Old January 10th, 2016, 03:15 PM   #1
Calix
Calix's Avatar
Motorcycle(s): '99 Ninja 250
Rear wheel and rear brake issues. [my problems continue]
So yesterday I received my 41 tooth rear sprocket, and decided to install it.
So popped the bike up on a rear stand and dropped the rear tire, Unbolted the old sprocket, put the new one on, put everything back on and remounted the wheel and adjusted the chain slack and alignment.
Decided to go for a quick test run, love the new sprocket, all my gears are taller and 1st gear is worth something now. But, as I was coming to a stop at the end of my street, I realized my back brake wasn't working at all. And upon starting to roll the bike back up my driveway, I noticed something else was off. I wasn't rolling anywhere near as freely as before. So, rolled it back up the driveway and into the garage and popped it back up on the rear stand.
I checked the rear brake to make sure I had actually aligned everything correctly and it looked well enough, the disk was in between the brake pad and the main "clamp" If not resting more on the pad. Didn't feel like going through the process of dropping the rear wheel again that night I left it until today.
Fast forward to an hour ago, I have once again dropped the rear wheel and have noticed that I may have put the left spacer on backwards. Here is a picture of what the current placement is now
By flipping it around it now puts the tire a tad more to the right which should move the disk perfectly inbetween the pad and the clamp.
Also noticed that one of my chain adjusters has a slight deformation
Would this be enough to cause spacing issues?
Now, my main problem is putting the wheel back on, the rear brake is now completely locked, no space inbetween the pad and clamp to fit the disk..
How do I go about fixing this issue?
This little ninjette has given me so many problems haha
Full album link if images aren't appearing http://imgur.com/a/GPbZ1
We may not all be geniuses, but we are all genius to some.
Hard work betrays none, dreams betray many.
Calix is offline   Reply With Quote
Old January 10th, 2016, 04:03 PM   #2
Sarge1992
Sarge1992's Avatar
Motorcycle(s): 2014 Kawasaki Ninja 650R
I actually just changed my chain and sprockets last night, here's a few pics of how it all should go. Also that spacer being bent like that almost looks like someone tried to force the axle shaft through without the holes being lined up, possibly using a hammer or something. Not sure how big of an issue it is but if it were me I'd change it, ebay is your friend. As far as the brakes, have you tried compressing the brake caliper piston back in?
Left side (chain side)
Right side (brake side)
Sarge1992 is offline   Reply With Quote
Old January 31st, 2016, 02:11 PM   #3
Ghostt
Ghostt's Avatar
Did you readjust the torque link?
http://faq.ninja250.org/wiki/What_is...torque_link%3F
Also you can slightly push the caliper piston in, and make sure that everything is ok with the pads, and clips etc...
When was the last time the caliper was serviced?
Hope this helps, if not let me know.
violente et ignorantia
ZX-2R BLOG
Old January 31st, 2016, 04:34 PM   #4
RickM
Motorcycle(s): 2000 EX250
You can use a flat blade screw driver the carefully spread the pads apart if there is room to try it. if it's completely seated against the each other, You can open the bleeder nipple(use a hose on it to prevent the mess) and push the caliper pistons in with your fingers from the backside of the visible pad.
RickM is offline   Reply With Quote
Old January 31st, 2016, 06:45 PM   #5
Ghostt
Ghostt's Avatar
No reason to open the bleeder, just use a C-clamp on the piston side of the caliper, you don't need to compress it a lot, just enough to fit it back in the disc.
You can either use an old pad, or a block of wood between the C-clamp and caliper pistons.
Remember to put the clamp in the center of whatever your using so both pistons move evenly. Don't want to just move one, both must move evenly.
I would advise you check the caliper, if any doubts service them using my guide, and might as well lube the slider pins as long as your there anyway.
After I looked at your picture again of the caliper, I see the piston side pad looks more worn than the other, and the piston looks pretty dirty, and I see no grease on the slider pin.
These are signs the caliper and sliders need to be served IMHO.
My write-up on the subject,
I recommend that every time you change your pads, you service the calipers, he's my write-up to help you out. It should fix your initial problem, and keep your calipers in top working order.
