#1 |
Join Date: May 2012 Motorcycle(s): 2010 Ninja 250r Posts: 102
High revs at stand still?
My 2010 idles at around 1500 when I start her up, but after i ride around or a bit and get to a red light the rpm stays at around 3000, is this normal?
If I stop for a minute it usually drops back down to 1500. Does this happen just because I'm riding it? |
#2 |
Sounds like your idle is adjusted too high.
When you start the bike, you should set the choke and let it warm up a bit. I have my check set at 3k. Once it's warmed up enough, turn the choke off and ride. Your idle should be at about 1500 rpm once the engine is fully warmed The black idle control knob is located in the hole of the left fairing at shin/knee height.
#3 |
My bike idles at 1500 when its warmed up, the high idle only happens when I'm riding around and get to a stop light. Does this happen to anyone else?
#4 |
Join Date: Jul 2011 Motorcycle(s): 2010 250r ninja Posts: 115
how hot is it when riding? could it be the cdi issue when outside temp is hot rpm read wrong....
#5 |
It's at least 100 when I was riding so do you think it was overheating? and it wasn't something with the reading because I could hear the engine actually in the higher rpm.
#6 | |
ninjette.org *********
Join Date: Jul 2011 Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r Posts: 347
it sounds like your idle is set a bit too high, but so long as it doesnt go into the red zone it should be fine, just be sure to keep an eye on tach and coolent temp sensor light. to adjust the idle, look at the left hand side of your bike with the black trim piece removed, and you should see a knob, twist it counter clock wise to youre liking.(i dont believe you need to take off the fairing but if you dont see it you might have to)
#7 | |
You could test it spraying carb cleaner or WD-40 around the cylinder-carbs boots and vacuum hoses. If a leak is present, the rpms' will suddenly drop when you spray over it. Lubing the throttle handle and cables is always a good idea.
Motofool ![]() .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí |
#8 |
figured my throttle would stick a little bit, probably going to the zip tie mod soon!
#9 |
pilot system is running lean.
its either a very slight vacuum leak, or your pilot screw is not adjusted correctly. we had an idle screw back itsself all the way in behind the screw cover all by itself on a new gen, so its not out of the realm of possibility. could also just be very slightly gummed up carbs
#10 |
I just broke 1k miles on the bike though, should i still test for a vacuum leak if i figured it was a sticky throttle?
#11 |
There's a knob under the left fairing by the kickstand. It adjusts the rpm while your bike is idle...
#13 |
After buying it I ride it everyday, but before I bought it it was ran at least once or twice a weak but not driven. Do I need to take of fairings to test for vacuum leak?
#14 | |
Ninjette Noob
Join Date: Apr 2012 Motorcycle(s): 2004 YZF-600r ---- 2006 Kawasaki Ninja 250r Posts: 227
What part of Arizona are you in?
#15 |
Tucson, it's a little cooler down here!, It's stop doing it but I have to adjust the idle knob at least once a weak?
#16 |
sorry...got here late... but i get the same thing and hottest it gets here is 80 for now least till the sun is out for a week straight then its about 90 but i idle at 1500 and when im at the lights i stay at about 3k so if yours is something crazy then mine is too... but well see...do you have any add ons?
SV Racing Parts, Black Front Stem Stand and SS Style Rear Stand Combination | SV Racing Parts | Motorcycle-related | 0 | January 15th, 2015 06:45 PM |
High Revs on Start-up - FI Model | alex192 | 2008 - 2012 Ninja 250R Tech Talk | 19 | October 27th, 2014 09:03 AM |
High revs | tehcarguy | 2008 - 2012 Ninja 250R Tech Talk | 11 | July 16th, 2012 04:57 AM |
Improperly disengage clutch ~ revs high, lower speed. | Ntotot | 2008 - 2012 Ninja 250R Tech Talk | 12 | August 26th, 2009 10:48 PM |
Very high revs with choke | diablo250 | 2008 - 2012 Ninja 250R Tech Talk | 9 | May 25th, 2009 08:27 PM |
