Old August 26th, 2010, 07:04 AM   #1
irishjohn
Motorcycle(s): KLR 650, XT250, KLX250s, 09 Ninja 250, KT250, Beta 250, Scorpa 250, Sherpa T 350, Penton Jackpiner 175, IT425
Good kitchen tool for removing bar ends.
In replacing my bars after my off road shunt, I found a easy way to loosen the red-lock holding the barends on. My wife has this little butane torch which she uses when cooking things like eggs provence or creme brule', to carmelize the sugar. It has an adjustable flame which you can adjust down to almost a pin point. I found that I could adjust the flame to where it only heated the screw and in 30seconds, I could remove the screw easily. I also found that when I reinstalled the barends, I heated the screw back up and it remelted the red locktite and holds the screws tight.
Just don't forget to return the torch to it's proper location in the kitchen!
irishjohn is offline   Reply With Quote
Old August 26th, 2010, 07:38 AM   #2
dubojr1
dubojr1's Avatar
Good find
Old August 26th, 2010, 08:18 AM   #3
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
or don't
kamikaze is offline   Reply With Quote
Old August 29th, 2010, 10:24 PM   #4
Not many of us have something like that lying around. Any suggestions for the rest of us? I want to buy these but I don't know if I'll be able to install them. I don't have an impact driver or a burner. I don't have an electrified work area anyway (parking space at condominium) and I hear that the 12v ones from Harbor Freight aren't that great either (not to mention the additional cost, cheap as it may be).
The paint is wearing thin/wearing away on my current bar ends and they are even changing from the metallic color underneath to rusty-color as they oxidize (oddly, still smooth and shiny), so I don't really care what they look like if I heat more than the screw... so will a regular lighter work? Like one used to light a grill?
Last futzed with by CZroe; August 30th, 2010 at 12:15 AM.
Old August 29th, 2010, 11:43 PM   #5
Cuongism
Cuongism's Avatar
Hey Jet, I have a minitorch if you wanna borrow it. Also, to get mine off I just used a ratchet attached to a Phillips #3 after heating them. Let me know if you need help.
Old August 30th, 2010, 12:16 AM   #6
That'd be awesome. If I still need access to it by the time I get around to ordering those, I'll check with you to see if the offer still stands. Thanks!
Old August 30th, 2010, 12:24 AM   #7
irishjohn
Aregular lighter won't work but one of the mini jet torches will. You can pick those up a lot of different places for under $10. I just needed a phillipps screw driver to remove the barend after get it hot enough.
Old August 30th, 2010, 08:51 AM   #8
Brian250R
Brian250R's Avatar
Motorcycle(s): 2009 250R
Use a lighter to heat the screwdriver shaft while it's in the screw. The heat should transfer....just not sure if it'll be enough.
Currently own: 2006 H-D XL1200L, 2009 Kawasaki Ninja 250R
Previously owned: 1980 Suzuki GS450, 1996 Honda VLX 600, 2000 Ducati 750 Monster Dark, 2004 Buell XB9S, 2000 BMW R1100SA
Brian250R is offline   Reply With Quote
Old August 30th, 2010, 07:39 PM   #9
smcbride11
smcbride11's Avatar
Motorcycle(s): '95 BMW K75
I used a heat gun on high (~425*, I think)... I don't think it actually heated the screw thorougly enough, though, since the cordless impact driver I have didn't make a dent.
My drill (Milwaukee 8A, the thing is amazing) with a P2 bit on it, on the other hand, made pretty quick work of the screw. Just be careful to add torque slowly so you don't strip it.
smcbride11 is offline   Reply With Quote
Removing bar ends jax 2008 - 2012 Ninja 250R Tech Talk 43 March 6th, 2015 08:26 PM
Finally got around to removing the forks, but missing one tool.. Insane Pie 2008 - 2012 Ninja 250R Tech Talk 7 May 9th, 2014 07:20 AM
Bar Ends skilletmo 2008 - 2012 Ninja 250R Tech Talk 8 March 8th, 2013 11:17 PM
Removing the bar ends ChaoSS 2008 - 2012 Ninja 250R Farkles 2 January 7th, 2013 03:14 PM
!@#$!ing bar ends! Torch, impact screwdriver, breaker bar, etc ALL failed. :( CZroe 2008 - 2012 Ninja 250R Tech Talk 64 September 13th, 2012 11:50 AM
