View Poll Results: How do you prefer to cut the engine?
toggle the cut-off switch 95 45.24%
turn the ignition key to off 84 40.00%
put the kickstand down 15 7.14%
no preference (use all 3 interchangeably) 16 7.62%
Voters: 210. You may not vote on this poll
Old July 15th, 2009, 02:06 PM   #1
dimeified
Motorcycle(s): '09 Blue 250R
How do i shut off my bike????
Ok i pretty much have everything under control except shutdown procedure. Put the bike in neutral, but then do i hit the ignition cut off switch and then turn the key off? Or do i skip hitting the ignition cutoff?
dimeified is offline   Reply With Quote
Old July 15th, 2009, 02:12 PM   #2
I use the key to shut off my bike. if you use the kill switch, the lights stay on and you might forget to turn them off one day if you leave the key in.
as far as the bike is concerned, it doesn't matter which way you kill the engine.
Old July 15th, 2009, 02:29 PM   #3
rockNroll
rockNroll's Avatar
Motorcycle(s): black
I almost always put the kick stand down to kill the engine, then turn and remove the key and I always park my bikes in gear.
I think parking in gear is a good habit to get into so that if/when you do park on a slope one day, you're not gonna forget and have the bike roll. I park on a slope every day that I ride to work. Ive seen two people turn their bike off, remove the key, then walk away and the bike falls over (in a hurry)... I've seen a bunch of people "almost" do that, but catch themselves at the last moment. I started using the kickstand method so it would become a habit and I'd never pull that move... that was a long time ago and now I don't think about it.
Old July 15th, 2009, 03:32 PM   #4
sofo
sofo's Avatar
I stop with the bike in neutral, press the kill switch, remove the key, put down the stand with a tap forward to make sure it's down, then get off the bike.
There are some who leave their bikes in first gear, I'm sure there are times when that's a good idea, so I am not saying it's wrong.
Short answer - kill switch.
sofo is offline   Reply With Quote
Old July 15th, 2009, 03:34 PM   #5
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
I use either the kick stand or the kill switch - and i always leave it in gear, as it won't roll forward or backwards in gear on the slopes around here
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old July 15th, 2009, 03:42 PM   #6
NaughtyusMaximus
Motorcycle(s): 2009 ex250
I leave it running. Eventually it runs out of gas on its own.
NaughtyusMaximus is offline   Reply With Quote
Old July 15th, 2009, 03:43 PM   #7
sofo
sofo's Avatar
Now if I think about it in terms of living in San Fransisco... first gear all the way!
Old July 15th, 2009, 04:06 PM   #8
HKr1
IC2(SW)
HKr1's Avatar
1st gear....
Clutch in....
Turn key off....
Let clutch out...
Put kick stand down....
I always leave it in gear....
We never use the kill switch. It makes a nice manual fan "on" switch for sure.
Old July 15th, 2009, 07:49 PM   #9
Nickds7
Nickds7's Avatar
I leave it in neutral when parking it in my garage. Makes it easier in the morning to start it up to warm up, without me on it.
Nickds7 is offline   Reply With Quote
Old July 15th, 2009, 08:41 PM   #10
Anteraan
Motorcycle(s): 2009 Ninja 250 (Blue)
That's my method too. I do keep the steering lock on, even in the garage. I turn it off by turning the key. I've never used the kill switch, and I hope I never have to. I want zero wear on that baby if I ever need it while in motion.
Anteraan is offline   Reply With Quote
Old July 15th, 2009, 10:03 PM   #11
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
I do it the way I learned in the MSF course:
neutral
kill switch
key - set to steering lock (the lock is my own doing because of being in an open parking lot)
kickstand
In the course they said you should always use the kill switch followed by the key, but for the life of me I can't remember why.
sombo is offline   Reply With Quote
Old July 15th, 2009, 10:19 PM   #12
Nemy
Nemy's Avatar
Motorcycle(s): 2009 SE Ninja 250R
I switch it up. Sometimes key, mostly kill switch and on occasion the kickstand switch. It's a good way to make sure everything works and I remember reading somewhere about putting too much wear on one switch... or not using it enough is bad too blah blah blah... Not sure there's a right answer. Kind of like the contradictory studies of whether chocolate etc. is good for you
Nemy is offline   Reply With Quote
Old July 15th, 2009, 10:22 PM   #13
Chamus57
Chamus57's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r se
I use the kickstand to turn the engine off. If i am on a slope i leave it in gear, lock the bars and remove the key. When at home i do the same but put her in neutral so i can warm her up without getting on.
