#1 |
Join Date: May 2009 Motorcycle(s): BLACK 09 250r, burnt orange 09 zx 6r Posts: 25
comp werkes fender kit trouble
K, so i was doin my oil change and i figured good time to throw the fender kit on while it drained. Got it all apart, fender off the bike, but there's this one step where its asking to drill the heads of the rivets out, and I can't get em for the life of me. They're heating up and starting to melt the plastic. I'm gonna try a dremel and get em from underneath. But its sayin to drill the heads out from the top. ??????????????, HELP
#2 |
maybe I should use a bigger drill bit???
#3 |
use a centerpunch to mark the center of the rivet first to help position the drill bit. us a small bit first if you are having problems with a large bit. Are the bits sharp? rivets are usually aluminum and relatively easy to drill.
#4 |
thas exactly what i was sayin
#5 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250R Posts: A lot.
Rivits are usually really easy to drill out. If your bits are dull it will cause excess heat. you can either replace the bits if they are cheap, or if they are really nice bits you can buy a sharpener. I honestly think it is not worth sharpening, but i have an uncle who always sharpens his bits.
Addicted to anything that has an engine and rolls. ![]() |
#6 | |
also, if you have a reversible drill, are you sure you have it turning in the right direction? ![]() |
#7 |
lmao, thas exactly what it was, reversed
![]() damn new technology, i thought it was just a basic drill. lmao. effin screw gun. But i still gonna need a smaller torque wrench mine only goes down to 30lbs. |
#8 |
lol... don't feel bad.
true story... I work at a NASA site and one day one of the techs is drilling a hole on the back of the chassis to install a connector. After about an hour he yells... "I give up.. all the damn drill bits are so damned dull around here!! Can't we get some sharper bits??!!" You guessed it, he had the drill in reverse. ![]() 3/8" drive torque wrench. usually works from about 10-90 ft/lbs. |
FS: Comp Werkes Exhaust - BRAND NEW | folky15 | Motorcycle-related | 3 | October 22nd, 2012 11:07 AM |
FS: 08+ Comp Werkes Exhaust $270 shipped | streetsquid | Motorcycle-related | 3 | September 24th, 2012 06:14 PM |
Comp Werkes Fender Eliminator (Ebay) Three left at the moment | cbowman78 | Motorcycle-related | 2 | January 9th, 2011 05:56 PM |