For those of you whom are scratching their heads, here you go,*
Front Caliper Service (also rear as well)
Many folks have posted here with a Varity of front brake problems.
*Many of which are attributable to the lack of proper maintenance.
*Here’s how you can always have a brake like when your bike was new.
A short list of the problems and the causes.
Soft lever or lever goes to the bar.
The usual cause is the pistons are pushed too far back into the caliper by a flexing a warped, coned, disc.
*Using up too much piston travel before the disc is pinched.
Juddering in sync with wheel rotation.
The disc is worn, and its thickness varies. *This causes the caliper to “sink” into the thin part and when the thick part comes around, it gets wedged into a smaller space causing a tightening of the brake. Then the tight spot passes through and it like the brake is released. Then repeat, repeat.
Cupped, coned, or warped disc.
Unfortunately this is a common problem with EX’s the cause is the disc is stretched in the center due to being rigidly bolted to the wheel. *The huge force of braking is transmitted to the wheel through the webbed center of the disc which gets stretched and becomes larger than the space it occupies in the center of the disc. This causes the center to push to the side trying to find room for itself.
*Resulting is a cone shaped disc.
Soft lever 2
The caliper has pistons only on one side, so as the pads wear the caliper must shift sideways apply even pressure on both sides of the disc.
*To allow this the caliper floats on two pins. *If these pins get dry (no grease) dirty or bent. The caliper won’t center itself and bends the disc to wherever it is.
This take up lever travel and when released pushes the pistons further back than necessary.
*If not fixed will eventually destroy the disc (warp it).
Ok how to prevent all of the above.
When new pad time comes around, resist the temptation to just pop in new one and go.
*Every time you must do these things.
Remove caliper disassemble and clean it.
Clean and re grease the sliding pins.
Polish the caliper pistons to remove dirt. If you just push the pistons back into the caliper leaks will result. Or binding.
Tools required:
12 mm socket
8mm open end wrench
3” or bigger C clamp
a supply of new bake fluid.
wire brush and or steel wool.
Remove the caliper from the fork leg but leave the brake line on.
Remove the old pads and the mounting frame (the sliding pins)
Remove the cover from the Master Cylinder on the Handel bar.
Attach the C clamp to one of the pistons but don’t squeeze it. *Pump the lever on the bar slowly to push out the other piston almost all the way. *Put the C clamp on that piston and push out the other one.
Remove both pistons by hand.
Remove all the rubber part from the caliper, the seals are in the grooves in the caliper and dull pointed thingy will get them out easy.
Disconnect the caliper from the brake line.
Soak all the rubber parts in new clean brake fluid * ONLY!!!!! * Rub them with you fingers till as clean as new.
The caliper can be cleaned with a wire brush or even a Moto tool for the internal grooves, NOW’s the time to paint it if you wish.
Polish the pistons till they are smooth and shinny. They are chrome plated. If any of the plating is chipped or damaged below the dust cap groove. *Replace it.
The master cylinder is the subject of another write up and we’ll assume it in good working order here.
If you suspect your disc is bad, your bets bet is to replace it with an after market one fro EBC or Galpher.
*Don’t remove the disc unless you intend to replace it. *It will assume a new shape if it is * stressed and will not be flat again. You can try to check its condition by placing a straight edge across the face of the pad swept area looking for any distortion.
Re assembly
Take the nice clean rubber seals and install them into the caliper then the Dust covers.
Wet all the rubber with new clean brake fluid and partially fill the caliper with new fluid.
Push the pistons though the dust seals and into the caliper body until the dust covers snap into the grooves.
Fill the MC with new fluid and pump the lever while holding the Line above the MC till clean fluid flows.
Connect the line to the caliper while holding it above the MC.
Pump the lever with the bleeder valve open till fluid flow from the bleeder.
*Hold the caliper so that the bleeder is the highest point.
Close the bleeder and pump more fluid into the caliper but don’t push the pistons all the way out.
Then squeeze the pistons all the way back in and install the new pads.
