Old September 17th, 2021, 04:48 PM   #41
BonelessSugar
Motorcycle(s): EX250-F, TW200, NPS50
Take picture of left & right cases of your engine
There you go. I gotta degrease the underside tomorrow morning.
Last futzed with by BonelessSugar; September 17th, 2021 at 09:00 PM.
BonelessSugar is offline   Reply With Quote
Old Yesterday, 12:15 PM   #42
BonelessSugar
broken bolt in gas tank mount is removed. have to replace metal bracket and rivets and nuts and bolts for battery tray because a bolt is just too seized and i didnt wanna use a torch right next to plastic if i didnt have to.
engine is degreased, took off the front sprocket cover but didnt take off the starter, so that spot is still dirty, and so is the rear of the engine covered by the swingarm and kickstand. kicked over the bucket of grease and oil and water right when i finished :/
Last futzed with by BonelessSugar; Yesterday at 02:54 PM.
Old Yesterday, 02:49 PM   #43
Motorcycle(s): CB125T EX250E EX250F Ninja250R-street CBR250R-MC19 CBR250RR-MC22 NSR350R VF500 CBR600RR VFR750
Heh, heh… hate it when that happens!!! At least you got the cleaning done first!
Old Today, 07:47 PM   #44
BonelessSugar
Broke down carb all the way today. Going to pine-sol soak for a couple (4-7) days, then ultra-sonic clean (10:1 simple green? at 120-130F? 5-20mins?), then B-12 and carb cleaner. Compressed air between every step. If I see anything left I'll get some of those welding tip cleaners but I don't wanna for fear of messing up the passages unless I have to. Sanded (150 grit, probably would've been better with 220) one of the intakes down. First 3 pics are the second intake, last pic is the first finished intake.
[completely forgot to sand down the other before soaking in pine-sol] Doing the other [tomorrow] and going over with fine (1000/2000) sandpaper after. Should have all the supplies for gas tank now to do it tomorrow, too. Picked up missing spring clamps for carb as well and blew out the dirt from the hoses.
Had to double-bag everything in ziplock because the pine-sol was leaking, and I assume it'll leak through that too so I also have them in buckets individually and in a big container all together. Didn't soak plastic slides or diaphragms, everything else went in the bath.
Also found some sort of dirt/mud nest.
Last futzed with by BonelessSugar; Today at 09:11 PM.
rebuild help! tap_rack_bacon 2008 - 2012 Ninja 250R Tech Talk 1 May 31st, 2017 07:51 PM
Flying's Rebuild Flying 2008 - 2012 Ninja 250R Tech Talk 31 February 1st, 2017 03:57 PM
The Re-Rebuild... mr2peak 1986 - 2007 Ninja 250R Tech Talk 7 April 11th, 2016 07:11 PM
We can rebuild it. Alex Off-Topic 29 April 2nd, 2013 07:21 PM
So I think I am going to rebuild my bike... SpyderGirl 2008 - 2012 Ninja 250R Tech Talk 10 August 27th, 2009 08:49 PM
remote server monitor
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Except where otherwise noted, all site contents are Copyright 2021 ninjette.org, All rights reserved.
