Old January 6th, 2016, 02:12 PM   #1
GAU-8
Socially inept. Yet FUN!
GAU-8's Avatar
Motorcycle(s): Current machines- 1992 SECA II 600, 2006 Ninja 250, 2008 Ninja 250
"Lil Miss" got cranky and stumbly
Hey all. Had a recent issue with one of my ninja's. I''ll call her "lil Miss" for now.
A little background info on her.
2008 Ninja 250: 8k Miles. One accident, after accident, an aftermarket slip on exhaust was installed. From my understanding valves were performed around time of repair. (I do not know if the prior owner, did or did not have a jet kit installed, with the Yoshi slip on)
then she was donated to our school
I do KNOW this.. a few times at the school, she was used, and had a minor flat spot, around 1500 rpm/drive off. but it was minor. like an off idle stumble. One week she is riding great. I come back after the weekend, and apparently she has a HORRIBLE flat spot now. (maybe a student dropped her??) so digging in..basically, giving her gas, between 1000-2000 rpm kills her, until you blip throttle, and get it above 2k. at which point it will climb between 3k to 5k and hang around there for a few seconds.
- One spark plug CR-8HSA, other is CR-8 HA (or something, it was missing one of the letters.) one was a little darker than the other. Replaced both with new CR-8HSA, and gapped per specs. NOTE: this was going by online. Since she is so new to us, we do not have a current '08 manual in our hands yet, but its on the way.
-Airfilter is clean, dry and new.
-carb fuel mixture screws. one is 3 turns out, one is 3-1/2 turns out. (NOTE: since im limited with internet at the shop, I matched both at 3 turns out, before I can research here/now.
pulled the carbs, cleaned out as much as I could, sprayed carb/choke spray through the orifices. no gummy-ness, or noticeable detriments.
Synched the carbs. (after warm up)Using the handy info from here on how to use "T"s for easy synching, without moving the messy hose issues)
: note: One of the boxes near battery, is making an electomechanical "etch etch etch" noise. which seems to coincide, with rpm/stumble, at idle. sometimes random, in a concise series, and/or not at all. (I have a photo of it, but currently on phone. after editing it I will upload.)
As she sits. needs a good 10 minutes to warm up. if the idle is set to around 800-1k , i can slowly ride it off, gingerly, and no stall issues. If I keep it set between 1100/1500 RPM, it will die on ride off. Almost no throttle can be given. also at this range, it will hunt and peck, between 1100/1500 rpm.
if set roughly 1600/2000 rpm. you can drive off, no hangups, but the bike will idle at 3 or 5 k for a few seconds then back down. and damn, that idle adjustment screw is a beast to turn. even after lubricated.
Anyways, thoughts, ideas, and maybe general info on 08 ninjas I may not know yet, characteristic wise.
sorry for length. trying to be concise and thorough, all though I can be wordy!
GAU-8 is offline   Reply With Quote
Old January 6th, 2016, 05:26 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
sounds like dirty carbs specifically the pilot jets. You could try running a tank with seafoam through it to see if you get lucky, but I doubt you'll avoid a full tear down of the carbs. While you have the carbs off triple check everything is the correct size.
Old January 6th, 2016, 07:28 PM   #3
HoneyBadgerRy
HoneyBadgerRy's Avatar
Sound like it needs a carb clean and rebuild.
Old January 7th, 2016, 07:44 AM   #4
allanoue
allanoue's Avatar
MOTM - Sep '14
I vote, try the seafoam fist. If that does not do it, tear down the cards.
Old January 7th, 2016, 08:30 PM   #5
GAU-8
GAU-8's Avatar
READERS DIGEST..... exactly the same outcome. below 1500 rpm dies. above 15/1700 rpm, still climbs to 3 to 5 k, and hangs, then settles to about 2 k.
for those that like to read. scroll below.
Did a complete disassemble (again), removed all jets, needles, diaphragms, screws.( anything that could come out, CAME OUT) Let it sit in carb cleaning fluid for an hour, then sprayed all orifices, springs, screws, tubes with a carb cleaner spray. Magnifying glass inspected. All components had the same "flow", and/or orifice size (if there were 2 or more like pieces). No burs, trash. Reset, re-seated, re-installed. very clean set of carbs. no gunk,junk,slime, anywhere.
NOTE: Right side exhaust header pipe (sitting on bike) still, is much cooler than the left. I can keep my hand on it (and this was after letting bike run for about an hour with the Sea foam).. A quick touch of the left header is all you needed to know it was skin blistering worthy. (makes me wonder if this was the reason mixture screws were set at 3 on one carb, and 3-1/2 turns out on the other?)
All hoses were cleaned, firmly, and fully installed, and clipped in, as well as a new fuel filter. the entire carb bank, is spotless. ( Choke operation, and idle adjustment screw works MUCH better though.)
(since I don't have the manual yet...)
Main jet (appeared) to be #98. BOTH carb needles had E-clip 3rd slot from top, and TWO washers on top. Is that a stock value? (again, it does have a Yoshi slip on) can anyone confirm or deny this is recommended for slip on and/or stock? AND/OR, I cannot truly confirm when last valve adjustment was done. (supposedly after repair, from an accident) POSSIBLE this related to valves needing adjustment?