Re grease the slider pins and assemble the dust seals and re mount the caliper on the forks but leave the bolts loose.
Now clamp the caliper to the disc with the brake lever.
Look at the space between the fork lugs and the caliper, clamp and release a few times as you tighten the bolts by hand. It one lug touches much before the other the odds are you mounting bracket is bent. You can straighten it.
*After you get it the best you can. Some shim washers made from alum can stock can be fitted to the loose side.*
** *What we are doing here is trying to minimize the bedd in time and gets the best pad life.
Ok with everything tight you should be through, Notice we don’t need to bleed the brakes, but if you screwed up in any of the above steps, you might do that here.
Be careful to Bedd in the new pads gently.
*Too much pressure too soon will burn the pad material as only a small area will be gripping at first. You also won’t have full braking power till the pads are fully familiar with the disc
I also recommend flush and fill with new brake fluid, also I'd go with 5.1DOT
This is the one I use
https://m.motul.com/ca/en-us/product...-1-brake-fluid
Also inspect the brake lines, replace is needed, http://faq.ninja250.org/wiki/Stainle..._lines_upgrade
Venhill Introduction
Greetings everyone!
I wanted to take a moment to introduce you to Venhill...
Venhill manufactures some of the highest quality brake lines and cables you can get. We've been in business since 1971 and currently offer a full range of brake lines for the Ninja 250, first and second generations.
Our website, venhillusa.com, is setup to take orders for any year Ninja 250 as well as many other bikes. You can pick your bike and then customize your kits as you wish. We offer many different colors of hose as well as different finishes and materials for hardware. All of these options can be selected during the purchase process, so you'll be sure to get exactly what you want. You can even add length to hoses if needed.
To get an idea of our reputation, have a look at our eBay feedback.
If you have any questions or comments about Venhill products or brake lines or cables in general, please share them. I'm happy to be a resource for general information about brake lines and cables as well. Technical questions are welcome!
Please take a look at our website and let us know what you think. We just recently did a complete makeover and are interested in feedback. (venhillusa.com)
Have a great day and stay safe,
Chris
Venhill USA
For the detail oriented out there, some interesting things you might want to know about Venhill and our products:
Our factory is ISO 9001-2000 approved, which basically means we have the ability to consistently produce quality products. To qualify for ISO approval your factory and quality control mechanisms are evaluated as to whether your "good" products happen by chance, or if they are a result of good quality control.
All of our hoses are built to DOT/TUV spec and have been certified as such. We submitted hoses to the TUV (German DOT) for testing and only by passing are we allowed to use the TUV symbol on our hoses. Every hose we sell is built to these specifications, even if it is for track or offroad use only. It just makes for a higher quality product.
All of our hoses are hydraulically crimped, not hand crimped, and leak/pressure tested in a water bath. Yes, we immerse every hose we build in a water bath and pressurize it to check for leaks and to verify integrity of the crimps.
Venhill's hose core is authentic DuPont Teflon which is more expensive than generic "PTFE" but is stronger with a smoother inner bore. This is surrounded by 96 strands of braided marine grade stainless wire. 96 strands is more dense than some other braided line brands and the marine grade alloy is a stronger metal, which reduces expansion, the reason rubber hoses feel "spongy". Finally, we coat the braid with a UV-resistant PVC, extruded on during manufacture. This protects the hose as well as body and paint work.
Our hose design uses free-floating swivels, which allow you to loosely install everything before the hoses are tightened into place. This ensures the hose is not forced into a twist or kink when the banjo bolts are tightened. If you're worried about leaks, don't be. Our swivels work on the same premise as every threaded connection on a car or truck.
As you can see, we're sort of obsessed with quality and safety. We look at it this way: If we're asking you to put our brake lines on your bike, you're trusting us with the integrity of your brakes. That's a serious concept and we refuse to compromise when it comes to the integrity of your brakes.
I have these stainless steel lines on my Ninjette, and so far, some good, I recommend getting the stainless steel banjo bolts, I noticed my chrome ones have started to rust slightly, a good excuse for me to upgrade to titanium
On my 91 EX500 I have Spiegler, in orange to match that bike.
