August 13th, 2022, 07:40 AM | #1 |
[webbikeworld.com] - 2022 MV Agusta Rush 1000 [Specs, Features, Photos]
Click here for full story...
2022 MV Agusta Rush 1000: The Disruptive Wizard Contents The Agusta Rush 1000 is a swanky four-cylinder streetfighter from the MV Agusta 2022 lineup. With very few units for sale, if you’re one of the lucky few to put this Rush in your collection, then you’ll be glad to know that MV Agusta has done everything possible to make it better than before. The limited edition model took advantage of the same tubular chassis and the 998 cc inline four-cylinder engine, the same as the Brutale 1000 RR, which comes from the F4, so it is not a novelty, but it was very well updated. For example, it now has a new camshaft profile that delivers more torque at low and medium rpm. MV Agusta upgraded the engine with a DLC, diamond-like carbon, and a surface coating that substantially improves valve surface sliding properties. In addition, this Italian bike is the only production motorcycle with radial valves and titanium connecting rods. The transmission also has new gearing, and the clutch bell is now reinforced to better support its horsepower. The Ohlins suspension comes with some adjustments to improve the response. Still, it is the hardware and software update where the most difference is noticeable since it enhances the feel of all the electronic aids, anti-wheelie, traction control with eight intervention levels, four maps of power, and adds and Continental MK100 ABS with Cornering function. The 2022 MV Agusta Rush 1000 starts at $40,600 USD / $43,520 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Agusta Rush 1000 in one place. Model Overview </p>General Info
Main Specs
Competitors 2022 MV Agusta Rush 1000 Specifications ENGINE Engine998 cm3 (60.9 cu. in.), Four cylinder, 4 stroke, 16 valvePower208 HpBore x Stroke79 mm x 50.9 mm (3.1 in. x 2.0 in.)Compression Ratio13.4:1Timing system“D.O.H.C”, radial valve and DLC tappetStarterElectricColorDRIVETRAIN ClutchWet, multi-disc with back torque limiting device and Brembo radial pump/lever assemblyTransmissionCassette style; six speed, constant meshFinal Drive Ratio15/41CHASSIS Suspension FrontÖhlins Nix EC hydraulic “upside down” front forks with TiN superficial treatment.Completely adjustable with electronically controlled compression and rebound damping with manually controlled spring preload.Suspension RearProgressive, single shock absorber Öhlins EC TTX completely adjustable with electronically controlled compression and rebound damping and spring preloadBrakes FrontDouble floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and aluminium flange – Brembo radial pump/level assembly Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia. Brembo PS13 brake pumpTires Front120/70 – ZR 17 M/C (58 W)Tires Rear200/55 – ZR 17 M/C (78 W)Fuel Tank Capacity16 l (4.23 U.S. gal.)ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering functionELECTRICAL BatteryLi-ion 12 V – 4.0 AhVoltage12 VAlternator350 W at 5.000 r.p.m.HeadlightTail LightDIMENSIONS Overall Length2.080 mm (81.89 in.)Overall Width805 mm (31.69 in.)Trail97 mm (3.82 in.)Wheelbase1.415 mm (55.71 in.)Ground ClearanceSeat Height845 mm (33.27 in.)Dry Weight186 kg (410.06 lbs.) – 184 kg (405.65 lbs.)WARRANTY WarrantyExtension 2022 MV Agusta Rush 1000 Features Electronics The evolution of the electronics compartment aims at making the Rush 1000 the easiest possible to drive despite its exceptional performance. Thus the extreme care in fine-tuning the electronic management of the engine. The 8-level traction control is particularly useful on a model boasting rocket-like starts, as is the anti-wheelie system and the EAS 2.1 Up & Down for clutch-free changes. Technology All MV Agusta technology is concentrated in this Rush 1000, which boasts the engine, transmission and chassis of the extremely powerful Brutale 1000 RR. Every technical detail has been adapted to the irreverent vocation of this “strip” bike, to obtain an even more exciting performance. Starting with titanium connecting rods, which reduce engine loads and inertia. Safety Brembo Stylema callipers linked to Bosch 9 Plus Race ABS with RLM (Rear wheel Lift Mitigation) constitute the ideal combination to manage the exuberance of the Rush 1000. Born to impress, it exploits the electronically adjustable Öhlins EC suspension units to further enhance driving control. 2022 MV Agusta Rush 1000 Photos 2022 MV Agusta Rush 1000 Videos 2022 MV Agusta Rush 1000. Number 3/300 and we start it up! REVIEW – 40.000€ MV Agusta RUSH 1000 / LIMITED EDITION 1 of 300 in The World Links MV Agusta Websites Other Links The post 2022 MV Agusta Rush 1000 [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Kawasaki Versys 1000 SE LT+ [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 21st, 2022 11:11 AM |
[webbikeworld.com] - 2022 BMW S 1000 R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 10:35 AM |
[webbikeworld.com] - 2022 BMW S 1000 XR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | July 6th, 2022 09:51 AM |
[webbikeworld.com] - 2022 Zero SR/S [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2022 01:52 PM |
[webbikeworld.com] - 2022 Zero SR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 03:27 AM |