Old January 7th, 2016, 08:32 PM   #6
HoneyBadgerRy
Originally Posted by GAU-8 View Post
Did a complete disassemble (again), removed all jets, needles, diaphragms, screws.( anything that could come out, CAME OUT) Let it sit in carb cleaning fluid for an hour, then sprayed all orifices, springs, screws, tubes with a carb cleaner spray. All components had the same "flow", and/or orifice size (if there were 2 or more like pieces). No burs, trash. Reset, re-seated, re-installed. very clean set of carbs. no gunk,junk,slime, anywhere.
NOTE: Right side exhaust header pipe (sitting on bike) is much cooler than the left. I can keep my hand on it (and this was after letting bike run for about an hour with the Sea foam).. A quick touch of the left header is all you needed to know it was skin blistering worthy. (makes me wonder if this was the reason mixture screws were set at 3, and 3-1/2 turns out?)
Stock needles don't have clips.
Old January 7th, 2016, 08:51 PM   #7
genosr1
Motorcycle(s): gsxr 750, sv650, 250 ninja
did you remove and clean pilot jets, they can be difficult to clean
Last futzed with by genosr1; January 7th, 2016 at 08:52 PM. Reason: morw
genosr1 is offline   Reply With Quote
Old January 7th, 2016, 08:56 PM   #8
HoneyBadgerRy
Also did you verify all four holes in the pilot circuit flow? To do this you need to spray with the mixture screw slightly unscrewed,, and completely in.
Old January 7th, 2016, 09:01 PM   #9
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Don't forget to sync the carbs. Maybe a cold header on ideal means something isn't matching between the carbs in the low rpm range. Then when you open it up your only using the main jets and it's all happy.
My understanding was OEM needles don't have a clip that can be adjusted so if yours is adjustable then you have a jet kit installed. There's no need for washer on a proper jet kit.
Old January 7th, 2016, 09:02 PM   #10
Did you bench-sync the carbs while they were off? (rojo beat me by a minute...)
Idle mixture screws have a spring, washer, and o-ring?
Last futzed with by jkv45; January 8th, 2016 at 07:08 AM.
Old January 7th, 2016, 09:32 PM   #11
GAU-8
GAU-8's Avatar
Thanks for the reminder! I always had a modified bike, completely forgotten that stock has no clips or spacers. Ok so we know the ket kit is after-market.
THAT I did do.
This one, technically no. more info please. anything that had a passage, I cleaned and squirted through. but I did a lot of squirting, and verifying through other orifices in carb body, on exit. THIS could lead somewhere though....
( addressed above, and thank you though for the time)
yes, and yes.
I did synch them today again, though. Idle/low rpm, is on the money (using an electric "synch-mate" or similar sounding name)
surprised by the quick responses, and thanks for your time.
Old January 8th, 2016, 06:50 AM   #12
HoneyBadgerRy
THAT I did do.
yes, and yes.
I will try to explain this as best I can. For starters place the carbs on a work bench with the fuel bowls, floats, and float needles removed (Main jets, jet holder, slide, and needle optional). Now put the mixture screws to 3 turns out and verify that carb cleaner flows through the pilot jet and out of the hole infront of the throttle plate. Screw the mixture screw in and notice how it is now sticking out of the hole carb cleaner just flowed through. Open the throttle plate and you should see some holes just behind where is seats. Spray carb cleaner through the pilot jet and verify that it comes out of those holes.
Old January 8th, 2016, 05:01 PM   #13
GAU-8
GAU-8's Avatar
That was the ticket.
I'm guessing spraying down into where the mixture screw was, may have blocked residue, or particulates more. But spraying into those holes, and out, cleared it out. Then doing what you asked, I could verify flow.
Thank you!
Both exhaust headers running same temps, no horrible stumble/ die on low throttle, and RPM stays where its set. And she runs fantastic now.
Old January 8th, 2016, 05:08 PM   #14
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
Thank you!
Glad to hear the bike runs well for you now.Ride on...........
pantera is offline   Reply With Quote
Old January 11th, 2016, 11:34 AM   #15
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
Awesome to see the forum helping someone out that was at a loss. Awesome!
Dsheumaker is offline   Reply With Quote
Old January 11th, 2016, 12:27 PM   #16
Glad you figured it out with the help of HoneyBadgerRy.
It sounds like another case of the carb not being absolutely clean before re-assembly. Happens all the time.
[superbikeplanet.com] - Back in Stock & Shipping: "Roberts" and "Lawson" Yamaha Art P Ninjette Newsbot Motorcycling News 0 March 13th, 2015 01:40 PM
[motorcyclistonline] - 7 Essential "Farks" for Cranky Old Bikers | COOK'S CORNER Ninjette Newsbot Motorcycling News 0 February 21st, 2015 10:00 AM
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl Ninjette Newsbot Motorcycling News 0 August 16th, 2012 04:30 PM
[sportrider - latest stories] - Chris "Teach" McNeil stars in "New Hire". Ninjette Newsbot Motorcycling News 0 March 5th, 2012 04:50 PM
[sportrider - latest stories] - Nitrous Oxide--"Wet" and "Dry" Kits Ninjette Newsbot Motorcycling News 0 April 9th, 2010 11:30 AM
