Old October 2nd, 2014, 11:40 AM   #1
[motorcycle.com] - 2015 Suzuki GSX-S750 and GSX-S750Z Preview
The 750 Naked bike class has just gained a formidable entry. Suzuki has taken the wraps off the 2015 Suzuki GSX-S750 and GSX-S750Z, which our European readers will recognize as the GSR750 that’s been available on the Continent since 2011. These functionally identical motorcycles will certainly enliven what has been an energetic class in the last year.
Using the engine from Suzuki’s best selling model – the GSX-R750 – as a starting point, the GSX-S750’s 749cc mill has been massaged to deliver performance in the rpm range most commonly encountered on the street. With the charges and spent gasses flowing through specially designed intake/exhaust tracts, the valves are directly operated by cam profiles designed to produce bottom-end torque coupled with mid-range power for optimal streeting acceleration.
Suzuki’s Dual Throttle Valve (SDTV) controls the delivery of the air/fuel mixture for smooth throttle response, while new iridium spark plugs initiate the combustion with a hotter, more powerful spark for a more efficient burn. Iridium plugs also reduce maintenance thanks to increased plug longevity. The triangular muffler shares a family resemblance with Suzuki’s GSX-R line.
The chassis of the GSX-S blends a twin-spar frame with a tubular rear section and then attaches it to an inverted fork and a link-type shock controlling a steel swingarm. Dual 310mm discs and 2-piston calipers handle front braking duties while a 240mm rear disc is clamped by a single-piston binder.
The 32.1 in. seat height mates with an aggressively upright riding position. A Renthal aluminum Fatbar reaches back to the pilot to ease the navigation of urban obstacles or sinewy backroads. The tightly integrated package announces the GSX-S750’s miscreant tendencies through thoroughly modern, angular bodywork that is best illustrated by the design of the 4.6-gal. tank and tail section with its LED taillight. Suzuki claims a 463 lb. wet weight and a 57.1 in. wheelbase. Rake and trail figures are as yet unavailable.
The instrument cluster features a large analog tachometer with a LCD digital speedometer plus readouts for gear-position, coolant temperature, fuel gauge, dual tripmeters, fuel consumption and a clock. The backlight has adjustable brightness.
Colors and styling are what differentiate the S750 and the S750Z. Where the GSX-S750 is only available in Metallic Matte Black, the GSX-S750Z stands out in Metallic Triton Blue / Pearl Glacier White. Additionally, outer fork tubes of the Z are anodized in a yellowy-gold color instead of a lighter gold hue, plus red-anodized fork adjuster bolts, a red shock spring and blue chain.
Pricing is as aggressive as the bikes’ styling, with the GSX-S750 retailing for $7,999, and the GSX-S750Z only slightly higher at $8,149. No on-sale date has been set.
2015 Suzuki GSX-S750 & GSX-S750Z Specifications
Engine Type4-stroke, Inline 4-cylinder, liquid-cooled, DOHCEngine Displacement749ccBore x Stroke72.0mm x 46.0mmFuel SystemSuzuki Fuel InjectionCompression Ratio12.3:1Ignition TypeElectronic ignition (Transistorized)Transmission6-speed constant meshOverall Length2115mm (83.3 in)Overall Width785mm (30.9 in)Overall Height1060mm (41.7 in)Wheelbase1450mm (57.1 in)Ground Clearance145mm (5.7 in)Seat Height815mm (32.1 in)Curb mass210kg (463 lbs)Suspension FrontInverted telescopic, coil spring, oil dampedSuspension RearLink type, coil spring, oil dampedBrakes FrontDisc, twinBrakes RearDiscTires Front120/70-ZR17M/C (58W), tubelessTires Rear180/55-ZR17M/C (73W), tubelessFuel Tank17.5 L (4.6 US gal)ColorGSX-S750Z Metallic Triton Blue / Pearl Glacier White
GSX-S750, Metallic Matte Black2015 Suzuki GSX-S750 and GSX-S750Z Preview appeared first on Motorcycle.com.
Click here for full story...
Old October 3rd, 2014, 01:17 PM   #2
Jono
Jono's Avatar
I dig it! Oh no, I think I am becoming a Suzuki fan. It's very heavy though so I think Yamaha still has the best Jap naked bike.
Old October 3rd, 2014, 02:29 PM   #3
Sooooooo FZ09 vs GSX-S750 showdown. Aaaaand go!
Such good pricing too. I like where this trend is going. Mid weight bikes with street riders in mind. that looks like a nice bike.
[motorcycle-usa.com] - 2015 Suzuki GSX-S750 First Look Ninjette Newsbot Motorcycling News 0 October 3rd, 2014 05:20 AM
[cyclenews.com] - First Look: 2016 Suzuki GSX-S1000/2015 GSX-S750 Naked Bikes Ninjette Newsbot Motorcycling News 0 October 3rd, 2014 03:00 AM
[motorcyclistonline] - 2015 Suzuki GSX-S1000 & GSX-S750 | FIRST LOOK Ninjette Newsbot Motorcycling News 0 October 2nd, 2014 08:10 PM
[sportrider - features] - Suzuki GSX-S1000F ABS, GSX-S1000S and GSX-S750 First Look Ninjette Newsbot Motorcycling News 0 October 2nd, 2014 05:10 PM
[roadracingworld.com] - Suzuki Introduces New GSX-S750 And GSX-S1000 Naked Sportbikes Ninjette Newsbot Motorcycling News 0 October 2nd, 2014 11:40 AM
