Old July 14th, 2013, 07:23 PM   #1
focus101
Motorcycle(s): 96 250
Exclamation fuel tank leak at bolt holes
long story short the last tank (one that came with the bike) was leaking at the upper bolt holes, now i got a new (used) tank in pretty good condition, but on the left side i has a small drop (only when its full and on the kick stand), now my ? is am i getting the wrong size bolts? whats the correct size??, the threads on the tank look good and non striped. (btw i have the tank off now and the bolts i had in there broke off inside smh) NEED HELP!!
thanks
shawn
focus101 is offline   Reply With Quote
Old July 15th, 2013, 02:31 AM   #2
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
Common problem with these bikes, using too long a bolt will punch a hole right through your tank. The correct length for the bolt is 18mm. The holes can be welded up, but will need someone who knows what they are doing.
baxtc1 is offline   Reply With Quote
Old July 15th, 2013, 06:26 AM   #3
focus101
i do know someone who can weld, what is he welding the hole itself or around it?? is there an alternate way i can get it welded??
Old July 15th, 2013, 06:47 AM   #4
az3200
az3200's Avatar
Motorcycle(s): 2002 Ninja 250
my next door neighbor had a ninja 250 with the same problem. Used a bolt that was too long and put a hole in the tank. He used JB Weld to patch it up. It worked, for the remaining 2 months before he totaled the bike
az3200 is offline   Reply With Quote
Old July 15th, 2013, 07:23 AM   #5
spc2125
Motorcycle(s): 10 Ninja 250
Im in a kind of similar situation... my gas cap is leaking fuel when i fill it up and itll spew out the top. I think ill eventually just buy one on ebay. It wont have the key on it anymore, but it'll be a nice little *farkle*.
You can also get the gas cap bolts on ebay (in different colors as well)
Not something im going to get but just an example
http://www.ebay.com/itm/Black-Billet...662f88&vxp=mtr
and the bolts
http://www.ebay.com/itm/Titanium-Gas...cb4cc7&vxp=mtr
spc2125 is offline   Reply With Quote
Old July 15th, 2013, 08:53 AM   #6
focus101
where did he apply the jb weld at exactly?? on the bolts or around hole area around the tank?? i heard of someone on another forum said he did that same thing.
not to mention i have to drill to two parts to the bolt that broke off when i taking them out. their in the back of the hole though maybe i can use a small bolt??..
thanks for your input guy im new at the bike stuff but mechanically inclined..
Old July 15th, 2013, 04:50 PM   #7
baxtc1
baxtc1's Avatar
If you have a look where the bolts go, you will see that they screw into a plate that is welded to the tank. Behind that plate should be solid wall of the fuel tank. Whatever you try to seal it with will need to go onto the tank behind that plate. If getting it welded, that plate will be removed, the hole welded and then the plate rewelded back into place. I had someone weld up a tank on a previous GPX 250 I had a few years ago, he didn't do so well, he welded it up good, but he didn't clear all the fumes properly and had a small pop as he waved the torch over. That small pop was enough to blow the tank out of shape. I accepted the risk when I asked him to do it and in this case I ended up having to buy another tank anyway. As I said, if you go the welding route, make sure the bloke doing it is careful and you should be right.
Old July 16th, 2013, 10:19 AM   #8
focus101
ok i see it now, what imma do is just use some jb weld to patch it up(just gotta see where to apply it at), plus my upper fairing is cracked (came like that) so imma do a semi naked/streetfighter look and rock with that for a little bit, these tanks is a pain in the rear end lol..
thanks guys
Old July 16th, 2013, 05:48 PM   #9
slickt0mmy
Motorcycle(s): 2004 Ninja 250
I have a similar problem. Previous owner punched a hole through the tank and tried to patch it with JB Weld. Unfortunately, they completely screwed it up and pressed the plate down flush with the tank and put JB Weld over the whole assembly. Now the bolt threads right into the gas tank and acts like a plug to keep the gas in. This would be fine except for the fact that small amounts of gas still leak out through the threads.
It's not enough to be alarming but my tank is constantly wet on the left side and is starting to get a yellow stain where the gas is always seeping out.
Whichever engineer at Kawasaki that designed this whole system needs to be fired.
slickt0mmy is offline   Reply With Quote
Old May 26th, 2014, 09:02 PM   #10
The plate has a nut welded to the back and is spot-welded in three places. There are dimples in the tank just deep enough to make room for the nuts.
