November 12th, 2010, 08:28 AM | #1 |
Join Date: Nov 2010 Motorcycle(s): Red Ninja 250r 09 Posts: 13
Having sum problems with Ninja 250R 09
I have tryed jump starting and Charging the battery.. still nothing.. Im not much of a auto-motor mechanical wiz. How much would sumthin like this cost to get looked at and fixed. Just dont want to be overcharged too much.
Bike has Been in storage for quite sum Time ( since june ), only has 469 miles on it. Ive siphoned out gas, drained carbs, added fresh fuel, added green stabil, charged battery still nothing..bleh Is their a step im missing. Just feel hopeless.. lol Guess it is my fault for not storing properly Like I said I have Little to None Experience in Mechanics, not sure im comfortable pulling everything apart |
November 12th, 2010, 08:36 AM | #2 |
Well lets start with some simple questions to help everyone better understand.
Does the engine turn over? Does it crank but not start? Does it start but not run?
November 12th, 2010, 08:40 AM | #3 |
At first it made the click click noise, was told thats battery, charged.. fixed
Now it turns engine but doesnt fire. does not start |
November 12th, 2010, 08:47 AM | #4 |
Ok. I know it may sound weird to ask but it has happened before so please no offense intended. Double-check that the kill switch is set to on position. Neutral light on the dash should also be on. I want to make sure we don't have a safety switch preventing it from starting. Are you using the choke per the normal cold start procedure? Does it "hit" or "pop" as if it trying to start?
November 12th, 2010, 08:53 AM | #5 |
Yes Kill switch off, I made sure it was in neutral, using choke, just trys to turn over but nothing hitting.
November 12th, 2010, 09:01 AM | #6 |
OK. Do we know for sure it is getting fuel? check the carb bowl drain screws to see if fuel comes out? Do you need help with this? I could prolly get some pics to help if needed.
November 12th, 2010, 09:10 AM | #7 |
November 12th, 2010, 09:11 AM | #8 |
Im at work atm, before i put fresh fuel back in, i drained carbs.. it leaked then... havent checked since.
November 12th, 2010, 09:20 AM | #9 |
That's cool. We can take it step by step. The 2 links DaBlue1 posted has some good information too. Review that and check for fuel then get back to us.
November 12th, 2010, 09:32 AM | #10 |
Yea checked most of those except valves and taking out carb. How much would that all cost to be done at a shop. Like i said not much mechanic exp and have a bad feeling ill screw it up more :P
November 12th, 2010, 09:41 AM | #11 |
If you are really unsure of your mechanical skills, there is one more thing you can try. Get yourself a can of Seafoam http://www.seafoamsales.com/how-to-u...treatment.html and add it to your gas. Let it sit in the tank and carbs overnight and see if that helps. Most shops charge and hourly rate. You will have to check you local shop what the rate is for a tune up.
November 12th, 2010, 09:52 AM | #12 | |
November 12th, 2010, 09:54 AM | #13 |
November 12th, 2010, 09:59 AM | #14 |
thanks ill try the seafoam when i get home.
[visordown.com] - Dymag looking to secure sevenfigure sum for new factory | Ninjette Newsbot | Motorcycling News | 0 | January 8th, 2015 04:30 AM |
Common Problems with Ninja 250r | Ragnar1x | 1986 - 2007 Ninja 250R Tech Talk | 15 | May 31st, 2011 01:02 PM |
[hell for leather] - GETN SUM respect from the DMV | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2011 07:30 PM |
Ninja 250r 2009 - first 300 miles impressions/problems | hackeron | 2008 - 2012 Ninja 250R Tech Talk | 7 | September 12th, 2010 10:20 PM |
RPM problems on 2010 ninja 250r | Spencer M | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 1st, 2010 04:59 AM |
