Old October 5th, 2016, 03:00 PM   #1
[motorcycle.com] - New Heavy-Duty Center Jack From BikeMaster
Maintenance on your motorcycle no longer has to be a chore with the new Heavy-Duty Center Jack from BikeMaster. This jack will lift your motorcycle in seconds, giving you more time to maintain or fix your bike and less time worrying about how you are going to work on it.
The Heavy-Duty Center Jack (P/N 152505) has a 1,100 lbs. lifting capacity with built-in stability tabs at the base. It is able to handle big and small bikes, making it a versatile tool for your shop. The heavy-duty steel is powder-coated to a beautiful red finish and includes a hex socket handle for raising and lowering. Removable rubber cradles, which are included, prevent your bike from slipping and sustaining scratches while using the jack. The rubber cradles also aid in custom height adjustments to your bike’s frame before lifting it in the position required for you to work. The Heavy-Duty Center Jack from BikeMaster also includes a one-year warranty.
To use, simply slide the jack under your motorcycle, ensuring it’s positioned under the frame. Adjust the rubber cradles to your desired height and turn the jack arm. You can achieve up to 16 inches of lift when fully raised.
The BikeMaster Heavy-Duty Center Jack retails for $109.95 and can be ordered through your local Tucker Rocky | Biker’s Choice dealer.
New Heavy-Duty Center Jack From BikeMaster appeared first on Motorcycle.com News.
Click here for full story...
Harbor Freight: Heavy Duty Padlock & Chain FerociousNINJA 2008 - 2012 Ninja 250R Farkles 2 August 23rd, 2010 11:05 AM
[motorcycle.com] - Steadymate introduces heavy duty Wheel Chock Ninjette Newsbot Motorcycling News 0 April 14th, 2009 12:50 AM