I would not recommend welding on the tank (factory did it before it ever had gas in it). I believe even an 18mm bolt will puncture the tank without fairings and such between.
Another user here has since freed his with a spot weld cutter and then soldered a tiny bit of sheet metal over the hole. I tried the same thing and ended up cutting more holes in the tank because the plate would not free even after drilling through the plate.
Old January 28th, 2016, 04:26 PM   #11
gordonsimon
Motorcycle(s): bimota sb6r, ninja 250r, aprilia tuono, triumph tiger, vespa gt200
permanent fix
made a permanent fix...see photos..used 3/4" brass finger pull, JB METAL PUTTY AND JB WELD...EMAIL ME IF YOU WANT ALL THE DETAILS, BUT THE PHOTOS SAY IT ALL. once it was in place, i then filled up the finger full with JB weld and turned tank upside down with the bolt in the hole (well greased) to complete the sealing just in case something get past the brass finger pull.
gordonsimon is offline   Reply With Quote
Old January 29th, 2016, 04:23 AM   #12
swarfman64
Master modder
swarfman64's Avatar
Motorcycle(s): TURBO gpx250 99 CB250/500rs Sherco290 Trials Indian 1911big base (replica)
I had the same problem.
I cleaned and dried tank, wound a long bolt in to open out the hole into the tank. Grab a 6mm x 6mm long grub screw, coat it and the internal threads (using match stick or similar) with JB weld. make sure you work the JB into the threads, get it bonding. Screw the grub screw in till its about 10mm deep, If you go to far just fish it out of the tank and try again. That's it, let it cure. As the grub screw goes in it cleans the JB from the thread so you don't need to re-tap it. I did all of mine and no leaks in 3 years, and m tanks been on and off a billion times!
[B]Come and see my turbo ninja build, dyno build and other stuff at http://swarfman64.blogspot.com.au/20...rtia-dyno.html
swarfman64 is offline   Reply With Quote
Old January 29th, 2016, 08:30 AM   #13
HoneyBadgerRy
HoneyBadgerRy's Avatar
My bike was in the exact same situation when I bought it, I sanded down some of the JB weld he had on it, got a american sized nylon bolt, coated in in jb weld, cross threaded it into the gas tank (when it was empty) and then coated the head of the bolt in JB weld, it no longer leaks.
Old January 29th, 2016, 08:45 AM   #14
Bowtie2Bimmer
Motorcycle(s): 2005 V-STROM 1000
This is super helpful. the tank I just got off ebay leaks form both bolt holes. Looks like we will need to jb weld it before we use it.
Actually, we are Kreeming the tank. Would this plug up those holes?
Bowtie2Bimmer is offline   Reply With Quote
Old January 29th, 2016, 10:52 AM   #15
agentbad
agentbad's Avatar
Don't they have a recall on this tank?
Old January 29th, 2016, 11:03 AM   #16
RickM
Motorcycle(s): 2000 EX250
They did have a recall on the tank. I don't think it's still active though
RickM is offline   Reply With Quote
Old January 29th, 2016, 11:42 AM   #17
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
They did have a recall on the tanks, and I just had mine inspected for it. Some bikes did have bolts that were too long, and would dent the tank causing a rust point/leak. The recall was issued in 2007. Check and see if you can get something covered under it- they might be able to work with you.
Old February 3rd, 2016, 06:16 AM   #18
taz
taz's Avatar
MOTM - May '17
this same topic seems to come upalot so i thoought i would put a link to a good fix. https://www.ninjette.org/forums/show...341#post860341
Recall on 05 Ninja 250R - fuel tank leak AmyF 1986 - 2007 Ninja 250R Tech Talk 10 October 3rd, 2021 06:19 PM
[RoadRUNNER] - Pot Holes, Sink Holes, and Buckled Roads Ninjette Newsbot Motorcycling News 0 August 26th, 2014 03:01 AM
Installed a tank without holes, a fairing with no cracks, and the gauges too!! verboten1 1986 - 2007 Ninja 250R Farkles 2 August 26th, 2013 01:13 PM
Help, fuel leak. Stangrider 2008 - 2012 Ninja 250R Tech Talk 3 June 24th, 2013 09:34 PM
Never use fuel tank linear, and there is a nut on the clutch lever bolt... saber63 1986 - 2007 Ninja 250R Tech Talk 0 April 23rd, 2010 08:58 AM