Chamus57 is offline   Reply With Quote
Old July 15th, 2009, 10:23 PM   #14
sombo
sombo's Avatar
Oh, but chocolate in moderation (everyone forgets the moderation part) is in deed good for you because of it's HIGH amount of antioxidants.
I'm a chocoholic/addict.
Old July 15th, 2009, 10:29 PM   #15
almost40
ninjette.org Monkey Spank
almost40's Avatar
Key here
Black 250R
Full Area P QC
Old July 15th, 2009, 10:31 PM   #16
dimeified
c'mon guys make up your minds IM ALMOST OUT OF GAS!!! I'm joking, for some reason killing the ignition before shutdown seems logical, like when you turn off a speaker system. You usually shut off the amplifier first before you turn off the preamps.
Old July 15th, 2009, 10:33 PM   #17
dimeified
But that switch is very red, did kawasaki design it as the "shiny red button" for a reason? Is it the "oh ****" switch? Or does it happen to be red by coincidence?
Old July 15th, 2009, 11:21 PM   #18
Cicarius
Sponge
Cicarius's Avatar
I agree. I was told that the kill switch is not meant for everyday use. The kill switch is all plastic parts but the ignition is a metal barrel. It made sense to me at the time so now I
- STOP
- Clutch
- First
- Key
- Stand
- Steering lock (if i feel the need)
Marty
Cicarius is offline   Reply With Quote
Old July 15th, 2009, 11:40 PM   #19
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
i used the kill switch almost exclusively on my first ride and wore out the switch, and although i'm sure switching tech has out-grown this somewhat, i'm a key guy unless i need hands on bars then it's the switch. i don't put it in neutral cuz i'm in 1st gear and bike rolled forward so it won't roll off the kick stand. (lesson learned farkle)
i've never used the kick stand to kill the bike unless i forget its down
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old July 16th, 2009, 12:11 AM   #20
Sound Wave
Ramen Rider
Sound Wave's Avatar
Originally Posted by rockNroll View Post
Ive seen two people turn their bike off, remove the key, then walk away and the bike falls over (in a hurry)... I've seen a bunch of people "almost" do that, but catch themselves at the last moment. .
ok, come on. sorry, but how can they turn off their bike, get off and walk away without putting the kick stand down? or did the get off the bike first, then turn it off and walk away.
either way, what a bunch of idiots! disclaimer: if anyone on this forum did that, then they are excluded, but everyone else who did it are still idiots.
Old July 16th, 2009, 12:16 AM   #21
Cicarius
Sponge
Cicarius's Avatar
I think he meant they just left it out of gear.
Old July 16th, 2009, 12:20 AM   #22
Sound Wave
Ramen Rider
Sound Wave's Avatar
ah. yeah you are right. i didn't read it well. that makes a lot more sense. lol.
Old July 16th, 2009, 12:39 AM   #23
Nickds7
Nickds7's Avatar
Problem I have with the kill switch and the kickstand is that it leaves all electronics on! That means your lights, dash, taillight and possible accessories all stay on until you hit the key. I don't like the idea of that.. especially if you stay sitting on the bike to talk to someone, and forget to turn the key right away. Still that extra few seconds of battery draining doesn't make me feel happy.
MSF says to hit the kill switch first so that you don't take your hands off the grips, I think. Just don't let go of the clutch when taking your hand off to turn the key :P
Should I sit down while I pee, so that I don't accidentally turn away? They just train you newbie style.
Old July 16th, 2009, 03:38 AM   #24
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
If I remember correctly, they had you do that so that if you were ever in a situation where you needed to shut the bike off while in motion, you're first reaction would be to hit the kill switch.
k-os is offline   Reply With Quote
Old July 16th, 2009, 05:41 AM   #25
tjkamper
tjkamper's Avatar
It really doesn't matter if you turn the key or flip the cut off switch. I always use the switch. I know in MSF they told us to use the switch as well. Also I always keep the bike in gear when it is parked.
I do pop it up to neutral in the morning so I can warm it up while still on the side stand. While it's warming up I put on my gear.
Old July 16th, 2009, 05:46 AM   #26
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
I believe that's only for dark chocolate
I'm not small, I'm fun sized
BlueRaven is offline   Reply With Quote
Old July 16th, 2009, 05:55 AM   #27
BlueRaven
BlueRaven's Avatar
In my course we were taught to use the kill switch but leave the bike in neutral. I always turn it off with my key cause the kill switch as mentioned by others is assembled with plastic parts. I always leave it in neutral in my parents garage just in case they need to move as they do not know how to turn the bike on (only biker in family). Now that I know a good reason for the leaving the bike in gear i will start doing that especially when i'm parking on a incline. You learn something every day.
