Old August 15th, 2012, 05:43 AM   #1
azimmer11
azimmer11's Avatar
Downshifting by itself from 2nd into neutral??
I've been seeing this happen more and more, but if i'm riding in 2nd my bike will sometimes downshift itself into neutral. I'm not sure what the problem is but any advice will be helpful
Thanks
azimmer11 is offline   Reply With Quote
Old August 15th, 2012, 05:44 AM   #2
Vampyre
Vampyre's Avatar
Motorcycle(s): 2011 250R Black, 2005 ZX-6R Blue
Adjust the shift lever. You aren't fully getting it into 2nd, so it slips out under harder acceleration.
Vampyre is offline   Reply With Quote
Old August 15th, 2012, 05:44 AM   #3
lgk
are you resting your foot on the pedal?
Old August 15th, 2012, 06:17 AM   #4
azimmer11
azimmer11's Avatar
now that you bring this up, i think it may be the problem. I replaced my shift lever at the beginning of the season and may not have dailed it in very well.
Old August 15th, 2012, 07:37 AM   #5
bdavison
Wartown, USA
bdavison's Avatar
its not downshifting...what's actually happening is that the shifting dogs in the transmission were not fully engaged with your last shift...and when you apply acceleration, they pop out, and it goes to neutral.
What you need to do is make absolutely sure that you give FIRM complete shifts into every gear...particularly 2nd gear.
Motorcycle transmissions are notoriously unforgiving to light shifts from their design. Be sure-footed when you shift.
Old August 15th, 2012, 08:22 AM   #6
mariorivera830
MoVal's only ninjette :(
mariorivera830's Avatar
Motorcycle(s): 2012 Ninja 250r SE Black with a dash of yellow
I've been noticing this problem as well lately. Mine is a 2012 and I haven't done anything to it aside from a double bubble. I am mostly sure it's from not shifting fully into second, but if you find another cause I'd like to hear about it.
mariorivera830 is offline   Reply With Quote
Old August 15th, 2012, 08:23 AM   #7
azimmer11
azimmer11's Avatar
i'm shifting firm. i'm pretty sure its because of how i installed the new shift lever. going to take a look at adjusting it when i get home from work.
300 Slipping out of 2nd and into neutral anacron 2013 - 2017 Ninja 300 Tech Talk 38 June 7th, 2016 09:36 AM
Occasionally shifts to neutral from 1st to 2nd woofer987 2008 - 2012 Ninja 250R Tech Talk 8 May 6th, 2013 08:52 AM
Going from 1st to 2nd I hit neutral?? TwoWheelNinja General Motorcycling Discussion 6 October 10th, 2012 07:49 PM
2nd bike, 2nd low speed drop... -__- massacremasses !%@*#$%!)@#&!%@ I crashed! 8 June 9th, 2012 11:11 AM
Downshifting akshay11 Riding Skills 17 March 18th, 2012 02:52 PM
