Old January 8th, 2012, 04:41 PM   #1
dino74
dino74's Avatar
Exclamation Why did my rear brake caliper melt?
So I was at the track this weekend. During the warm up orientation laps, it seemed like my engine was lacking power. It was weird, it sounded good but no power. Power was restored about 3-4 laps later, figured it was due to the bike sitting for 2 months. Later in the day I saw this. It don't know what to think...
BTW: The reservoir was still full and I didn't touch the rear brake the whole day.
CVMA #55
Old January 8th, 2012, 04:55 PM   #2
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
Are your pistons seized and caused your rear brake to keep pressure on the disc, therefore heating it up and deforming the aluminum caliper?
k-os is offline   Reply With Quote
Old January 8th, 2012, 05:00 PM   #3
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
Not much help here but on OC moto the same thing happened to someone else, A reason why was never found :/
----> My Youtube! <----
Old January 8th, 2012, 05:00 PM   #4
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
In the first picture you can see tons of crud on the pistons. I suspect they couldn't move so the pads were stuck.
Wasn't the bike hard to push around before the race?
Old January 8th, 2012, 05:05 PM   #5
look at how far the piston is pushed out. the crud was on the inside. your brake fluid in the caliper is probably disgusting. when was the last time you cleaned it out?
but.... why would it keep pushing out... did the fluid boil and put even more pressure on? something had to keep putting pressure in that caliper...
Old January 8th, 2012, 05:16 PM   #6
k-os
I'm sure if the caliper heated up enough to deform it, the fluid inside it was boiling.
Old January 8th, 2012, 05:24 PM   #7
dino74
dino74's Avatar
Yeah, I usually clean out the caliper when I change the pads, but its been years since I changed out the rear pads. I think the crud on the inside are the melted rubber rings.
I'm guessing there was slight pressure on the pads and it just got hotter and hotter until it boiled. Its a no brainer that the caliper is hosed but I'm wondering if a malfunction in the master cylinder could have caused it. I was wrong about the rear brake not being used. It was pressed during tech. I'm probably going to replace the master cylinder just to be safe.
CVMA #55
Old January 8th, 2012, 05:28 PM   #8
i wonder how much rotational weight the rear brake disk is... it weighs a few pounds right?. . . . . . hmmmmm
Old January 8th, 2012, 05:39 PM   #9
dino74
dino74's Avatar
I don't use the rear brake at all ... except when I run off the track into the dirt
CVMA #55
Old January 8th, 2012, 06:10 PM   #10
jasle
Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L
+1. Brake fluid is hydroscopic and absorbs water. You should change fluid every 24 months at a min. I'd do 3-4 if you're on the track. From a sealed bottle every time. The one sitting on the shelf has been absorbing water since you bought it and broke it open.
The pistons rust in the bore and stick. I'd suspect this is what happened.
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles
jasle is offline   Reply With Quote
Old January 8th, 2012, 08:13 PM   #11
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Too much crud around the piston can cause your pistons to seize and as a result that is what happens.
Any time you change out your tires always spin your wheels and make sure they spin at least one full rotation. If not, you got issues.
That's what happened to me on my trackday Nov. @ Buttonwillow. My front wheel wouldn't even spin half a rotation. You can see in this vid Rexbo took where my entry speed was faster but he'd catch me easily in the straights.
Got home, pull the front wheel & brakes apart and one of the pistons had seized (fully extended) so it was always applying pressure.
Old January 8th, 2012, 08:41 PM   #12
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Oh Dean I have an extra rear caliper if you need it. LMK>
Old January 8th, 2012, 10:33 PM   #13
Skippii
Milkshake Drinker
Skippii's Avatar
Your caliper melted because it got too hot. Glad I could help.
Posted via Mobile Device
Old January 8th, 2012, 10:40 PM   #14
dino74
dino74's Avatar
Thanks for the offer! But I've got a second ninja to pull parts from.
CVMA #55
Old January 8th, 2012, 10:40 PM   #15
dino74
dino74's Avatar
Skippii, where have you been all my life?
CVMA #55
Old January 8th, 2012, 11:01 PM   #16
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
WTF?
I'm sorry....baller!
Old January 8th, 2012, 11:58 PM   #17
sure, blame the brakes.
Old January 9th, 2012, 12:45 AM   #18
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Ahhh, my padawan is learning fast.
Rear Brake Caliper Rebuild aurbz 2008 - 2012 Ninja 250R Tech Talk 6 April 5th, 2015 10:57 AM
Rear Brake Caliper Help blap6798 2008 - 2012 Ninja 250R Tech Talk 4 April 2nd, 2012 07:25 PM
Rear brake caliper mounting help. fbalsam 2008 - 2012 Ninja 250R Tech Talk 4 April 1st, 2012 08:21 PM
Rear brake caliper Reswob 2008 - 2012 Ninja 250R Tech Talk 4 April 8th, 2010 08:16 PM
Rear brake caliper issue sprale 1986 - 2007 Ninja 250R Tech Talk 6 December 9th, 2008 02:44 PM