So you have made the decision that your OEM rubber lines need to be changed.
So why choose Spiegler Brake Lines?
A: Strength
That’s the short answer. But it doesn’t tell the whole story.
Spiegler Brake Lines strength comes from our innovation and research, materials and construction, knowledge and experience, service and support.
At Spiegler, we believe that the more you know about what we put into our products, the better you’ll be able to answer that question yourself.
That’s the short version; now let’s cover this topic more in depth.
Most OEM manufacturer recommend that you replace your rubber brake lines every 2 to 3 years. Why do the OEM’s recommend this? Over time OEM rubber lines deteriorate rapidly due to expansion and UV damage. This leads to increased braking distances and possible failure.
At Spiegler, our brake lines are made of only the finest materials available.
Outside casings are made of tightly woven stainless steel braiding that exceeds our competitors
The inside is made with DuPont’s PTFE-Teflon which eliminates expansion and adds durability
Crimp sleeves are made from stainless steel; competitors are using mostly carbon steel
Unique patented adjustable banjo fittings eliminate line twist during installation.
30% weight savings in comparison to other stainless steel braided brake lines
DOT approved
Lifetime warranty
117 color combinations possible which allows customers to personalize their bikes
We can build your lines to any specifications for custom applications
All brake line kits come ready for install
For more information on why you should choose Spiegler Brake Lines, you can view the following pages for a more detailed look into Spiegler brake lines.
When it comes to safety items like brakes, when in doubt, throw them out, it's your safety in your hands, and is cheaper than a visit to the ER.
Buy quality pads,I personally recommend EBC brand either the HH, or the Extreme HH.
EBC full floating rotor, replace the OEM rubber line with a stainless steel braided brake line, cheaper than replacing them with OEM.
On my 500 I have Spiegler line
http://www.spieglerusa.com/brakes/cy...line-kits.html
On my Ninja 250 i went with Venhill
http://www.venhillusa.com/products.html
With all that, it will stop on a dime, and leave you nine cents in change.
look here http://ebcbrakes.com/products/motorcycle/
And also read this, http://www.ex-500.com/wiki/index.php...otors_and_Pads
That should answer any questions you might have.
ZX-2R BLOG
Old August 7th, 2021, 03:19 PM   #6
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
I just put my rear wheel back on....
so it's fresh in memory ...this is on a 2012 Kawa. 250R ninja.
things of note grease the hole that the spacer by the sprocket goes into and the one on the other side... your bearings will last longer !
.....the spacer on the sprocket side is solid straight sides just a hole for the axle to go through.... on the brake side it's different the spacer there is stepped and the step goes IN to the wheel...
I widened out the brake pads by putting a large screw driver between them and prying at both ends of the caliper.
I put the axle in and stopped flush with the outside edge of the brake side spacer... that held the tire close to where it needed to be , next was getting the caliper between the spacer and the swing arm and in it's slot....
that was not so easy, but I did manage to do it by thumping, prodding and prying it finally slid over the slot for the caliper...then with a rubber mallet
i bopped the axle while lining it up with the hole in the swing arm then the adjuster and then all the way to the hilt.......
once it was on.... I pumped up the rear brake... and then it worked....
I had to put the wheel back on to be able to hold it from the force of the 3/4" drive socket I was using to take the sprocket off the engine shaft.... that puppy was on tight !!!!
but it popped loose and I'm good to go for putting on a 16 tooth front sprocket..... we'll see how that goes !
Bob.......
Rear brake light problems!! Please help!! Cole2 2008 - 2012 Ninja 250R Tech Talk 1 May 5th, 2015 07:55 PM
Just installed new gen rear wheel, brake problem? Zombarian 1986 - 2007 Ninja 250R Tech Talk 6 August 2nd, 2014 09:26 PM
08+ rear wheel, right rear set, rear brake system, seat cuong-nutz Items Wanted 2 October 6th, 2013 05:37 PM
rear brake issues mikromo 2008 - 2012 Ninja 250R Tech Talk 7 October 2nd, 2013 09:51 AM
