August 14th, 2022, 07:41 AM | #1 |
[webbikeworld.com] - 2022 MV Agusta Brutale Rosso [Specs, Features, Photos]
Click here for full story...
2022 MV Agusta Brutale Rosso: Brawniness Never Looked So Red Contents The new KTM 890 Duke R Brutale Rosso is one novelty in naked motorcycles by the Italian manufacturer. Its new three-cylinder engine now produces 110 hp at 11,500 rpm, while the torque is 83 Nm at 7,600 rpm, 25% higher than the previous version. This increment for 2022 favors top speed and acceleration. To help the rider control all this power, MV Agusta has equipped this naked bike with an MVICS system, Full Ride by Wire multimap, coupled with 8-level adjustable traction control. In addition, the Brutale Rosso comes equipped with an EAS 2.0 electronic gear change, both uphill and downhill, associated with a hydraulically controlled anti-rebound clutch. In the cycle part, we must highlight the increase of 20 mm, while the steering advance increased from 95 to 103.5 mm. This bike mounts a Marzocchi fork in the front and a Sachs monoshock in the rear. The braking system includes two floating discs at the front and a 4-piston Brembo caliper, while the rear wheel mounts a 220 mm disc with a double piston caliper. All this, together with the Bosch 9 PLUS ABS with RLM (Rear wheel Lift-up Mitigation), prevents the rear wheel from lifting during demanding braking. The hallmark of this Brutale is its characteristic “rosso” color (Italian for red), the definitive color of competitions, providing the final design touch. The 2022 MV Agusta Brutale Rosso starts at $15,398 USD / $17,152 CAD On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 MV Agusta Brutale Rosso in one place. Model Overview </p>General Info
Main Specs
Competitors 2022 MV Agusta Brutale Rosso Specifications ENGINE Engine798 cm3 (48.68 cu. in.), Three cylinder, 4 stroke, 12 valvePower110 horsepowerBore x Stroke79 mm x 54.3 mm (3.1 in. x 2.1 in.)Compression Ratio12.3:1Timing system“D.O.H.C” with mechanical chain tensioner and DLC tappetStarterElectricColorAgo RedDRIVETRAIN ClutchMulti-disc wet clutch with hydraulic actuation and back torque limiting deviceTransmissionCassette style; six speed, constant meshFinal Drive Ratio16/41CHASSIS Suspension FrontMarzocchi “UPSIDE DOWN” telescopic hydraulic fork with rebound-compression damping and spring preload external and separate adjustmentSuspension RearProgressive Sachs, single shock absorber with rebound and compression damping and spring preload adjustmentBrakes FrontDouble floating disc with Ø 320 mm (Ø 12.6 in.) diameter, with steel braking disc and flange Brakes RearSingle steel disc with Ø 220 mm (Ø 8.66 in.) dia.Tires Front120/70 – ZR 17 M/C (58 W)Tires Rear180/55 – ZR 17 M/C (73 W)Fuel Tank Capacity16.5 l (4.36 U.S. gal.)ABS SystemContinental MK100 with RLM (Rear Wheel Lift-up Mitigation) and with cornering functionELECTRICAL Battery12 V – 8.5 AhVoltage12 VAlternator350 W at 5000 r.p.m.HeadlightTail LightDIMENSIONS Overall Length2045 mm (80.51 in.)Overall Width875 mm (34.45 in.)Trail103,5 mm (4.07 in.)Wheelbase1400 mm (55,12 in.)Ground ClearanceSeat Height830 mm (32.68 in.)Dry Weight175 kg (385,8 lbs.)WARRANTY WarrantyExtension 2022 MV Agusta Brutale Rosso Features Electronics Eight levels of traction control and four riding modes: Sport, Race, Rain and Custom. The different sides of an engine bursting with confidence can be selected via joystick, for maximum enjoyment in every driving situation. Technology The Rosso Range shares the same technical solutions as other MV models, such as the MotoGP-derived counter-rotating crankshaft and the removable gearbox.*The structure has been revamped, thanks to a new progressive linkage rear as well as the new and improved-comfort saddle. Safety Power and scalability. Mission accomplished, thanks to the high-performing system on the front end boasting a pair of four-piston Brembo radial calipers. The new Continental ABS with cornering function improves performance and safety, even around curves. 2022 MV Agusta Brutale Rosso Photos 2022 MV Agusta Brutale Rosso Videos MV Agusta Brutale 800 Rosso 2022 – First Engine start ever MV AGUSTA BRUTALE Rosso 2022 Links MV Agusta Websites Other Links The post 2022 MV Agusta Brutale Rosso [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 MV Agusta Rush 1000 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | August 13th, 2022 07:40 AM |
[webbikeworld.com] - 2022 Zero SR/F [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 24th, 2022 01:40 PM |
[webbikeworld.com] - 2022 Zero FX [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 04:36 AM |
[webbikeworld.com] - 2022 Zero DS [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 04:13 AM |
[webbikeworld.com] - 2022 Zero S [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2022 03:47 AM |
