt (don't ask me how I know) A couple things you can do to prevent that. If you love to take care of your bike and have time, at least once a month remove the caliper from the forks and remove the pads from teh calipers and actually clean the calipers and caliper pistons with an old toothbrush and dishwashing soap and water. Cleaning the pistons will ensure you get even wear on the brake pads. This also ensures that removing the pin will not give it enough time to seize up like it did. Put anti-seize paste on the threads. Not grease...Anti-Seize paste. A very small amount is all that's needed. This is what I started doing also...no problems ever since. Recently, Dave Moss recommended doing this. (If you don't know who Dave Moss is...google him...). If you are concerned about the pin possibly vibrating out due to having anti seize paste in, drill a small hole on the opposite end of the threads and stick very small cotter pin in. This is standard on the Daytona 675. Who knows...maybe you can get the pins from a Daytona 675 and use them on the Ninjette? If you are going to be removing that bolt again, spray some PB Blaster Penetrating catalyst and let it soak for 5-10 minutes to hopefully break the bonds causing the bolt to be seized. |
July 19th, 2012, 02:36 PM | #10 | |
It works at up to 1000°C |
January 26th, 2016, 10:36 PM | #11 | |
Join Date: Jan 2016 Motorcycle(s): Ninja ZX6R and SV650S Posts: 2
I've already ordered a new bolt but the old one is still stuck in it. Cheers |
January 28th, 2016, 12:09 PM | #12 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
Good luck. It may be easier to get a used one. I've had 2 do the same thing. Both times I stripped down the caliper to the bare casting then brazed an allen wrench into that pin. Worked fine both times and both calipers are still in service but the procedure may be more than most are willing to undertake.
January 28th, 2016, 02:38 PM | #13 |
FWIW I removed a stripped fairing bolt by hammering an oversized Torx bit into it, then (carefully!) using an impact driver to back the offending little bugger out. Carefully, otherwise the Torx will just strip the hole out even bigger. Don't know if that technique would work here, given that it's a grub screw. There might not be enough material there.
January 28th, 2016, 03:55 PM | #14 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
I strongly recommend a machine shop remove it or you have a real risk of ruining the caliper.
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
January 28th, 2016, 04:29 PM | #15 |
I managed to get it off by hammering a slightly bigger allen key into the screw.
Then I carefully put some pressure on it and it worked! I could remove that bolt and already ordered a new one. I suspect that happened because it had been a long time since the pads had been replaced (bought this track bike and ex-owner had left it in the garage for 1 year, then I used it for few more track days (about 6 months) and finally replaced the pads now. The calipers were really dirty. I guess just a bit more attention to it in the future would prevent that to happen again. Cheers. |
February 3rd, 2016, 11:46 AM | #16 | |
Board Member
but....you may not be able to get your hands on the stuff.... |
February 10th, 2016, 05:34 PM | #17 |
Join Date: Feb 2016 Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish Posts: 40
Pro-bolt sells some nice replacements hate the little pin bolts they love to get jammed in the caliper.
Rear caliper allen key bolt stripped | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 17 | June 30th, 2013 12:32 PM |
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 1 | May 30th, 2013 08:13 PM |
Stripped Allen Screw/Front fork change | ManOfGod | 1986 - 2007 Ninja 250R Tech Talk | 7 | April 30th, 2013 10:43 AM |
Stripped fuel bowl screw now what? | Slono | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 19th, 2012 12:38 PM |
stripped screw | scotty | 2008 - 2012 Ninja 250R Tech Talk | 17 | October 6th, 2010 11:05 AM |
