Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 Farkles
Old November 16th, 2012, 05:54 PM   #1
JBinSD
Motorcycle(s): '13 Ninja 300, '99 SV650 tracked
Front Rim same as 250?
Can anyone confirm the 300 front is the same as the two-fiddy? Ie Rotor and hub match the same? I'm pretty sure tire size is the same. New front rim is $500+, yuck. I know the spoke style is different, but I can live with to save some $$.
thanx,
Joel
JBinSD is offline   Reply With Quote
Old November 16th, 2012, 09:35 PM   #2
I don't believe they are the same. The 250 rim fits a speedo sensor on the left, the 300 does without any spacer.
Old November 20th, 2012, 09:04 PM   #3
I wonder if it will fit using the newgen-J speed sender/meter gear as a spacer (no cable). The forks won't have the little notches that keep the meter gear in place but I doubt that's a concern. The rotor is the same but the position might not be. If it does fit, let us know!
The whole triple tree will almost certainly fit (the triple clamps are the same), so you might want to look into that if your forks are bent. If they are straight you might be able to get the lower parts from someone with bent newgen-J forks and build them onto your forks tubes, but the fork tube part numbers are different so that's probably only worth looking into if the seller will throw them in with the rim.
Hope this helps.
Old November 20th, 2012, 10:39 PM   #4
JBinSD
Thanx CZ, it appears that the forks are straight, but who knows. I may try to get the wheel straightened/trued, but it will probably need to be replaced. I was hoping someone with both a 300 and a 250 could try a quick swap, but if not, when I get it back, I'll try taking to someone with a 250 and compare.
Cheers,
Joel
Old November 20th, 2012, 11:07 PM   #5
Cheers,
Joel
When I was in San Diego and needed a rim straightened I took mine up to Sierra Madre to get it fixed at Mackie Welding. Dude did it in minutes and only charged me $70! That's a fraction of what any other service I've read about would charge and that's what I suggest you do.
I just tied that rim on my backpack and rode up there on my Ninjette (I already had powder-coated replacements) because I had other things to do in Banning and San Bernardino that day (yes, VERY long day).
Old November 21st, 2012, 02:24 AM   #6
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
Joel, I would take your bike to Mackie in Sierra Madre or to Dr. John's Frame straightening in Anaheim. When my Daytona forks were bent I sent them to Dr. John's to fix.
Mackie I heard is cheaper. Both should be able to fix your wheel and go over the frame and forks to make sure other stuff is straight also. If not, they can fix. It will be the cheapest route for you overall I think. The 300 is too new to find used/salvaged parts on forums and on ebay.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old November 23rd, 2012, 09:42 PM   #7
JBinSD
D*mn, wish I woulda read these recs for Mackie earlier, I was just in Glendale today (I h8 LA,and avoid it like the plague), but could just swung by. Not sure if the rim can be trued or not, but hopefully. Good reviews thus far too. . . wish there was someone closer to SD though. .
Old November 24th, 2012, 09:03 AM   #8
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
A rim from a 250 will fit on the 300.
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old November 24th, 2012, 09:50 AM   #9
JBinSD
Have you tried swapping 'em Peanut? Alex mentioned the speedo mount or rotor mount may be issues. . .
Old November 24th, 2012, 05:28 PM   #10
Peanut_EOD
Peanut_EOD's Avatar
I haven't yet. The 250 is still in the RV. I'll swap them and take a picture for you as I bring the 250 home.
Old November 24th, 2012, 09:40 PM   #11
JBinSD
Thanks peanut I appreciate it, no rush though the bike is still in various pieces. It must be a long walk from that mobile palace to the garage in the back too ;-).
Old November 24th, 2012, 09:47 PM   #12
Peanut_EOD
Peanut_EOD's Avatar
It is, but I don't live in it full time. The RV is 30 miles away from my house in RV storage.
Old December 3rd, 2012, 03:10 PM   #13
JBinSD
Hey Peanut, any chance you had time to check the rims for me? A new OEM '13 rim is over $500, but I can get a used newgen for around $100, but no one's been able to confirm if it'll play nicely. . . .
thanx doood,
Joel
Old December 11th, 2012, 02:48 PM   #14
JBinSD
If anyone else has access to a 250 and a 300 please let me know if it looks like the rims are inter-changeable; I've found several 250 rims to buy, but can't confirm if they'll work or not. . . Thnx.
Old December 11th, 2012, 03:23 PM   #15
hey joel my 250 is just sitting around. i can bring it by next weekend sometime if you want? where are you? do you have your bike or is it in the shop still?
Old December 11th, 2012, 04:05 PM   #16
JBinSD
Hey thanx Alex, but my 300 is still up in LA w/ Bazazz, so I won't have it back for a bit. Every vendor wants it immediately, then it sits and nothing gets done. I have a ton of work to do on it, but haven't seen the thing in almost a month. I appreciate the offer, I see you're in C'bad too, maybe when I get it back I can spin by and try to trade wheels for a moment.
cheers,
Joel
Old December 11th, 2012, 04:17 PM   #17
the bike is in escondido but let me know
Old December 13th, 2012, 06:55 PM   #18
Peanut_EOD
Peanut_EOD's Avatar
Ok, sorry it took me so long to get to this. I swapped the front rims on the 250 and 300. They fit just fine. Here you go.
Old December 13th, 2012, 08:01 PM   #19
JBinSD
Awesome, thanx Peanut, did the bolt right up? No issues with spacers or speedo cable mount? did you try riding them that way, or just bolt 'em on? Rotors and axle all the same?
I appreciate the effort man, owe ya a beer next round. . .
Old December 14th, 2012, 10:00 PM   #20
Peanut_EOD
Peanut_EOD's Avatar
Yep, they just went right on. Same axles. I just left the speedo mount on the 250 rim to act as the spacer. No I didn't ride them around. It was like 20* here last night.
Old December 19th, 2012, 11:18 PM   #21
Awesome. So he just needs to make sure he gets the speedo sender/meter gear too (cheap).
Anyway, I know the four mounting bolts on the front fender will not line up, but would it otherwise swap with only the top bolts holding it on?
Wanted: Front Rim for 09 250 (black) NYCninja Items Wanted 7 October 15th, 2011 01:40 PM
EX250J ('08+) Front rim; also selling rear rim in an older thread CZroe Motorcycle-related 11 September 11th, 2011 08:32 PM
