Old July 26th, 2013, 04:54 PM   #1
Sebastian f7
Motorcycle(s): fz1 fz8 ninja 250
vacuum hose routing
Alright I got a new petcock for the bike carbs are clean, I routed all the hoses back where they were. The bike doesn't run right. I'm thinking the hoses aren't routed properly.
Is there a diagram I can follow somewhere?
The 2 on the top front of the carbs, where do they go? One pic I looked at showed a T off one of them... Definitely no T on mine.
Also the one on the fuel petcock was routed to the back of the fuel tank, seems odd to have a line essentially routed back into itself. Is that correct?
Sebastian f7 is offline   Reply With Quote
Old July 27th, 2013, 05:08 AM   #2
n4mwd
n4mwd's Avatar
Do you happen to have a california bike or tank? The CA tanks have three ports on the rear of the tank, everybody else has one port. Plus the CA bikes have a lot of extra pollution junk in there. Everybody else just has a carb.
Here are some pictures:
The vacuum line of carb #1 goes to the petcock and the vacuum line on carb #2 goes to the enrichener circuit. There are other ports on the sides that go to the enrichener on both carbs. Nothing goes to the tank directly.
The yellow hose is connected by a tee to both carbs. Its the bowl overflow line.
My Ninja Blog
Old July 28th, 2013, 07:06 AM   #3
Sebastian f7
Sweet thanks.
It's not a cali bike. Only 1 port off the tank. Is that just an overflow on the back of.the tank?
2008 250R Carb hose routing? devildogae 2008 - 2012 Ninja 250R Tech Talk 12 November 6th, 2016 04:32 PM
Carb Hose Routing jschatte 1986 - 2007 Ninja 250R Tech Talk 6 July 8th, 2014 08:30 AM
Breather and vacuum identification and routing help bitaria 2008 - 2012 Ninja 250R Tech Talk 6 April 10th, 2014 09:17 AM
Routing for fuel overflow hose haze5736 1986 - 2007 Ninja 250R Tech Talk 3 July 7th, 2011 07:09 PM
Routing for 'side hose' on fuel tank kobachi 2008 - 2012 Ninja 250R Tech Talk 11 December 12th, 2010 05:00 PM
