September 13th, 2013, 06:31 PM | #1 |
90% Reader, 10% Poster
Join Date: Aug 2013 Motorcycle(s): 2000 Ninja Ex250 Posts: 10
Oil leak from drain plug
I noticed I had a very very tiny leak coming from the drain plug (one drop a night).
I bought a new drain plug and as my mechanic was about to unscrew the plug, he stopped and said it's because it looks like something was wrong. The drain plug that was on there seems to have been a non metric type and went in sideways. Long story short, my bike is now leaking more, 3-4 drops when I park it. And it's only been a couple of hours since it left the mechanic's hands. It's there any solution to this that would be inexpensive? My mechanic said he's going to do some research because he's concerned about that and the fact that the oil filter is on there SUPER TIGHT and can't get it out. |
September 13th, 2013, 06:42 PM | #2 |
MOTM - Jan '18, Sep '13
I've heard people mention helicoil as a repair option.
September 13th, 2013, 11:18 PM | #3 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
1. Replace oil pan.
OR 2. Weld the old oil drain plug on. Then replace your oil pick up filter cover with the new-gen pick up cover, which includes another oil drain plug and has the benefit of providing a larger supply for the pickup under hard breaking. http://faq.ninja250.org/wiki/Changin...ver/drain_plug
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike Last futzed with by Lychee; September 16th, 2013 at 10:27 AM. |
September 14th, 2013, 05:58 AM | #4 | |
Why did you buy a new drain plug? Did it come with a new aluminum washer?
September 14th, 2013, 05:50 PM | #5 | |
Anyway, I was warned before buying the bike that the drain plug is causing a tiny leak and therefore, I bought a new drain plug. And yes, it came with an aluminum washer. It was just a matter of time that I had the bike in the shop and checked out. |
September 14th, 2013, 07:38 PM | #6 |
You will need to plan time to disable the bike, just in case any repair takes some time.
You will need to drain all the oil and inspect the condition of the aluminum threads in the crankcase (the old plug is not likely to be damaged). See how the new plug adjusts in the threads; it doesn't have to be perfect. They may be strong enough to put pressure on the new washer and eliminate the leak. If not, you will need to find a way to seal that hole and use the new-gen system. You could try a helicoil but the problem is that the threads need to be perfectly perpendicular to the flat sealing surface in order to avoid any leak.
September 14th, 2013, 11:45 PM | #7 | |
October 4th, 2013, 01:03 PM | #8 |
Just curious, how much will a new oil pan will cost me?
The puzzling demise of my Oil Drain Plug Socket | ChrisMKV | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 10th, 2014 11:00 AM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
2008 oil drain plug size and specs?? | azimmer11 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 12th, 2012 09:55 PM |
[webbikeworld.com] - Magnetic Drain Plug and Oil Filter Magnet Review | Ninjette Newsbot | Motorcycling News | 0 | October 9th, 2011 10:10 AM |
2009 model oil drain plug crush washer | littledog | 2008 - 2012 Ninja 250R Tech Talk | 14 | January 14th, 2010 02:57 PM |
