July 25th, 2009, 07:41 PM | #1 |
Join Date: Jul 2009 Motorcycle(s): Ninja 250R 08 Posts: 59
Anyone Good with Painting?
I need to repaint a giant cabinant.
How should i do it, and what products. I heared using a Malamine paint would be good. I wanna make it glossy black. |
July 26th, 2009, 08:18 AM | #2 |
Join Date: Dec 2008 Motorcycle(s): 2008 ninja 250 Posts: 98
First you need to make sure that the surface you are going to paint is free from any loose paint or old finishes by sanding and or scraping off any loose material that you can see.Then you'll need to get a good paint primer from any paint or hardware store,we carry a good primer from Zinsser product lines where I work.Then depending how big this cabinet is you can use either a high gloss spray paint or rent an airless sprayer.These will prevent you from seeing brush lines if you apply the paint from a can.
July 27th, 2009, 05:12 AM | #3 |
Join Date: Dec 2008 Motorcycle(s): '09 ninja 250 (blue) Posts: 295
This weekend while watching one of the home improvement shows, the host said that if you want a nice, smooth finish when painting furniture to use a foam roller to avoid seeing brush/roller strokes.
A woman is like a teabag; you never know how strong she is until she's in hot water! |
JohnnyBravo, the painting | misfitsailor | Off-Topic | 5 | April 23rd, 2014 06:17 PM |
Painting? | Nathanptak | 1986 - 2007 Ninja 250R Tech Talk | 2 | May 26th, 2013 07:56 PM |
Considering Painting my Ninjette/Help! | ManOfGod | General Motorcycling Discussion | 4 | April 14th, 2013 09:14 AM |
Painting Helmets??? | ninjamunky85 | Motorcycle Gear | 23 | October 1st, 2012 09:05 AM |
Painting Question | Jordan91 | General Motorcycling Discussion | 8 | September 3rd, 2010 07:49 PM |
