May 4th, 2014, 01:30 PM | #1 |
Join Date: May 2014 Motorcycle(s): Ninja 250 cbr600 Posts: 3
New blinkers, did all the wiring but confused with load independent relay flasher
I have a 2012 Kawi ninja ex250, took off the stock blinker lights and put on some aftermarket lights. The rate of flash is off it depends on the speed because I have a load dependent flasher. How do I find a load independent relay flasher that works for a ninja 250? Sorry if this is a bad question google hasn't been very helpful. Thanks y'all.
May 4th, 2014, 01:34 PM | #2 |
Some info here:
https://www.ninjette.org/forums/showthread.php?t=76116 and https://www.ninjette.org/forums/showthread.php?t=79621 It sounds like you need the diode mod, along with the correct relay (EP34 is supposedly the current winner, looks to be $12 on Amazon).
May 4th, 2014, 09:15 PM | #3 | |
May 5th, 2014, 10:03 AM | #4 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
Good to hear your problem is solved. Welcome to ninjette David!
May 11th, 2014, 04:58 PM | #5 |
So my lights aren't LED and I've tried this to no avail. What's next?
turn signal relay flasher install | contact148 | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 8th, 2013 02:05 PM |
flasher relay buzzing? | rawbert625 | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 17th, 2012 12:21 AM |
Flasher relay question!!!!! | danjaho | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 8th, 2011 03:03 PM |
what kind of flasher relay? | DEXSPEED | 2008 - 2012 Ninja 250R Farkles | 6 | January 24th, 2011 08:02 PM |
