February 11th, 2012, 05:45 PM | #1 |
Join Date: Feb 2012 Motorcycle(s): 2003 Ninja 250 Posts: 91
Missing Filter Spring!!!
I Just bought a 2003 Ninja 250 and decided to do an oil change before I really rode it. The guy I bought it from says he rarely rode it and has another bike. It seems to run fine.
However when I changed the oil I noticed the filter assembly did not have the spring or washer between the filter plate and filter. The filter just sits directly on the plate. Unfortunately, I didnt realize this might be an issue until right after I poured the new oil in. So my questions are... Is this normal? Will it damage the motor if not fixed before 500 miles or so? What could this mean considering the bike has apparently been running like this for at least 200 miles( judging by the old oil and filter condition)? Thanks Guys, and Glad to be A NEW MEMBER HERE |
February 11th, 2012, 07:30 PM | #2 |
Motorcycle Hypermiler
Join Date: Jan 2012 Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's Posts: A lot.
Definitely not " normal" .The lubrication system is designed for the filter to seal with the spring pressure. WIth no filter washer and spring the oil is flowing past the filter element and not having dirt, grit and other contaminanats captured by the filter. The dirty oil freely circulates through your motor promoting premature wear. Not good. You need to get the missing spring and washer and install them ASAP.
Why wait 500 miles? The recommended oil change period is 5000 miles ( with a working filter of course). If you are concerned about dumping the fresh , clean oil you have just put in it, why not just carefully drain it into a clean container , fix your filter system and put the oil back in . 2 cents worth |
February 11th, 2012, 08:10 PM | #3 |
thanks
Yeah I just threw 500 out there to see how bad the problem might be. Ok so w/o the spring the filter doesn't do its job but its fine till I get a new spring and washer this week. I dont need to ride it any sooner anyway.
That sucks though considering there is no telling how many of the 14k miles on the bike have been ridden w/o the filter functioning properly. But yeah as far as the new oil... Ill just buy some more Ill just consider it a flush. Thanks |
February 11th, 2012, 08:27 PM | #4 |
You are most welcome! Thank goodness your bike has found a good home!
February 11th, 2012, 10:52 PM | #5 |
I had that same issue when I bought my ninja. I did an oil and filter change a couple days after I bought the bike and notice it was missing the spring and washer. Good thing I looked up a DIY before I did the oil change or I would have thought it was normal.
I don't know how long the previous owner was riding the bike without the spring and washer so I don't know if any damage was done to the engine. Hopefully not. I don't think it is a huge issue. I am sure most of the pieces of metal shavings or other debris that may be in the oil would be caught in either the filter or the oil screen. My bike ran the same after I put in the missing parts. So I would assume it would be okay to ride it until the parts come in. |
missing the washer between my oil filter and the spring | corralhollowkid | 1986 - 2007 Ninja 250R Tech Talk | 14 | July 22nd, 2017 02:36 PM |
Air filter missing? | csmith12 | 1986 - 2007 Ninja 250R Tech Talk | 4 | June 20th, 2011 12:16 PM |
Oil filter change - missing parts | HorizonXP | 2008 - 2012 Ninja 250R Tech Talk | 12 | August 29th, 2010 09:26 PM |
Oil Filter Shield Missing-is this really bad? | diablo250 | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 31st, 2010 09:08 PM |
Missing oil filter washer | JokerSeven | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 21st, 2010 07:23 PM |
