#1 |
Join Date: May 2015 Motorcycle(s): 2008 ninja ex250r Posts: 38
Turned my bike off something continued to run
I drove my bike to Walmart and then home maybe a 30 min ride its very hot today i haven't ridden this bike much so it might be normal but when i shut it down today something continued to run kinda sounded like the fan on a car it turned off after about a min or less
the most powerful ass is the one behind you. |
#2 |
As you suspected. The sound you hears was the radiator fan. It is normal for the fan to run for about 30 seconds after engine shutdown on a hot day.
#3 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninjette Posts: 809
Totally normal.. Just cooling it down
"That's what" -she |
#4 |
Or you'll need and old priest, and a new priest to fix it
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#5 |
Urban Legend
Join Date: Apr 2014 Motorcycle(s): 09 Ninja 250R SE - Circe Posts: 542
And be sure that you make this face
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up." -Baron |
#6 |
lmao
thanks guys lol
#7 |
Np
#8 |
#9 |
Cars do this too. You never noticed?!
#10 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
Those damn gnomes
![]() Spoiler for topic:
#11 | |
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250R Posts: 260
#12 |
EX500 full of EX250 parts
FYI, the fan fuse is powered by the always-hot white wire. The fan will have power even if the key isn't in the bike, and will turn on whenever the temp sensor gets hot enough and completes the circuit.
The older 500 (same junction box as the PreGen) had this wired up to the switched brown wire, so fan (and the accessory fuse) would only be powered when the ignition was on. They changed the harness in later years so these fuses were fed by the always-hot white wire instead. Personally, I prefer the old configuration, and will be changing mine back to switched power. This makes the accessory fuse switched again (avoiding the j-box hackery described here) and keeps the fan from running when the bike isn't on. I'm more concerned by the always-live circuit than losing the few seconds of cooling (of non-circulating coolant). Plus the fan can continue to run if you really want, just by leaving the key on after you kill the engine.
![]() *** Unregistered, I'm not your mom and I'm not paying for your parts, so do whatever you want with your own bike. *** |
Bike won't run above 5K rpm | edward2014 | 1986 - 2007 Ninja 250R Tech Talk | 12 | October 30th, 2014 08:51 AM |
Turned bike off while waiting for construction, 5 mins later won't restart | kchava | 1986 - 2007 Ninja 250R Tech Talk | 20 | October 16th, 2011 03:45 PM |
[visordown.com] - If BMW turned its K1600 into a sports bike | Ninjette Newsbot | Motorcycling News | 0 | August 4th, 2011 01:40 PM |
[motorcycle.com] - US Sales Continued to Decline in 2010 | Ninjette Newsbot | Motorcycling News | 0 | January 24th, 2011 07:10 PM |
Has your confidence in your riding skills ever turned you nutter on your bike? | virgilsc | Riding Skills | 22 | January 20th, 2011 04:01 AM |
