#1 |
Electrical Problem?
Hi guys,
Glad to be a part of this forum. I'm new to riding, but I hope over time I can acquire enough knowledge to share with everyone here. Recently, I've had several problems occur simultaneously and not sure what the source of the problem could be. First off, my turn signals are randomly deciding, at times, to fluctuate between working normally and blinking extremely fast. At times, they will even just 'stay-on'. The next problem I realized I have now is that my brake lights are not activating when applying either the front brake or the back brake. Finally, my headlight (low-beam) bulb burnt out also. I replaced it and now it is working fine. Could anyone please offer me some advice to fixing these problems. I'm wondering if this could be an electrical problem, as all of these problems happened at the same time. So far, I've only fixed the headlight, but for the other two, I'm at a lose. I've searched around but couldn't really pinpoint a thread with a similar situation (if there is one, then please post it here). Thank you. Edit: Just thought I would add a bit more details. 2009 EX-250 (Japanese version) Stock No mods Last futzed with by preezert; July 6th, 2012 at 05:43 AM. |
#2 |
Join Date: Apr 2011 Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold) Posts: 479
Any mods or completely stock?
#3 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
check your fuse 4 the no brake light situation
#4 |
#5 |
Join Date: Apr 2012 Motorcycle(s): 1988 FJ1100 Posts: 165
for the turn signals, as long as everything is stock, it kind of sounds like a loose ground connection. Check the ground wires in all four of your signals.
High output motorcycle stators, rotors and replacement regulators/rectifiers. www.racetechelectric.com |
#6 |
Checked all the ground connections and still no luck. I even used a spare turn signal I had to check if one of the bulbs were going out.
Here's a video of the problem that I am having: http://www.youtube.com/watch?v=RIHGb...ature=youtu.be Edit: The brake problem is now fixed. When I took the bike apart, I looked at both filaments of the light bulb and they were both being activated. I messed with the rear brake pedal and found that the spring was always activated. Problem solved. As for the turn signal problem, could my turn signal relay be going bad? |
#7 |
the video made it look like the handlebar switch was shorting the two outside posts from rain water. just a guess though.
#8 |
Thanks for the suggestions, everyone.
All problems solved. In the case of the turn signal problem, the signal relay went bad. I replaced it and the signals are now working perfectly fine. |
#9 |
Join Date: Jun 2012 Motorcycle(s): 09 Ninja 250r Posts: 70
Does anyone know how to check the ground wires? I need to do this because my signals are acting too. Where does the ground wire connect to the body of the bike? Please if anyone knows, let me know or message me
Confusing electrical problem | tjthreat | 1986 - 2007 Ninja 250R Tech Talk | 8 | February 23rd, 2015 08:48 PM |
I got a little electrical problem. | infinitewhiskey | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 8th, 2013 10:36 AM |
Critical electrical problem | 05Ninjette89 | 1986 - 2007 Ninja 250R Tech Talk | 14 | June 15th, 2013 04:51 AM |
Electrical Problem! Help Please! | kawigirl | 2008 - 2012 Ninja 250R Tech Talk | 21 | January 30th, 2012 11:02 AM |
Electrical problem.... | Verus Cidere | 1986 - 2007 Ninja 250R Tech Talk | 2 | May 23rd, 2009 08:11 PM |
