August 16th, 2022, 10:00 AM | #1 |
[webbikeworld.com] - 2022 MV Agusta Dragster RR SCS [Specs, Features, Photos]
Click here for full story...
2022 MV Agusta Dragster RR SCS: The Tarmac Burner Contents The MV Agusta Dragster 800 RR SCS is a version based on the MV Agusta Dragster 800 RR 2021. Therefore, it received all the improvements made to the Dragster family: the engine, the cycle part, and the equipment and it’s brand spanking new for the 2022 model year. In addition, this version features the innovative SCS (Smart Clutch System) automatic transmission developed together with Rekluse, which has also refined its behavior. As a result, this system allows you to pick up speed faster than traditional clutch bikes. The SCS 2.0 allows for a perfect balance between clutch action and engine delivery curve. However, the SCS doesn’t change how the rider interacts with the bike. The clutch control and the change and gears remain in their usual place, but with the option of not using the clutch to maximize performance. Designwise, this Italian-made motorbike shows vitality and character at every angle, ready to burn the asphalt thanks to the new intelligent gearbox and electronics. The fuel tank’s curves, headlight, short exhaust, and sleek radial-mounted wheels frame the three-cylinder engine. This motor has an electronic control with an extremely sensitive response and allows you to exploit its full potential. The 2022 MV Agusta Dragster RR SCS starts at $23,398 USD / $26,346 CAD On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Agusta Dragster RR SCS in one place. Model Overview </p>General Info
Main Specs
Competitors 2022 MV Agusta Dragster RR SCS Specifications ENGINE Engine798 cm3 (48.68 cu. in.), Three cylinder, 4 stroke, 12 valvePower140 HpBore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)Compression Ratio13.3:1Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappetStarterElectricColorMeatallic Pearl Yellow Gloss, Intense Black Gloss, Fried Red Gloss, Matt Megnum Avio Grey, Matt Metallic Dark GeryDRIVETRAIN ClutchS.C.S. 2.0 (Smart Clutch System) Radius CX automatic clutch with hydraulic clutch actuation, wet multi-discTransmissionCassette style; six speed, constant meshFinal Drive Ratio16/41CHASSIS Suspension FrontMarzocchi “UPSIDE DOWN” telescopic hydraulic fork in DLC treated aluminium, with anodized fork legs and having rebound-compression damping and spring preload external and separate adjustmentSuspension RearProgressive Sachs, single shock absorber with rebound and compression damping and spring preload adjustmentBrakes FrontDouble floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.Tires Front120/70 – ZR 17 M/C (58 W)Tires Rear200/55 – ZR 17 M/C (78 W)Fuel Tank Capacity16.5 l (4.36 U.S. gal.)ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering functionELECTRICAL Battery12 V – 8.6 AhVoltage12 VAlternator350 W at 5000 r.p.m.HeadlightTail LightDIMENSIONS Overall Length2035 mm (80.12 in.)Overall Width935 mm (36.81 in.)Trail103.5 mm (4.07 in.)Wheelbase1400 mm (55.12 in.)Ground Clearance135 mm (5.31 in.)Seat Height845 mm (33.27 in.)Dry Weight175 kg (385.8 lbs.)WARRANTY WarrantyExtension 2022 MV Agusta Dragster RR SCS Features Electronics The SCS 2.0 system allows a perfect match between the clutch action and the delivery curve of the three-cylinder engine. The support of highly sophisticated electronics has allowed MV engineers to unlock the secret to beating traditional-clutch models in acceleration performance. Technology The SCS 2.0 system doesn’t really change the way the rider interacts with the motorcycle: the clutch control, shift and gears are still just where you’d expect to find them, but with the bonus option of simply deciding not to use the clutch. For extreme functionality, without sacrificing anything. Safety A braking system worthy of the name and performance of the Dragster. Powerful and scalable, with two 320 mm-diameter floating discs and four-piston radial callipers, plus the assistance of the advanced Continental ABS with cornering function. 2022 MV Agusta Dragster RR SCS Photos 2022 MV Agusta Dragster RR SCS Videos 2022 MV Agusta Dragster RR SCS First Ride 2022 MV Agusta Dragster RR SCS Dyno Test Links MV Agusta Websites Other Links The post 2022 MV Agusta Dragster RR SCS [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 MV Agusta Dragster RR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | August 15th, 2022 11:51 AM |
[webbikeworld.com] - 2022 MV Agusta Dragster Rosso [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | August 15th, 2022 10:23 AM |
[webbikeworld.com] - 2022 MV Agusta Brutale 1000 RR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | August 14th, 2022 01:21 PM |
[webbikeworld.com] - 2022 MV Agusta Brutale RR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | August 14th, 2022 09:50 AM |
[webbikeworld.com] - 2022 MV Agusta Brutale Rosso [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | August 14th, 2022 07:41 AM |
