Old November 10th, 2011, 02:13 AM   #1
5evenz
5evenz's Avatar
Motorcycle(s): 09' 250r Thunder Blue
Clutch lever with too much play. how to fix?
I threw on some ride it levers and my clutch has a lot more movement/play while fully out. it does not rattle vertically but rather horizontally. how can this be fixed?
5evenz is offline   Reply With Quote
Old November 10th, 2011, 07:24 AM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
You could try shimming it with some shim stock. Fastenal carries it. I think the 11/32" ID shim stock would work. You'd have to check what the diameter is of clutch lever bolt. For some reason 8mm is coming to mind.
Link.
k-os is offline   Reply With Quote
Old November 10th, 2011, 08:41 AM   #3
rockNroll
rockNroll's Avatar
Motorcycle(s): black
check your clutch cable adjustment
Old November 10th, 2011, 11:01 AM   #4
k-os
His issue isn't the clutch cable being too loose. The "thickness" of the lever he installed seems to be too thin so there is play in the lever bolted to the perch.
Old November 10th, 2011, 11:06 AM   #5
setasai
setasai's Avatar
Link.
Similar idea, see if you can find some aluminum or brass tubing that'll go around the bolt to tighten it up. Then add some shims on top and bottom until everything is smooth. While you're at it, grease it up with some bearing grease.
Old November 10th, 2011, 12:49 PM   #6
k-os
I haven't had my 250 levers off, but is there not a shoulder on the bolt to fit the lever tight and help it pivot easy? On my Honda the bolt has a long shoulder that goes into the bushing on the lever.
Old November 10th, 2011, 01:36 PM   #7
DaBlue1
DaBlue1's Avatar
Just make sure the lever has the proper amount of slack. These adjustable levers have a little bit of horizontal play because they flex forward and backwards. What you see and feel is the lever flexing forward a bit which is normal and necessary for using the adjustment lever easily. Keep in mind the lever is in 2 pieces. As long as it does not rattle while riding, you should be fine. mine does the same thing if I wiggle it hard enough. Check my review on the adjustable levers.
http://www.ninjette.org/forums/showp...4&postcount=15
Old November 10th, 2011, 01:40 PM   #8
setasai
setasai's Avatar
There is but if the levers are aftermarket, it may not fit correctly. The OPs video showed aftermarket levers so I dont know how well they were supposed to fit or if he purchased an incorrect model.
Best course of action is to make sure it is designed for this bike and fits correctly but otherwise, he would have to do some adjustments to get them to fit the way he wants.. Nothing I've suggested would impact the usability or safety of the levers.
Old November 10th, 2011, 04:30 PM   #9
rockNroll
rockNroll's Avatar
He said horizontal movement, not up and down. Wouldn't the lever being thin be called up and down movement? In his video it looks like he's moving the lever in the direction of apply/release, not up and down.
Old November 10th, 2011, 04:38 PM   #10
5evenz
5evenz's Avatar
Yeah the Rideit levers have received good reviews. the brake is totally fine and being adjustable there is a bit more movement away from the grip in order to adjust them. But in my case there is at least 3/4 inch too much movement. also a tiny bit of plastic came out of there about the size of pen tip during install. maybe just debris as i cant find anything like it on my friends ninja. either way i will tinker with these suggestions and post what i find.
Old November 10th, 2011, 04:40 PM   #11
k-os
The piece of plastic you found is probably the clutch lever switch. You just broke the pin off of it.
Old November 11th, 2011, 06:15 AM   #12
DaBlue1
DaBlue1's Avatar
What he said.
http://www.ninjette.org/forums/showp...76&postcount=2
Clutch slipping... how to fix? walty87 2008 - 2012 Ninja 250R Tech Talk 35 September 10th, 2022 06:33 AM
Easy no tool Rattling Clutch lever or short fingers fix redsnapper 2008 - 2012 Ninja 250R Tech Talk 3 February 13th, 2014 06:16 PM
WTB: Clutch lever, handle bar end, dummy cap, and clutch lever holder. 09 250r SwagenGTI Items Wanted 5 March 4th, 2013 12:20 PM
WTB: Left side turn signal/clutch lever/ shift lever/fairing (green/red or black) daedrick Items Wanted 0 April 3rd, 2012 12:44 PM
Ebay lever broke my clutch lever mounting bolt! pilotgeorge747 2008 - 2012 Ninja 250R Tech Talk 8 December 22nd, 2011 07:22 AM