Old July 16th, 2009, 06:53 AM   #28
rockNroll
rockNroll's Avatar
The bikes rolled and then fell over. Eh... I see now I coulda also worded it a little different too, not your fault.
Old July 16th, 2009, 08:06 AM   #29
sombo
sombo's Avatar
No, they just advertise it more for the dark because it has a higher concentration of cacao (aka cocoa bean). Milk chocolate still has the anti-oxidants in it, it just has less cocoa and a few more additives in it compared to dark. The darker the better for anti-oxidants, but it also starts to get bitter.
The kill switch may be made of plastic, but all switches go bad over time no matter what they are made of. I've had ignition switches go bad on my past cars before, and it was not from weighed down key chains putting to much pressure on it.
K-OS, thanks for the info. That would make sense I suppose.
Old July 16th, 2009, 09:15 AM   #30
Postiez
Postiez's Avatar
Motorcycle(s): Red '08 250
MSF told me to always use kill switch, sorry if this has already been said
Postiez is offline   Reply With Quote
Old July 16th, 2009, 09:50 AM   #31
capt_bugaloo
motorcycle rider
capt_bugaloo's Avatar
Typically: neutral, key off, sidestand, dismount, lock forks.
Occasionally I use the kill switch just so that I know that the switch is working fine.
I think it would actually be good to get into the habit of using the kill switch so that in an emergency I can have the engine turned off with a quick flick of the button...
Old July 16th, 2009, 10:44 AM   #32
sofo
sofo's Avatar
I must say this thread has got me thinking about both ignition key / switch for powering off and 1st gear / neutral parking. Thanks all!
Old July 16th, 2009, 05:46 PM   #33
Banzai
Psychic war veteran
Banzai's Avatar
From page 28 of the Owner's Manual "NOTE: Althout th engine stop switch stops the engine, it does not turn off all the electrical circuits. Ordinarily, the ignition switch should be used to stop the engine"
Old July 17th, 2009, 12:21 AM   #34
Nickds7
Nickds7's Avatar
^thank you. I was annoyed that msf wanted me to use the kill switch, but I conformed for the course without saying a word about it.
Old July 17th, 2009, 11:26 AM   #35
Postiez
Postiez's Avatar
well i dont think the msf was saying to do that instead of turning it off with the key, just first.
Old July 17th, 2009, 11:32 AM   #36
tjkamper
tjkamper's Avatar
Old July 17th, 2009, 11:58 AM   #37
revstriker
revstriker's Avatar
Motorcycle(s): 2009 Ninja zx6r
I typically use the key to shut off the engine. MSF teaches you to use the kill switch so that it becomes second nature to shut the engine off that way, should you need to do so in an emergency (at least, that's what they told us). They also teach you to kill the engine, and shut the key off. Probably a good idea to use the kill switch every now and then to check that it is in working order.
revstriker is offline   Reply With Quote
Old July 17th, 2009, 01:18 PM   #38
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
I conformed at msf regarding 4 fingers on the fr brake.
Posted via Mobile Device
Old July 17th, 2009, 04:16 PM   #39
Mo1981
Mo1981's Avatar
Motorcycle(s): 2008 Ebony Ninja 250R
Switch
Kickstand
Key
Neutral in the garage, 1st on the street.
Matt
2008 Ebony Ninja 250R (a.k.a. "Venom")
Mo1981 is offline   Reply With Quote
Old July 17th, 2009, 05:46 PM   #40
Guztack
ok.. this is pretty weird but when I ride the bike its fine. only when I finish parking the engine shuts off automatically o.O? this happens alot.
I don't release the clutch, but still almost everytime I finish riding this happens.
Guztack is offline   Reply With Quote
WTB: Pre-gen jet kit, factory pro, etc (TN preferred) kxpower? Items Wanted 9 September 30th, 2013 11:28 AM
OEM Oil Pump Parts - DIRE NEED - Southern California Preferred EternalNewb Items Wanted 1 September 2nd, 2013 11:22 AM
[crash.net - MotoGP] - Stoner: I've always preferred Silverstone to Donington Ninjette Newsbot Motorcycling News 0 June 15th, 2010 09:50 AM
[crash.net - MotoGP] - Engine rule to cut MotoGP celebrations Ninjette Newsbot Motorcycling News 0 August 13th, 2009 01:40 PM
WTB: Stock exhaust (chrome preferred) pre-08 Ninja 250 Grn99Kawi Items Wanted 1 June 1st, 2009 01:05 PM
